| Write-Up: Installing Boost Gauge | |
+73RidzRiv 1997riv bigdave bmcd9179 stan joshuadalegrimes charlieRobinson Fromano matt270avian Johnny5 al_roethlisberger BKRIV Rod.G ghost88 rk0ehn J. Chris Davis GreenMonster GreenSupreme VJD2 7901mark Snowdog Its a car part now GMFreak8 brmcm15 Hometown Hero L67 Ryan from Ohio LARRY70GS 96Super robotennis61 texasfan010 woggy Rickw Fuzzy rivboy 97rivsc lyonsperformance 1wickedninja SuperRiv07 gliderguy agood1 Karma Chicken deekster_caddy albertj Supercharged blackbart95 99 Riviera 99 IBx1 palermocorey90 mr.19982tone Jack the R 98riv RIVhorsepwr RivMan okiedrifter jimmyriv AA 97rivman RhinoFLA urbsnspices dreww SpaceBar NO 4 EVR Jason TType_Riviera turtleman pwmin jax95riv Mr.Riviera oldsman105 1998 Riv T Riley 77 posters |
Name : Aaron Age : 46 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18438 Merit : 248
 | Subject: Re: Write-Up: Installing Boost Gauge Wed Apr 25, 2012 1:28 pm | |
| CD holder location might not be large enough to clear the bezels on standard size gauges. Maybe someone can verify if this is the case. It could still be done, but would likely require some customization to the trim. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
Name : Larry Age : 66 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2160 Merit : 149
 | Subject: Re: Write-Up: Installing Boost Gauge Wed Apr 25, 2012 1:50 pm | |
| - BKRIV wrote:
- I have been waiting to see a boost gauge installation in the the cd holder location, so far all I have been able to find is window pillar, door air vent, steering column and ashtray... has anyone done this? I dont like to be the first especially where there are cheap little plastic clips involved.
Why? You would have to cut that whole section off and add a Bezel to house the gauges. Alot more work, plus the gauge location is even lower restricting your view. The gauges in my picture are 2 1/16". Not sure they would fit. The ashtray is ideal IMHO, unless of course you are a smoker.  | |
BKRIV Enthusiast
 | Subject: Re: Write-Up: Installing Boost Gauge Thu Apr 26, 2012 11:11 am | |
| You're right Larry - Your install looks good! I never use the CD tray but realized just yesterday that with a milkshake in the cupholder view would be further obstructed...not a smoker, ashtray is for toll money but may be time for EZ pass. | |
al_roethlisberger Junkie
Name : Al Roethlisberger Age : 54 Location : Sanford, NC Joined : 2013-03-12 Post Count : 960 Merit : 24
 | Subject: Re: Write-Up: Installing Boost Gauge Mon Apr 15, 2013 5:52 pm | |
| Wow, that Aeroforce Interceptor is really a neat product, and a good price at around $250 for what I've seen of it online.
I know you probably don't know this answer, but I wonder if it would work on the OBD "1.5" that the 1995's use. I guess I'd have to ask them.
Very cool.
 | Subject: Re: Write-Up: Installing Boost Gauge Mon Apr 15, 2013 6:24 pm | |
 | Subject: Re: Write-Up: Installing Boost Gauge Tue Jun 25, 2013 7:16 pm | |
| Has anyone found a particular style gauge series that is a close match to the look of the stock instruments?
....or one that is modifiable to match, such as being able to access the needle and paint it white?
I like the drivers door panel location for two reasons: aesthetic, and it sounds like it may boost the air velocity of the remaning vent, which is somewhat weak with both vents.
Al | |
 | Subject: Re: Write-Up: Installing Boost Gauge Tue Jun 25, 2013 7:39 pm | |
| I think most gauges feature a threaded lens, like a filter on a camera. This would let you not only paint the needle, but also install a Riviera themed background insert. I've done this with my Aeroforce gauge, using the typeface "Eurostyle" to match the factory dash lettering:  _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
Name : Codith Age : 35 Location : Villa Park, IL Joined : 2007-02-08 Post Count : 3671 Merit : 140
 | Subject: Re: Write-Up: Installing Boost Gauge Wed Jun 26, 2013 12:55 am | |
- I think most gauges feature a threaded lens, like a filter on a camera. This would let you not only paint the needle, but also install a Riviera themed background insert. I've done this with my Aeroforce gauge, using the typeface "Eurostyle" to match the factory dash lettering:
 daaamn 107mpg?? you got one-ah dem inbreds or sumthin? | |
 | Subject: Re: Write-Up: Installing Boost Gauge Wed Jun 26, 2013 8:51 am | |
| 13 mile neutral coast in eastern MD. Got over 100 MPG for 10 minutes! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
J. Chris Davis Aficionado
Name : Chris Davis Age : 41 Location : Dixon, IL Joined : 2010-04-14 Post Count : 1008 Merit : 19
 | Subject: Re: Write-Up: Installing Boost Gauge Wed Jun 26, 2013 9:06 am | |
| I personally think mine is pretty close. I looked all over and couldn't find one closer to the original style that I liked. I just wish I could have found one with a close to matching needle. | |
 | Subject: Re: Write-Up: Installing Boost Gauge Wed Jun 26, 2013 11:30 am | |
| - J. Chris Davis wrote:
- I personally think mine is pretty close. I looked all over and couldn't find one closer to the original style that I liked. I just wish I could have found one with a close to matching needle.
