| FAQ: The Exhaust Thread | |
+8096_Juggernaut h20man al_roethlisberger Johnny5 bmcd9179 99Rivman matt270avian Sir Psycho Sexy th3fr4nchi5e bigblue96 2000ws6transam Setton stan llamalor2112 LT1Squirrel highwaywarrior Jamax pwriv97 c0reyl LARRY70GS flyineagle96 Pipes Bowersk charlieRobinson 69GSColorado gmann3001 Ron's Rocket Riv denim dboydakid RidzRiv jlaw J. Chris Davis Hometown Hero hollywood sealk VJD2 BrianEsser Tank Abaddon BMD crlombardi69 Karma 97 park ave IBx1 Snowdog L67 esquire23 DEMonte1997 Eldo #1BearsFan Rickw robotennis61 Chicken albertj 1wickedninja captshiner Shintsu greg_anderson_78 TonySmooth89 dreww urbsnspices nothincame2mind BillBoost37 BKRIV ewolfe0050 envus87 deekster_caddy TType_Riviera palermocorey90 oldsman105 Jack the R 97rivman 1998 Riv turtleman ender467 T Riley SoCal Riv Jason Mr.Riviera AA 84 posters |
| Subject: Re: FAQ: The Exhaust Thread Fri Sep 27, 2013 3:22 pm | |
| - charlieRobinson wrote:
- Like I said, cat was non existent prior to DP install.
All the welds are good, no leaks. Only difference is the O2 sensor emulator is now in place.
Could that be it? No, that's not it. BTW, that emulator is going to be useless after I tune that thing. Again, we'll look at it on Sunday. Quit worrying about it for now. | |
| Subject: Re: FAQ: The Exhaust Thread Fri Sep 27, 2013 3:25 pm | |
| No, the emulator won't cause exhaust fumes.
I think you need to back up and understand what you did by removing the cat. The cat converter's job is to make the exhaust "cleaner" by converting harmful smelly stuff into CO2 and water. When you take that out of the exhaust system, you are now going to have a more smelly exhaust because it's just blowing right through.
+/-1% LTFT doesn't mean anything. ALL cars have this much variance in daily use. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
charlieRobinson Expert
Name : Charlie Age : 38 Location : Toledo, OH Joined : 2011-05-17 Post Count : 3923 Merit : 31
| Subject: Re: FAQ: The Exhaust Thread Fri Sep 27, 2013 4:33 pm | |
| AA, like I said. The cat was hollowed out when we cut it. In other words it had no function before we installed the DP.
| Subject: Re: FAQ: The Exhaust Thread Fri Sep 27, 2013 5:01 pm | |
| Were you aware the cat was gutted before you opened it up? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: The Exhaust Thread Fri Sep 27, 2013 5:45 pm | |
- Were you aware the cat was gutted before you opened it up?
Nope. | |
h20man Enthusiast
Name : Aaron W. Age : 29 Location : CT Joined : 2013-10-04 Post Count : 242 Merit : -2
| Subject: exhaust note like a grand national? Sat Oct 05, 2013 12:15 am | |
| hey guys im new to the forums and have a 1996 l67 riviera that i will be doing some exhaust modifications on soon. i do realize that the 3800 sc doesnt sound good in general but for some reason the grand nationals seem to sound deep and throaty, i know that a turbo will soak up alot of noise compared to a supercharger but these are essentially the same motor just at a different angle. so i guess my question is there any way to get these cars to sound like a GN? | |
th3fr4nchi5e Addict
| Subject: Re: FAQ: The Exhaust Thread Sat Oct 05, 2013 12:51 am | |
| Unfortunately, theres not many ways to make a 3800 exhaust note worth hearing. I've seen all different setups and never heard one I like. With a cam, headers, or both, I've heard some better sounding, just not for me. There is an exhaust clip thread if you want to get an idea of some different setups people have tried. Check it out: https://rivperformance.editboard.com/t6854-exhaust-sound-clips?highlight=exhaust+clipsAlso, the 3.8 used in the grand national was essentially a completely different motor than the 3800. The displacement causes alot of people to think that parts might even be interchangable, and I was curious about that too. I think the Grand Nationals sounded so nice for a V6 because it was a SBC with 2 cylinders cut off. I read that the manifold, heads and valve cover bolt patterns were even the same, minus the extra set for for the 7th and 8th cylinders. Theres always setups people havent tried so dont hesitate to try something new if you have a good feeling about it. Maybe you'll come up with the ultimate solution to the exhaust note on a 3800. | |
Johnny5 Fanatic
Name : Going Nowhere Fast Age : 37 Location : Louisiana Joined : 2013-09-11 Post Count : 459 Merit : 1
