1996RIV CALI Amateur
Age : 43 Location : Oakland CA Joined : 2008-07-22 Post Count : 42 Merit : 0
| Subject: leaking power steering fluid Tue Sep 01, 2009 4:21 pm | |
| my power steering fluid did not start leaking until i filled it up, but only leaks after i park it over night. did i fill it up to much and thats why its leaking. it seem to turn ok. any help would be great. | |
| Subject: Re: leaking power steering fluid Tue Sep 01, 2009 4:31 pm | |
| what area is the leak coming from? from the rack? from the pump? otherwise ,clean off the power steering pump and reservoir area real good with hose and chemicals.place paper towels underneath,and next day with flashlight look for leak. could be p/s pump seal. eitherway PIA! | |
| Subject: Re: leaking power steering fluid Tue Sep 01, 2009 4:41 pm | |
| If you had to add P/S fluid, well... it has to be going somewhere, so you must have a leak somewhere else in the system. Normally you don't need to add P/S fluid. It could be anywhere, but a visual inspection of all the steering components should identify the leak. | |
| Subject: Re: leaking power steering fluid Tue Sep 01, 2009 5:46 pm | |
| i put P/S IN because it was low. I think it could be the pump or a hose. in the mourning the fluid is right under the pump. | |
| Subject: Re: leaking power steering fluid Tue Sep 01, 2009 6:29 pm | |
| again,clean all the areas around pump. if you think its a hose clean that area,and check in the morning. if tis coming from behind the pump thats a seal. PIA | |
RhinoFLA Aficionado
| Subject: Re: leaking power steering fluid Tue Sep 15, 2009 12:10 am | |
| I just went through this, mine ended up being a leak from the pump, then it went out. Have you noticed any hickups in the steering?.. If it's the pump, email Ed Morad, I got mine for $39 shipped | |
| Subject: Re: leaking power steering fluid | |
