| Write-Up: Installing Boost Gauge | |
+73RidzRiv 1997riv bigdave bmcd9179 stan joshuadalegrimes charlieRobinson Fromano matt270avian Johnny5 al_roethlisberger BKRIV Rod.G ghost88 rk0ehn J. Chris Davis GreenMonster GreenSupreme VJD2 7901mark Snowdog Its a car part now GMFreak8 brmcm15 Hometown Hero L67 Ryan from Ohio LARRY70GS 96Super robotennis61 texasfan010 woggy Rickw Fuzzy rivboy 97rivsc lyonsperformance 1wickedninja SuperRiv07 gliderguy agood1 Karma Chicken deekster_caddy albertj Supercharged blackbart95 99 Riviera 99 IBx1 palermocorey90 mr.19982tone Jack the R 98riv RIVhorsepwr RivMan okiedrifter jimmyriv AA 97rivman RhinoFLA urbsnspices dreww SpaceBar NO 4 EVR Jason TType_Riviera turtleman pwmin jax95riv Mr.Riviera oldsman105 1998 Riv T Riley 77 posters |
Karma Aficionado
Name : Andrew Age : 40 Location : Ontario, Canada Joined : 2008-01-14 Post Count : 1949 Merit : 123
| Subject: temp Fri Nov 15, 2013 11:29 am | |
| Your boost gauge is hooked up wrong or you aren't making any boost. "I hooked up the vacuum line and everything done right but it goes to negative 15psi and when I punch it, it goes to 0psi, so do I need to adjust the needle? And when the needle is off and car is off it goes to 0psi."
If working and hooked correctly you will see the neg(vac), but under load you will see positive boost.
Also post pics of your boost gauge install. Check for BBV movement under the hood when blipping the throttle. Thats the black actuator arm on the SC on the front right when facing you. If you reach over to the TB and give it a solid rev, you should see the actuator extend.
I suspect the not displaying boost and "vtec" thing are seperate issues if you still see no boost under the "vtec" condition. _________________ | |
matt270avian Expert
| Subject: Re: Write-Up: Installing Boost Gauge Tue Nov 19, 2013 8:46 pm | |
| Got mine actually hooked up today (finally). We finished, turned the car on, and revved it. Saw no boost. We were both like "Awwwww F$#@". Then I suggested we go for a quick drive just to be sure. Took it easy to the highway, nothing. Got on the highway, gunned it, needle took off. Think I hit about 11-12 pounds on the shift. Couldn't tell for sure because it was dark and I was watching the road. 34 degrees out. | |
Johnny5 Fanatic
Name : Going Nowhere Fast Age : 38 Location : Louisiana Joined : 2013-09-11 Post Count : 459 Merit : 1
| Subject: Re: Write-Up: Installing Boost Gauge Tue Nov 19, 2013 8:52 pm | |
| Mines on the aeroforce is displayed negative 19.21 but when I put my foot in her I got as high as 6.6 lbs of boost kickass | |
matt270avian Expert
| Subject: Re: Write-Up: Installing Boost Gauge Wed Nov 20, 2013 12:01 am | |
| I didn't have an "L" fitting so I had to make a "T" work..... I want it done right..... Won't be there for long. If you follow the line under the snout back it goes to that "T". One of the ports of it is plugged. Perfect for running a concealed line. Can take more pictures if wanted. | |
matt270avian Expert
| Subject: Re: Write-Up: Installing Boost Gauge Tue May 27, 2014 7:28 pm | |
| Alright, I was watching my gauge today and I was constantly getting 14 psi at the top of first. I seriously doubt that that is correct. Anyone have any explanation besides the gauge being off? | |
J. Chris Davis Aficionado
Name : Chris Davis Age : 43 Location : Dixon, IL Joined : 2010-04-14 Post Count : 1008 Merit : 19
| Subject: Re: Write-Up: Installing Boost Gauge Wed May 28, 2014 9:07 am | |
| How much vacuum do you get at idle? | |
| Subject: Re: Write-Up: Installing Boost Gauge Wed May 28, 2014 9:19 am | |
| - matt270avian wrote:
- Alright, I was watching my gauge today and I was constantly getting 14 psi at the top of first. I seriously doubt that that is correct. Anyone have any explanation besides the gauge being off?
Based on what I see in your sig, that could easily be correct. You've dropped pulley sizes but I don't see anything increasing valve lift, so the air pressure can't get out of the intake resulting in a high amount of PSI in the manifold. If you put something increasing intake valve lift and or duration you'll lower that PSI a bit and improve airflow. The higher your PSI the more heat you are going to create as well. | |
matt270avian Expert
| Subject: Re: Write-Up: Installing Boost Gauge Wed May 28, 2014 8:52 pm | |
| - J. Chris Davis wrote:
- How much vacuum do you get at idle?