What make/model gauge did you end up using? Apologies if it is already posted in this thread, but I browsed through all 18 pages and didn't find it or in your sig. Thanks Al | |
 | Subject: Re: Write-Up: Installing Boost Gauge Wed Jun 26, 2013 11:40 am | |
 | Subject: Re: Write-Up: Installing Boost Gauge Wed Jun 26, 2013 11:53 am | |
- I think it was moved to the pillar gauge thread. Here's the link to the thread that it would be in. Let me know if you are wanting more information.
https://rivperformance.editboard.com/t2780-write-up-a-pillar-re-upholstery-guage-pods?highlight=pillar Thanks, the A-pillar install looks very clean. I looked through that thread though, and couldn't find where you identified the make/model of the gauge. I did see the photo, but it is pretty low resolution so couldn't make out the gauge make. Do you recall if that gauge bezel and lens comes off so one could paint the needle without major surgery? Thanks again. Al | |
 | Subject: Re: Write-Up: Installing Boost Gauge Wed Jun 26, 2013 12:10 pm | |
| I was using my old camera then, lol. The gauges came assembled as a whole. I'm not sure if you can take the lens off of those or not. They are both Autometer gauges. Boost gauge is part # 2614 Z-series 2". The oil pressure gauge should be the same Z-series and 2" like the boost gauge with a range of 0-100. I do not have the part number for the oil gauge though. Hope that helps. | |
 | Subject: Re: Write-Up: Installing Boost Gauge Wed Jun 26, 2013 6:45 pm | |
- I was using my old camera then, lol. The gauges came assembled as a whole. I'm not sure if you can take the lens off of those or not. They are both Autometer gauges. Boost gauge is part # 2614 Z-series 2". The oil pressure gauge should be the same Z-series and 2" like the boost gauge with a range of 0-100. I do not have the part number for the oil gauge though. Hope that helps.
Thanks  | |
 | Subject: Re: Write-Up: Installing Boost Gauge Wed Jun 26, 2013 7:02 pm | |
 | Subject: Re: Write-Up: Installing Boost Gauge Wed Jun 26, 2013 7:39 pm | |
| This is the Autometer gauge I used. I just installed the green cover on the back lighting to closer match the Riv's lighting.  | |
Johnny5 Fanatic
Name : Going Nowhere Fast Age : 36 Location : Louisiana Joined : 2013-09-11 Post Count : 459 Merit : 1
 | Subject: Re: Write-Up: Installing Boost Gauge Mon Sep 30, 2013 2:50 pm | |
| I need a good spot to mount my AFG any ideas | |
matt270avian Expert
Name : Matt Age : 27 Location : Frederick, MD Joined : 2012-01-15 Post Count : 2681 Merit : 54
 | Subject: Re: Write-Up: Installing Boost Gauge Mon Sep 30, 2013 3:06 pm | |
Johnny5 Fanatic
 | Subject: temp Mon Sep 30, 2013 3:10 pm | |
 | Subject: Re: Write-Up: Installing Boost Gauge Mon Sep 30, 2013 3:26 pm | |
| It will just keep the gauge cooler, and the left side of the car will be a little warmer. You wont short anything if you wire it correctly. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
matt270avian Expert
 | Subject: Re: Write-Up: Installing Boost Gauge Mon Sep 30, 2013 4:35 pm | |
| I keep plenty cool even with half of the vents blocked off (this coming from the man who wraps up in a blanket in the summer and wears shorts in the winter) | |
Johnny5 Fanatic
 | Subject: Re: Write-Up: Installing Boost Gauge Mon Sep 30, 2013 8:58 pm | |
| [quote="AA"]It will just keep the gauge cooler, and the left side of the car will be a little warmer. You wont short anything if you wire it correctly.[/quote
AA im trying to figure out why my (timing says -22 ) long term fuel 16.9 im trying learn this thing....I like your mounting ideas too that was awesome | |
 | Subject: Re: Write-Up: Installing Boost Gauge Mon Sep 30, 2013 9:06 pm | |
| 16.9 LTFT, if it's (+), means your PCM is maxed out adding fuel to correct a serious lean condition, or it thinks there's a lean condition. A faulty or dirty MAF sensor could cause this. I would not go WOT until you figure this out.
The -22 spark timing means 22º before TDC, which is fine. This number will change a lot depending on how you drive. Should be -25 to -35 on the highway, around -26 when you're cruising around, and between -10 and -15 at WOT. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
Fromano Special
Name : Fromano Age : 62 Location : duncansville pa Joined : 2013-10-12 Post Count : 9 Merit : 0
 | Subject: Re: Write-Up: Installing Boost Gauge Sat Oct 19, 2013 8:14 pm | |
| hi every body . I want to put a boost guage on my97 riv where do I put it what does it hook up to  I hooked up my boost under supercharger with a tee .but still not working .can anybody tell me what I am doing wrong . I fell pretty dumb right now .help me please. thank you f.romano | |
 | Subject: Re: Write-Up: Installing Boost Gauge  | |
