| Grinding noise, but good brake pads | |
+6Mr.Riviera deekster_caddy albertj T Riley AA 1998 Riv 10 posters |
| Subject: Re: Grinding noise, but good brake pads Thu Mar 27, 2008 11:32 pm | |
| What about rotor rust/scale? Ridges? | |
| Subject: Re: Grinding noise, but good brake pads Fri Mar 28, 2008 12:04 am | |
| - Jack the R wrote:
- I had a scraping sound develop a couple days ago. My mechanic said it was because the dealer installed pads that were too hard for the rotors. He wanted to put on a softer pad
Whaaaat? I don't think so. All of the different types of pads out there, metallic, ceramic, kevlar, jujubes ( ), whatever... will not be too hard for the rotor! They'd better be hard or your car wouldn't stop when you step on the pedal!! The 'hard' pads will just last longer and _may_ wear the rotors a little faster but will not make a scraping noise unless there is something dragging against the pad or rotor. | |
| Subject: Re: Grinding noise, but good brake pads Fri Mar 28, 2008 11:19 am | |
| - deekster_caddy wrote:
- What about rotor rust/scale? Ridges?
The rotor surface is not good. A bit rough, and a ridge around the outside edge. Will have to see if it can be turned or is time for replacement. Maybe next week. | |
| Subject: Re: Grinding noise, but good brake pads Fri Mar 28, 2008 5:06 pm | |
Whaaaat? I don't think so. All of the different types of pads out there, metallic, ceramic, kevlar, jujubes (), whatever... will not be too hard for the rotor! They'd better be hard or your car wouldn't stop when you step on the pedal!! The 'hard' pads will just last longer and _may_ wear the rotors a little faster but will not make a scraping noise unless there is something dragging against the pad or rotor. Thanks for the input. Unfortunately the only way for me to determine which of you is right is to throw you both into a river and see who floats. | |
| Subject: Re: Grinding noise, but good brake pads Fri Mar 28, 2008 5:40 pm | |
| but first you have to tie bricks to their feet. then the one who floats is a witch. thats the one you must kill!
i have to agree with Derek on this one though. i dont think you could even find pads that would be that hard on rotors. especially if you/the mechanic installed OEM quality pads (ceramic). now what could have happened, is the dealer installed semi metallic pads that were noisier than what you had before. or maybe you just need some stop squeak on the back of the pads to keep then from sliding on the piston/caliper housing. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Grinding noise, but good brake pads Fri Mar 28, 2008 6:25 pm | |
| A witch! A witch! Burn her!
Still need to see the undersides of those pads. Whatever the case, you're going to want new rotors and pads. How many miles do you think are on this set? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Grinding noise, but good brake pads Fri Mar 28, 2008 7:19 pm | |
| Subject: Re: Grinding noise, but good brake pads Sat Mar 29, 2008 4:26 am | |
- A witch! A witch! Burn her!
Still need to see the undersides of those pads. Whatever the case, you're going to want new rotors and pads. How many miles do you think are on this set? 4-5k | |
ewolfe0050 Aficionado
| Subject: Re: Grinding noise, but good brake pads Sat Mar 29, 2008 11:10 am | |
| [quote="Jack the R"] - ewolfe0050 wrote:
- F-body brake mod won't cause you to get a larger rim. The difference is that they are dual pot and aluminum. They might cover a little more rotor but they don't stick out or up any further.
- Quote :
- Did you stay with an 11" rotor? I didn't know that was an option.
Jack the R- '97+ all came with the 12" rotor. The earlier ones have the 11". That's the reason for the spindle change on the '95-'96. | |
| Subject: Re: Grinding noise, but good brake pads Wed Apr 02, 2008 1:48 pm | |
| Well the brakes feel good, no complaints. However, I found a problem.
