| FAQ: Supercharger Noise (Bad Coupler) | |
+6497rivman1 AlienShoe charlieRobinson th3fr4nchi5e LaFlare matt270avian designer1962 Z-type highwaywarrior The Roadmaster crstump RidzRiv GEAREDUP robotennis61 ejeraser Cmurphy Lenrapkins BMD 97 park ave Abaddon Natesriv Eldo LARRY70GS Hometown Hero crosss3 T Riley rivman96 Rickw curious riv captshiner gotboost? lyonsperformance manofmany riviera2454 Lucas ibmoses TonySmooth89 1wickedninja Karma Chicken albertj baynes72 RhinoFLA ZEP 1998 Riv sburch23 overownt deekster_caddy IBx1 ewolfe0050 Buapo dreww Shintsu BillBoost37 Jason shrek90 Mr.Riviera oldsman105 turtleman urbsnspices 98riv AA NO 4 EVR robertwolf86 68 posters |
robertwolf86 Fanatic
Name : robert Age : 37 Location : new york Joined : 2007-03-11 Post Count : 268 Merit : 0
| Subject: FAQ: Supercharger Noise (Bad Coupler) Sun Mar 11, 2007 4:55 pm | |
| hey im having some problems with my s/c. I am hearing some noise in the s/c and just changed the oil in the nose. the noise is still there so i think the gears were starting to strip b/f i changed the oil. is there anything i can do to make it last longer?it still has the 3.8 pully on it. I can get a brand new supercharger with a 3.6 pully from the manufactor for $750.00. | |
NO 4 EVR Addict
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Sun Mar 11, 2007 5:19 pm | |
| Could be the coupler or bearings (probably coupler). Or if you aren't 100% it is the SC then it could be a nearby pulley.
Make sure you have some supporting mods when dropping pulley sizes
And welcome! | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Sun Mar 11, 2007 5:24 pm | |
| We rarely see blower failures in these engines. Check the coupler and surrounding pulleys, as Troy mentioned. Would hate to see you spend that much, although $750 is a good deal... almost hard to believe! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
98riv Moderator
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Sun Mar 11, 2007 6:14 pm | |
| As it was said above, it is probably the coupler. Make sure it isn't coming from a nearby pulley. Here are the instructions on how to replace the coupler http://www3.sympatico.ca/aepa/blowerinstall.html. It is for a Grand Prix, but the steps should be similar enough for you to figure out. This is from the link: "If you’re not sure if your coupler is bad, remove the S/C belt and “rock” the pulley back and forth. You should not feel any play. If you don’t, your coupler is ok, if you do, follow the instructions to fix it." _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
Last edited by 98riv on Fri Dec 23, 2011 9:45 pm; edited 3 times in total (Reason for editing : Added new link.) | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Sun Mar 11, 2007 7:16 pm | |
| no it is coming from the s/c not the other pullys. | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Sun Mar 11, 2007 7:26 pm | |
| hey thanks for the info ill see on monday if there is any play in the s/c pully. i have had the car on and put a screwdriver up to the nose of the s/c and thats where i heard the noise coming from so well see what happens. thanks for the link to. | |
urbsnspices Fanatic
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Tue Mar 13, 2007 8:20 am | |
| Did you put enough oil back in? Did you use GM SC oil?
When the SC is level, the oil should come up to the threads on the oil fill port.I have heard nearly dry superchargers run and they are a bit louder. More of a whizzing then a grinding.
Dont buy a new SC, even if yours is shot you can find a low miles one for much cheaper. There are ported used ones selling 350. | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Tue Mar 13, 2007 5:45 pm | |
| i emptied my s/c oil and it was down a/b 1/2 way. i filled it up with new to the right point. it still makes the noise. it makes a little noise when the car is on and when i turn it off it makes a cha-ching noise in the nose of the s/c. | |
urbsnspices Fanatic
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Wed Mar 14, 2007 7:53 am | |
| I would try changing the coupler if you havent tried that yet. It is pretty simple, especially with the write-up. If you think your snout bearings are bad (very rare), you could buy a lower miles snout. Swap the new snout in when you change the coupler.
