| FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions | |
+39ghpcnm Pipes adri Andysdorm ZEP pix rk0ehn LARRY70GS doct222 lo619 Derek Riv95SC RivieraRyan 95rivy bigdave 60kriv ddonohue DarkVader DEMonte1997 moldymac Blwn Riv Abaddon mechant_loup '96reese Eldo Natesriv robotennis61 woggy Jason AA Mr.Riviera playa albertj Rickw deekster_caddy ewolfe0050 ibmoses captshiner Jack the R 43 posters |
ghpcnm Aficionado
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Sat Apr 07, 2012 7:47 pm | |
| Hmmmm...sounds like it's time for some of the experts to chime in.
How 'bout it fellas? | |
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Sat Apr 07, 2012 10:05 pm | |
| I know shit all about diagnostics but it sounds like a fuel problem.have you taken apart the ignition module? they can get cheesy in winter.take it apart and clean it real good ,spread a little dialectric grease on it and reinstal. check your coil packs too. | |
Pipes Member
Name : Pipes Age : 40 Location : Pa Joined : 2011-12-11 Post Count : 80 Merit : 0
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Sun Apr 08, 2012 12:08 am | |
| just put icm on it and the coils are less than yr old ... it was missing really bad so i switched it smoothed it out than crank sensor came | |
Pipes Member
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Sun Apr 08, 2012 4:38 pm | |
| i changed the plugs and wires this morning right after i did it i the battery died charged it and nothing... but i had another computer for the car in my house i changed it a it came right on.... tomorrow i will putting it on a snap-on to see if anything is wrong... will post ant new finds | |
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Sun Apr 08, 2012 8:40 pm | |
| Do you have spark? If yes, are the injectors firing?
I would be willing to bet you have no spark, or the spark is way off, and you may have a broken wire to the crank position sensor or cam position sensor, or a bad one of those sensors.
What were you doing the last time it ran? Prior to this no-start, was the car running okay?
Is your car supercharged? | |
Pipes Member
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Sun Apr 08, 2012 11:06 pm | |
| it was running ok scanned it it came up with p0316 later that night it cut off while driving .... i did few more times the next day so i changed the crank sensor .... i did everything else but the crank .... had a few codes like 3 months ago but changed and codes went away .... they where knock tps and cam sensor ..... since i changed all that i put icm on a it ran great ... then light came back with crank code changed crank sensor still no start ... then i a ecm swap start with lil miss ... will be scan in the morning but new plugs and wires and still a miss ... im clueless as of this point .... and yeah its supercharged | |
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Mon Apr 09, 2012 12:22 pm | |
| Sounds like you need to verify your wiring harness. The wires have been known to get brittle and break near the firewall connector.
It would help a LOT when looking for help in a car forum to use full sentences and detailed explanations. I don't like to be a grammar nazi, but your description is very hard to follow. I understand most people are using mobile devices, and that's too bad because it makes helping you very difficult.
many times the code thrown does NOT mean you should replace that sensor. It means there is another problem causing that sensor to throw an alert or go out of range. Rarely does the actual sensor go bad. | |
Pipes Member
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Mon Apr 09, 2012 2:21 pm | |
| well i scanned then car this morning and it said that the throttle position is high at first 1000 rev. but the car is running like it was years ago when i first got it. i was looking for a new wiring harness but never found anyone who sold them.
thanks for all the help everybody very much appreciated
BigRay1125 Enthusiast
Name : Ray Age : 55 Location : Pittsburgh PA Joined : 2008-01-22 Post Count : 148 Merit : 5
| Subject: Rough Start & Fluttering @ 60mph Wed Apr 11, 2012 7:05 am | |
| Question #1 : Sometimes When I Start My 95 Riv I get A Rough Start Like It Dont Wanna Stay running & it most Time Cut Off . Question #1 : When Im On The parkway cruising @ 55-60mph I Get A Fluttering In The Motor like its Jerking HELP ME PLEASE | |
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Wed Apr 11, 2012 7:09 am | |
| Have you changed the spark plugs and wires? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Wed Apr 11, 2012 7:16 am | |
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Wed Apr 11, 2012 8:53 am | |
| Check the fuel pressure. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Wed Apr 11, 2012 3:19 pm | |
MFFDVR Amateur
Name : Chris Age : 44 Location : Omaha, NE Joined : 2012-03-06 Post Count : 38 Merit : 0
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Wed Apr 11, 2012 6:41 pm | |
| Had the same symptoms with mine. Fuel pump finally died and it wouldn't start at all. Found a faulty fuel injector, also. | |
rivparadise Fanatic
Name : Samuel Age : 51 Location : Niagara Co. Joined : 2007-06-10 Post Count : 381 Merit : 11
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Wed Apr 11, 2012 9:54 pm | |
| Would also try checking all the grounds. They can cause occasional sputters! | |
hecc Special
Name : hecczilla Joined : 2012-08-09 Post Count : 6 Merit : 0
| Subject: slow start Sun Aug 26, 2012 2:18 pm | |
| when my car is cold it doesnt start right up the engine turns a few times and then i have to press the gas pedal for the car to start up,once car its warm sometimes it starts right away, i changed the fuel filter,MAF sensor,TPS sensor please help..95 buick riviera sc.. | |
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Mon Aug 27, 2012 4:14 pm | |
| - hecc wrote:
- when my car is cold it doesnt start right up the engine turns a few times and then i have to press the gas pedal for the car to start up,once car its warm sometimes it starts right away, i changed the fuel filter,MAF sensor,TPS sensor please help..95 buick riviera sc..
throwing parts at it will cost you a flipping fortune. have to check fuel pressure at the fuel rail schraeder valve and check FP operation in the startup sequence. Could be fuel pump, could be fuel pressure regulator (they last a long time but not forever), could be something else. This is a job for a scanner to read the sensors during the startup sequence. Can you get to one? | |
hecc Special
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Thu Aug 30, 2012 4:17 pm | |
| No I Dont have a scanner...where can i get to one?? thanks for the help.. | |
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Fri Aug 31, 2012 11:38 pm | |
| - hecc wrote:
- No I Dont have a scanner...where can i get to one??
thanks for the help.. Search for "scanner" on this site. You will see some ideas of where other members got their scanners, what model, et cetera. | |
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Mon Feb 24, 2014 9:26 am | |
| Have a no-start issue, came out of the blue. Went to start as I always do. Engine turned over one revolution and then everything is dead. Inserting the key does not activate the accessories, even the remote will not lock/unlock the doors. Lights don't turn on. The car is completely dead.
Battery should be good, as it started the car just fine this morning, so I suspect a bad connection or a fuse. Checking these now. Any other ideas?
EDIT: loose battery terminal. Problem solved. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions Mon Feb 24, 2014 12:28 pm | |
| I was going to suggest loose battery terminal. Your symptoms exactly described it. Glad you found it okay! | |
| Subject: Re: FAQ: Rough / Slow / No Start - Symptoms, Causes, Solutions | |