| Subject: Re: FAQ: The Exhaust Thread Sat Oct 05, 2013 3:39 am | |
| My biggest aggravation the sound is that almost any exhaust you put to it has that nasty sound like a bunch of bumblebees in a tin can ... and on top that nasty cap gun pop when its coming down AA had the factory and removed the cat and it sounded really good but a catless is almost illegal in every state so look at your state emissions laws.. and borla xs sound kinda good on the 3.8 and I got my eye on a setup if it works im gonna post it | |
Johnny5 Fanatic
| Subject: Re: FAQ: The Exhaust Thread Sat Oct 05, 2013 3:44 am | |
| - h20man wrote:
- hey guys im new to the forums and have a 1996 l67 riviera that i will be doing some exhaust modifications on soon. i do realize that the 3800 sc doesnt sound good in general but for some reason the grand nationals seem to sound deep and throaty, i know that a turbo will soak up alot of noise compared to a supercharger but these are essentially the same motor just at a different angle. so i guess my question is there any way to get these cars to sound like a GN?
And to answer that question for the GN was a different engine I inquired about that along time ago it came down to displacement and valves so we | |
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2187 Merit : 149
| Subject: Re: FAQ: The Exhaust Thread Sat Oct 05, 2013 8:02 am | |
Nope, it was the Small Block Buick, not the SBC. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
h20man Enthusiast
| Subject: Re: FAQ: The Exhaust Thread Sat Oct 05, 2013 9:47 am | |
| yeah im leaning towards what johnny said i think ill try borla they seem to be a pretty quiet muffler, my dad thinks though that flowmaster will sound good though. My other car is a mitsubishi 3000gt and it sounds great straight pipe to just a flowmaster then again a much different smaller engine...... | |
th3fr4nchi5e Addict
| Subject: Re: FAQ: The Exhaust Thread Sat Oct 05, 2013 12:04 pm | |
Also, the 3.8 used in the grand national was essentially a completely different motor than the 3800. The displacement causes alot of people to think that parts might even be interchangable, and I was curious about that too. I think the Grand Nationals sounded so nice for a V6 because it was a SBB with 2 cylinders cut off. I read that the manifold, heads and valve cover bolt patterns were even the same, minus the extra set for for the 7th and 8th cylinders.
Nope, it was the Small Block Buick, not the SBC. Whoops! Yes, that is right. Larrys always on top of things! | |
| Subject: Re: FAQ: The Exhaust Thread Sat Oct 05, 2013 2:30 pm | |
| why is there so much dis on the 3800's exhaust sound? I think it sounds fine stock and can be greatly improved with exhaust mods. See Abaddon's Riv for a great example.
The 3800 II can for sure be made to sound great. No doubt about it. | |
| Subject: Re: FAQ: The Exhaust Thread Sat Oct 05, 2013 2:47 pm | |
| I haven't really heard any GN's that sound a lot different/better than these transverse 3800's and I would think it'd be much easier to make them. There are some really sexy sounding aussie longitudinal 3800 cars though that aren't even turbo. W-body headers only make it sound worse IMO. Most of my exhaust systems sounded decent up until headers went in and then I started getting picky because I didn't like it. The exhausts I've settled on after than were quieter and more unusual but I do like it now. I'm actually not a fan of stock exhaust with headers either. Most of the time, it still seems to have the unfavorable noises of any headered 3800 but without the toughness factor. | |
Johnny5 Fanatic
| Subject: Re: FAQ: The Exhaust Thread Sat Oct 05, 2013 3:06 pm | |
| Well so far I have only heard about 5 cars total thats sounded good. In my opinion tho which 2 were turbos and one was super cammed sounded like a corvette. And the 2 on here with take home modifications but my personal experience and being very cautious with these motors are not to drive anyone away | |
Jason Aficionado
| Subject: Re: FAQ: The Exhaust Thread Sat Oct 05, 2013 4:23 pm | |
| With all the new members joining, by all means please feel free to not just post the 1st thing that pops into your head. If you don't know why the old 3.8L V6 is different than the 3800, don't answer. There's a lot of misinformation in this thread, and it's popping up in others as well. The forum is a searchable database, and flooding it with garbage helps no one.