Where in NY are you? Im on Long Island if you need help. | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Wed Mar 14, 2007 7:56 pm | |
| im in binghamton. your a/b 3-5 hrs away from bing prolly. | |
| Subject: Is it time to replace the coupler? Fri Nov 02, 2007 12:21 pm | |
| that's a pretty recent video of mine (from when I changed the timing set) I hear the noise when its running a little bit sometimes. I'm planning on waiting to port the blower to change it - next few months... | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Nov 02, 2007 1:13 pm | |
| There's some slop in the turbine gears. Mine moved like yours. 4 hours later, with my blower in 3 pieces, I found my stock coupler to in good shape. 145k miles on the car. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
oldsman105 Junkie
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Nov 02, 2007 9:30 pm | |
| For me, I would change the coupler any just for piece of mind. | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Nov 02, 2007 11:11 pm | |
| mine was like that before the new coupler. it doesnt look reamed out, but it is enough to make noise. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
shrek90 Special
Name : Brandon Age : 34 Location : Anderson, IN Joined : 2007-12-06 Post Count : 4 Merit : 0
| Subject: Supercharger Noise Thu Dec 06, 2007 10:00 pm | |
| i have a 96 SC Riviera and when i idle, i can hear a noise in the motor it sounds like something is clanking around, its not very loud but its noticable i heard it was the coupler in the nose of the supercharger any suggestions?? | |
Jason Aficionado
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Thu Dec 06, 2007 10:08 pm | |
| it probably is the coupler. Order a new coupler, a supercharger gasket and 2 bottles of supercharger oil. You can order all of it through one of the main vendors (wbodystore, zzp)
the procedure is very easy. http://www.regalgs.org/coupler.shtml | |
BillBoost37 Junkie
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Dec 07, 2007 7:32 am | |
| The noise is a clanking like metallic?
You may want to replace the bearings as well as the coupler for peace of mind.
Check out Rolling Performance they have superfast shipping, usually the best prices and nicely detailed instructions (similar to RegalGS as linked above)
Overall it's an easy thing if you have a press available. | |
Shintsu Expert
| Subject: S/C sound Tue Mar 11, 2008 2:00 am | |
| I'm not sure why, but sometimes when I rev my car up it sounds very boosty. It reminds me of my dad's GTP. Most of the time though, it's not so loud and noticeable (You can still here the more rough kind of sound it usually makes). I took a video of it awhile back when I still had my CAI on it (took it off because it kept falling off, meaning it was just sucking unfiltered air in). Link | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Tue Mar 11, 2008 8:48 am | |
| It's probably not that your SC isn't boosting, just that you aren't hearing it.
Putting the OEM intake tube back on quiets it down a lot. If you make a FWI the right way, it's going to be loud. Rivieras also have better sound insulation, so having the window down makes a difference. Smaller SC pulleys make a slightly higher pitch. If your dad's GTP has the Gen V blower, that's also going to make a difference in sound.
If it rattles at idle, you need a new SC coupler. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Shintsu Expert
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Tue Mar 11, 2008 9:23 am | |
| How much is that gonna cost and how hard is that to replace? | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Tue Mar 11, 2008 9:27 am | |
| $30 + 2 bottles SC oil. I'll admit, it was an afternoon of work for me, but I work slowly. Depending on your level of mechanical aptitude, it could seem easy. You must remove the SC belt, alternator, SC snout, and drain SC oil. The SC pulley can stay on. Metric sockets/ratchet needed. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
dreww Junkie
| Subject: Supercharger Reliability Tue Apr 29, 2008 12:49 am | |
Buapo Addict
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Tue Apr 29, 2008 1:00 am | |
| I've been told by several mechanics that because I had the 3.8 supercharged, that the supercharger was likely to "cause problems" and not last very long. Kiss my ass, who do they think they're talking to?
The Eaton M90 is a quality product, and the tranny will go long before the supercharger (unless we're talking about the coupler... woo-hoo, a $30 part). | |
dreww Junkie
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Tue Apr 29, 2008 1:11 am | |
| - Buapo wrote:
The Eaton M90 is a quality product, and the tranny will go long before the supercharger (unless we're talking about the coupler... woo-hoo, a $30 part). yea, the irony of their statement is kind funny. They tell you that strongest damn component on the car is the weak link. | |
ewolfe0050 Aficionado
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Tue Apr 29, 2008 1:28 am | |
| When I got an estimate for the damage- the "experienced" bodyshop guy mentioned how much he loved working on these Rivs when he worked at an established body shop here in town but the thing he remembered was that our superchargers went out at about 50kmi. 'Tard...Who really thinks the Riv is an easy car to work on!?!? That's probably why you see so many modded Rivs and aftermarket support out there . Strike two- you can drop a M90 on the ground, kick it in mud, spit on it to clean it, and it will still work. | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) | |
