 reverse lamp bulb replacement
6 posters
reverse lamp bulb replacement Empty
PostSubject: reverse lamp bulb replacement   reverse lamp bulb replacement EmptyMon Jul 09, 2007 11:55 pm
so this should probably go under maintenance/repairs, but this forum gets more traffic.
I breifly looked at the lamp the other day as I need to replacement one that burnt out. How do you get to the lamp to replace it? It was dark, so I didn't look into it too much, but it doesn't appear to be very simple to do. Has anyone here done it yet? And if so, any tricks to it?
PostSubject: Re: reverse lamp bulb replacement   reverse lamp bulb replacement EmptyTue Jul 10, 2007 7:32 am
The only trick is to disassemble the tail light assembly. rolleyes It's not too hard, just time consuming. Be careful not to pinch any wires when you put the assembly back in...and make sure it's going in straight. You have to take all the fasteners off the inside of the trunk across the back side of the tail light.
PostSubject: Re: reverse lamp bulb replacement   reverse lamp bulb replacement EmptyTue Jul 10, 2007 8:52 am
Yeah, a bit tedious, but not difficult. I had to replace a few of the retaining knobs when I had some burnt bulbs, the threads were already stripped, and the GM knobs are not cheap.
PostSubject: Re: reverse lamp bulb replacement   reverse lamp bulb replacement EmptyTue Jul 10, 2007 5:03 pm
Also, you'll want to be careful when you pull the assembly out not to scratch the bumper cover.
PostSubject: Re: reverse lamp bulb replacement   reverse lamp bulb replacement EmptyTue Jul 10, 2007 11:14 pm
If you still have your car manual, the exact steps with pictures should be in there. You basically have to go in the trunk and start to unscrew the hooks that are attached to the black plastic cover. I think there may be some screws on the top to that you will have to remove. Once that is removed you should see how it comes out. Also like it was said above, be careful about scratching your paint when you pull the lamp assembly out.
PostSubject: Re: reverse lamp bulb replacement   reverse lamp bulb replacement EmptyWed Jul 11, 2007 6:31 am
one of my bulbs is burnt out too, when you get your bulb can you let me know what size and type.
You don't really notic it at first when you walk around the car but step away to the distance of a car behind you and you'll see your car looks like a Jack o Lantern oops
I think of it everytime I brake, people must think I drive a real junker lol
SilveR
SilveR
PostSubject: Re: reverse lamp bulb replacement   reverse lamp bulb replacement EmptyWed Jul 11, 2007 7:40 am
We have only 2 types of bulbs in the taillight:
#L3057 for stop and reverse
#L194 for turn, park and license plate
http://www.amavto.ru
PostSubject: Re: reverse lamp bulb replacement   reverse lamp bulb replacement EmptyWed Jul 11, 2007 11:27 am
And the bulb numbers are conveniently listed on the back inside cover of your owners manual, IIRC. Get the LL bulbs, any auto parts store.
PostSubject: Re: reverse lamp bulb replacement   reverse lamp bulb replacement EmptyWed Jul 11, 2007 2:06 pm
You can also find a list of all the light bulbs for our cars on the Riviera FAQ website.
http://rivfaq.bravehost.com/lights.htm
» Front Cornering Lamp Bulb Replacement?
» FAQ: Engine/Transmission Motor Mounts
» Replacement Bulb Part Numbers
» front turn signal bulb replacement
» Transmission clunks when going into reverse