To answer the OP's original question: No. Nothing you do will get the 3800 in your riviera to sound as good as the 3.8 litre turbo in the Turbo Regals. | |
Johnny5 Fanatic
| Subject: Re: FAQ: The Exhaust Thread Sat Oct 05, 2013 7:31 pm | |
| - Jason wrote:
- With all the new members joining, by all means please feel free to not just post the 1st thing that pops into your head. If you don't know why the old 3.8L V6 is different than the 3800, don't answer. There's a lot of misinformation in this thread, and it's popping up in others as well. The forum is a searchable database, and flooding it with garbage helps no one.
To answer the OP's original question: No. Nothing you do will get the 3800 in your riviera to sound as good as the 3.8 litre turbo in the Turbo Regals. Put a address on it next time | |
h20man Enthusiast
| Subject: Re: FAQ: The Exhaust Thread Sun Oct 06, 2013 10:58 am | |
| ill just have to try my best and figure out what setup sounds good | |
bmcd9179 Fanatic
Name : Bryson Age : 28 Location : Utah Joined : 2013-09-21 Post Count : 288 Merit : 1
| Subject: Re: FAQ: The Exhaust Thread Sun Oct 06, 2013 5:06 pm | |
| I have a 1996 riviera to, where are you getting your exhaust set up? I want to by a full 3inch system any advice, I can install myself. | |
h20man Enthusiast
| Subject: Re: FAQ: The Exhaust Thread Sun Oct 06, 2013 6:45 pm | |
| Right now I'm leaning towards doing a 3in catted downpipe, to 3in piping going to a glass pack then a single borla muffler with a turn down tip. Figured ill save weight without duals plus easier install but that's up to the muffler shop | |
RidzRiv Addict
| Subject: Re: FAQ: The Exhaust Thread Sun Oct 06, 2013 7:07 pm | |
| I think another thing to consider that many do not think about is the thickness of the piping used for the exhaust parts. The thickness of the pipe walls make a difference, but it is hard to find different thicknesses. Perhaps someone here knows where to look for exhaust piping that comes in different wall thickness. | |
Johnny5 Fanatic
| Subject: Re: FAQ: The Exhaust Thread Sun Oct 06, 2013 11:35 pm | |
| All I say is ask your self one question.. What are you doing it for Performance, Sound, or just cause you can? | |
h20man Enthusiast
| Subject: Re: FAQ: The Exhaust Thread Mon Oct 07, 2013 7:44 am | |
| Well I don't really care too much about sound I mean I don't want it to have that tin can noise but I'm mostly in it for performance. As said before the 3800 isn't a motor that sounds good in the first place | |
| Subject: Re: FAQ: The Exhaust Thread Mon Oct 07, 2013 12:04 pm | |
- why is there so much dis on the 3800's exhaust sound? I think it sounds fine stock and can be greatly improved with exhaust mods. See Abaddon's Riv for a great example.
The 3800 II can for sure be made to sound great. No doubt about it. I still need to post the "new" sound. | |
J. Chris Davis Aficionado
| Subject: Re: FAQ: The Exhaust Thread Mon Oct 07, 2013 3:38 pm | |
| So I've decided I might do away with my Flowmaster Delta 50's and get something quiter. With my Flowmasters I have more inside noise than I wanted and they are a little louder than I thought they would be outside of the car as well. I'm just not sure what to get to replace it. Def something quiter inside and out. | |
| Subject: Re: FAQ: The Exhaust Thread | |