The Riv was driven straight from the shop to my garage and sat overnight. Drove to work this morning, then home for lunch, only to find a small puddle of oil in the garage where I always park it, just inside of the left front tire location. Look under the car and can't see much, so I pop the hood and find the brake fluid res has fluid all over the outside, it has run down over the booster housing, and onto the trans then to the floor. The lid is on tight, and the reservior is FULL to the max. Overfilled and spilled, or the system now has too much fluid due to the full pads now on the car. But it doesn't seem likely to me that it would blow past the lid that is on tight? Is there another seal, maybe at the bottom of the res that could leak?
Anyway, I called the service mgr today and they are going to clean up the engine bay over lunch tomorrow. Big question for me is would overfilling, then driving/braking cause the fluid to blow out a seal? In which case, there may be a repair needed? | |
| Subject: Re: Grinding noise, but good brake pads Wed Apr 02, 2008 1:56 pm | |
| I think if the reservoir were overfilled, the pressure could easily squeeze fluid through the seal of the master cyl.
Could it be the fluid was there from when they spilled it during install and weren't aware? All you need to do is clamp the caliper open, and the fuid will shoot out of the MC.Maybe it wasn't actually leaking while you were driving, just dripping from a sloppy install. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Grinding noise, but good brake pads Wed Apr 02, 2008 2:00 pm | |
| in theory the brake fluid resivoir has enough fluid to go from being full with new pads and rotors all around to pads and rotors really low, you should still have enough fluid for that without adding any. Then when you compress the caliper pistons, you refill the resivoir from the pistons! If you add fluid somewhere along the line, you'll have enough in there to overflow it when you go back to new pads.
It can also be a nice way to gauge pad life - resivoir full = new pads and rotors - resevoir almost empty - check those pads! | |
| Subject: Re: Grinding noise, but good brake pads Wed Apr 02, 2008 4:11 pm | |
| I know the reservior was just slightly above the minimum fill mark on the tank last week, so it seems most likely they overfilled it during the job, since it is currently filled far above the max line. Who knows, they may have overfilled AND spilled in the process. All I know is the fresh fluid starts right up at the cap. I'll have to keep an eye on it for more leak issues after they clean it tomorrow. They offered me a loaner to get back to work if I want, or it may take up to an hour to get done. I should see if they'll give me a Super or Enclave. | |
| Subject: Re: Grinding noise, but good brake pads Wed Apr 02, 2008 4:13 pm | |
| BTW, the inside pads were almost completely gone on both fronts, while the outside had a solid 1/4" left. Why would they wear so unevenly? Poor install, back whenever... ? | |
| Subject: Re: Grinding noise, but good brake pads Wed Apr 02, 2008 10:25 pm | |
| I find people tend not to clean or lube the caliper guide pins well enough. I make the pins (and inside the caliper brackets) really clean and I use never-seize instead of the caliper grease many calipers come with.
Would account for uneven wear. | |
| Subject: Re: Grinding noise, but good brake pads Thu Apr 03, 2008 1:25 pm | |
| I removed 3 turkey basters worth of excess fluid from the reservior this morning, just to get it down to the max fill mark. Then took it in at noon and they cleaned up their mess in and under the engine bay. Looks good now, but frustrating to have to do this. Same dealership owner when I had my F150 and had them do a winter oil change, drove home and parked in the driveway only to find a big puddle of oil in the morning. Not a leak, they simply didn't bother to catch the spillage when they removed the filter, just let it run all over the place. | |
| Subject: Re: Grinding noise, but good brake pads Tue Apr 29, 2008 9:09 pm | |
| Hey Dave
I "second" what Derek said. I've gone so far as to put the OE stainless/plated caliper pins in a drill chuck, spin them fast while polishing with ScotchBrite and a dab of antiseize (to keep from lelaving dust), then l clean them with denatured alcohol (ummm... the cheapest dry gas) then when reinstalling them, lube them with anti-seize (the silicone lube turns to boogers after a certain time). The aftermarket zinc chromated pins are probably not worth polishing, that would strip off the coating - just replace them.
Last edited by albertj on Tue Apr 29, 2008 9:24 pm; edited 1 time in total (Reason for editing : clarification) | |
| Subject: Re: Grinding noise, but good brake pads | |
