 p0705 shifter switch
2 posters
Rivieraz
Rivieraz
p0705 shifter switch Empty
PostSubject: p0705 shifter switch   p0705 shifter switch EmptyWed Jun 03, 2020 4:43 pm
is it hard to replace the switch??
Merit : 149
PostSubject: Re: p0705 shifter switch   p0705 shifter switch EmptyWed Jun 03, 2020 7:12 pm
Can't find that code in my 98 FSM.  Googled it,
P0705
Diagnostic trouble code P0705 indicates that the Engine Control Module (ECM) or Transmission Control Module (TCM) has received an input error from the Transmission Range Sensor (TRS). This switch is also known as a pressure switch, Park Neutral Position switch (PNP), the gear selection switch, or a PRNDL input switch.
That should be right on top of the transmission.  Do you have a replacement?
Rivieraz
Rivieraz
PostSubject: Re: p0705 shifter switch   p0705 shifter switch EmptyThu Jun 04, 2020 12:25 am
yes , its in the shop now thanks
Actron CP9690 picked it up as a pnrdl switch ,all the gears on the dash would light up , I had to jiggle the shifter every once n awhile for it to stop, also while in reverse I had to jiggle the shifter for my back up lights to come on , it will be done tomarrow i'll keep everyone posted thanks again
Rivieraz
Rivieraz
PostSubject: Re: p0705 shifter switch   p0705 shifter switch EmptyThu Jun 04, 2020 5:24 pm
got my beast back , all is well in the world now,200,00 dollars later , but that is the cost of not getting your hands dirty.
» same code p0705
» shifter
» Loose Shifter
» shifter help
» Will this shifter fit on our Riv?
