| Rear Seat Cushion - What is the secret | |
+4albertj sburch23 Karma Straighteight 8 posters |
Straighteight Member
Age : 89 Joined : 2007-01-22 Post Count : 66 Merit : 1
| Subject: Rear Seat Cushion - What is the secret Tue Jun 30, 2009 6:16 pm | |
| Okay, I give up, how the----- do you put the back seat cushion in place? | |
Karma Aficionado
| Subject: Re: Rear Seat Cushion - What is the secret Tue Jun 30, 2009 6:26 pm | |
| Slide in the back edge first, there are two plastic "things" that slide into two metal brakets along the back. Then just push down the front. If if doesn't go "click" then sit on the seat. _________________ | |
sburch23 Addict
| Subject: Re: Rear Seat Cushion - What is the secret Wed Jul 22, 2009 8:34 pm | |
| When the Moon is in the seventh house And Jupiter aligns with Mars The seat, wont need you to ram it And you, you can rest your arse!
with apologies to the 5th Dimension from the rock opera "Hair"
Seriously, for some reason I occasionally blow the interior light fuse. I now carry needle nose pliers and fuses and can undo the the seat, take the fuse block cover off, remove fuse, replace fuse, put the cover on in 1 minute. Getting the seat cushion back in takes 5 seconds or 15 minutes. There is a technique involved with pushing it in at an angle and then pivoting it down just right so the two plugs on the seat fit exactly in the holes in the support. | |
| Subject: Re: Rear Seat Cushion - What is the secret Wed Jul 22, 2009 11:01 pm | |
| What helps me is looking under the front edge of the rear seat before pushing it down so I mash it down with the heel of my paln right over where it's supposed to clip down. So for me it takes 5 seconds or 10 seconds.
I know one mechanic (Mooch) who can do it reliably and repeatably without looking. The rest have to look or fiddle with it.
EatDirtFartDust Fanatic
Name : The Josh Age : 40 Location : Somewhere between Sullivan and Saint Peters Missouri. Joined : 2009-03-27 Post Count : 284 Merit : 2
| Subject: Re: Rear Seat Cushion - What is the secret Wed Jul 22, 2009 11:18 pm | |
| Have yet to have trouble with this. Had the seat out about half dozen times already. | |
| Subject: Re: Rear Seat Cushion - What is the secret Wed Jul 22, 2009 11:21 pm | |
| - EatDirtFartDust wrote:
- Have yet to have trouble with this. Had the seat out about half dozen times already.
You must know Mooch. Albertj | |
| Subject: Re: Rear Seat Cushion - What is the secret Thu Jul 23, 2009 7:22 am | |
| I start with it tilted up high, and holding the seatbelts up in place. I sometimes tuck the middle longer seatbelt into the armrest to hold that up while I hold the drivers side floppier part in place with one hand. (I look pretty silly while doing this maneuver).
Then just lower the front while pushing back. It slips right in. A good push down on the front after it's lowered and it clicks home.
I think holding the seatbelts up is the key. | |
krazyfish Enthusiast
Name : Jerred Age : 34 Location : Kentucky Joined : 2009-02-20 Post Count : 136 Merit : 4
| Subject: Re: Rear Seat Cushion - What is the secret Thu Jul 23, 2009 11:13 am | |
| The thing ive notice is that just one side is not suffice to hold it in the pressure from the other side will pop it back out.
The way i do it is i stater with one side usually the drivers side of the car and push down and back until you feel it pop in then use your knee to hold that side down while repeating with the other side. It ends up looking like some sort of weird yoga pose but it works.
The easiest wy is to have a freind hold down the first side of the cushion while you work on the second. | |
| Subject: Re: Rear Seat Cushion - What is the secret Thu Jul 23, 2009 2:51 pm | |
| on my car there is a particular problem that is as annoying as hell. the factory carpet has a permanent fold in the carpet that forces me to push down on the offending corner in order to properly position the seat for placement. that sucks. everytime. | |
| Subject: Re: Rear Seat Cushion - What is the secret | |
