| Should I replace my OEM thermostat? | |
+20deekster_caddy ghpcnm Eldo curious riv captshiner Chicken EASHER Karma Rickw rivboy 1wickedninja SuperRiv07 lyonsperformance 1998 Riv manofmany 96riv robertwolf86 Mr.Riviera NO 4 EVR AA 24 posters |
69GSColorado Fanatic
Name : Jordon Joined : 2011-07-16 Post Count : 406 Merit : 29
| Subject: Re: Should I replace my OEM thermostat? Fri Feb 10, 2012 7:05 pm | |
| Alright thanks. I try to stick true to brand, so my thermostat will match my SLP headers. Haha I know its silly, but to each their own I guess. | |
| Subject: Re: Should I replace my OEM thermostat? Sat Feb 11, 2012 12:14 am | |
| Yes, it is silly, but it's your money. SLP sources their t-stats from Motorad. You can pay $15 + shipping, our get the same thing at Autozone for $5-10 less. FYI, AutoZone calls them Duralast - same product. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Should I replace my OEM thermostat? Sat Feb 11, 2012 2:12 am | |
| Oh I misunderstood you.. well if its the same part then yeah ill definitely go to autozone instead. | |
charlieRobinson Expert
Name : Charlie Age : 38 Location : Toledo, OH Joined : 2011-05-17 Post Count : 3923 Merit : 31
| Subject: Re: Should I replace my OEM thermostat? Wed May 22, 2013 1:10 pm | |
| I was idling at like 210ish with my 180 tstat a few days ago in traffic. Really thinking about trying a 160 tstat out just to see how it helps in the hot hot heat we are going to have this summer.
Probably need a tune to get the fans to turn on sooner too, huh.
OK, just read some. Never mind. I dont need a 160, I need a tune.
| Subject: Re: Should I replace my OEM thermostat? Wed May 22, 2013 1:17 pm | |
| - charlieRobinson wrote:
- I was idling at like 210ish with my 180 tstat a few days ago in traffic. Really thinking about trying a 160 tstat out just to see how it helps in the hot hot heat we are going to have this summer.
Even with a 180 T-stat, you're still going to reach over 200*. Yes, if you want to reap the full "benefits" of a 180 stat, you need to have to fans kick on sooner... | |
| Subject: Re: Should I replace my OEM thermostat? Wed May 22, 2013 1:18 pm | |
| Scott, as soon as I get my exhaust done, I will be paying you a visit!
| Subject: Re: Should I replace my OEM thermostat? Wed May 22, 2013 2:32 pm | |
| Subject: Re: Should I replace my OEM thermostat? Wed May 22, 2013 2:56 pm | |
My Eprom chip is tuned by Sinister to turn the fans on at 180 deg.I dont know about the series 2? you can install a sensor like this one to come on at any temp without the hassle of tuning your pcm.super easy to install and wont interfere with anything I think.1 fan runs for the AC,while the other fan runs the rad according to the FSM. Jegs also sells a single fan sensor too that you can program to run at 180deg http://www.jegs.com/i/JEGS-Performance-Products/555/52126/10002/-1?parentProductId=1557724 | |
| Subject: Re: Should I replace my OEM thermostat? Wed May 22, 2013 2:59 pm | |
| Thanks, Robo, but I plan on just setting the fan variable in the PCM once it's tune time. ISNT THAT RIGHT, SCOTT, MA MAN!? | |
| Subject: Re: Should I replace my OEM thermostat? | |