Not sure, the gauge only shows boost. That was almost a deal breaker but I decided to stick with it. - deekster_caddy wrote:
Based on what I see in your sig, that could easily be correct. You've dropped pulley sizes but I don't see anything increasing valve lift, so the air pressure can't get out of the intake resulting in a high amount of PSI in the manifold. If you put something increasing intake valve lift and or duration you'll lower that PSI a bit and improve airflow. The higher your PSI the more heat you are going to create as well. Makes sense. I've noticed on the 90* days the gauge will go up to ~200* under really heavy driving (I have a 180* tstat). | |
1997riv Enthusiast
Name : Joined : 2014-11-23 Post Count : 131 Merit : 0
| Subject: Re: Write-Up: Installing Boost Gauge Wed Apr 01, 2015 1:59 pm | |
| Where is the best place to run the line through the firewall? Also, can I run the line right off that plugged port where the brake booster plugs into the intake? Otherwise I might T into the line that runs across the front to the fuel pressure regulator. | |
| Subject: Re: Write-Up: Installing Boost Gauge Wed Apr 01, 2015 2:06 pm | |
| I had to drill a small hole in my firewall and put a grommet in to get all of my stuff fed into the engine bay. If you do this watch out for wires on the other side of where you drill. I have a T on the right side of the motor (firewall) where the line goes from under the supercharger snout and feeds back. | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri Apr 03, 2015 2:31 pm | |
| - stydel311 wrote:
- Where is the best place to run the line through the firewall? Â Also, can I run the line right off that plugged port where the brake booster plugs into the intake? Otherwise I might T into the line that runs across the front to the fuel pressure regulator.
There's a big wire harness pass-through that's fairly easy to get into on the passenger side. I tried to edit this pic with an arrow but it didn't work for some reason.. stupid photobucket. anyway it's where all the wires are coming out of. You remove two flat nuts and then take off the plastic cover. Inside, just remove the one lower foot panel on the bottom of the dash held on by two 7mm screws and you have access. You can add any wiring/hoses you want there without needing to drill anything or use additional grommets and stuff. | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri Apr 03, 2015 2:34 pm | |
| I was not aware of the pass through on the passenger side. Good call! | |
matt270avian Expert
| Subject: Re: Write-Up: Installing Boost Gauge Fri Apr 03, 2015 4:06 pm | |
| If you're going to the door vent with it, I tapped mine into the vacuum line that goes off the passenger side of the LIM, then ran it through the fender to the door harness, then through the door harness boot to the door itself. | |
RidzRiv Addict
| Subject: Re: Write-Up: Installing Boost Gauge Fri Apr 03, 2015 5:47 pm | |
| Dang, the turtle has a clean engine bay and cradle/suspension for a car in Illinois! | |
charlieRobinson Expert
Name : Charlie Age : 39 Location : Knoxville, TN Joined : 2011-05-17 Post Count : 3924 Merit : 31
| Subject: Re: Write-Up: Installing Boost Gauge Sun Apr 05, 2015 6:10 pm | |
| Thanks for that tip, Cody! Ima run my wide band through there. Update: Here is what I found after removing the clip in plastic with tons of foam shield. Looks like a plastic panel with 4 bolts and 2 wiring ports. I can reach the other side of this port panel by peeling back the carpet on the passengers side. Wondering what the best way is to sneak more wiring through there? | |
Sir Psycho Sexy Junkie
Name : Tyler Age : 30 Location : Temperance, Michigan Joined : 2012-06-22 Post Count : 948 Merit : 20
| Subject: Re: Write-Up: Installing Boost Gauge Thu May 07, 2015 8:51 pm | |
| May be covered in here, but has anyone spliced into the cluster dimmer wire so their boost gauge lights up the same as the rest of the gauges? I feel like it shouldn't be hard, I just need to know what wire to splice into.
I've read some control dim by varying resistance to ground, and some by varying voltage on positive side.
If anyone could help me out that would be greatly appreciated! | |
matt270avian Expert
| Subject: Re: Write-Up: Installing Boost Gauge Thu May 07, 2015 9:56 pm | |
| I spliced mine into the lights in the door panel since I put my gauge in the vent that's right next to them. It lights up and dims with the LEDs that are on when the headlights are on. | |
| Subject: Re: Write-Up: Installing Boost Gauge Thu May 07, 2015 10:04 pm | |
| Would you say the level of illumination is close to that of the dash? Does it dim with the dash when you spin the dimmer knob thing? | |
matt270avian Expert
| Subject: Re: Write-Up: Installing Boost Gauge Thu May 07, 2015 10:30 pm | |
| It dims with it, and it's not noticeably brighter or dimmer than the rest of the lights. | |
jbird Fanatic
Name : Jeff Location : Cleveland area Joined : 2013-11-11 Post Count : 368 Merit : 7
| Subject: Re: Write-Up: Installing Boost Gauge Fri May 08, 2015 8:22 am | |
| depending where you are locating the gauge the ash tray light may be a good option to tap into.
Jbird | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri May 08, 2015 9:15 am | |
| Good call! I forgot all those things dim too. | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri May 08, 2015 1:06 pm | |
| Why do you need boost gauge if you are installing tablet and running torque? Kind of redundant? | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri May 08, 2015 1:21 pm | |
| I've had it laying around for a while, and I think it looks kind of cool. And I'm kind of curious to see what torque reads vs what the gauge reads. | |
Name : Scott Location : Macomb, Michigan Joined : 2010-02-24 Post Count : 4316 Merit : 185
| Subject: Re: Write-Up: Installing Boost Gauge Fri May 08, 2015 2:21 pm | |
| I'd take ACTUAL boost over "calculated" any day.... | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri May 08, 2015 2:33 pm | |
| - Abaddon wrote:
- I'd take ACTUAL boost over "calculated" any day....
Kinda my thought. How do scan gauges and stuff even calculate boost? | |
| Subject: Re: Write-Up: Installing Boost Gauge | |
