 GV M90 Coming in!!
7 posters
GV M90 Coming in!! Empty
PostSubject: GV M90 Coming in!!   GV M90 Coming in!! EmptyTue Dec 04, 2007 2:57 pm
I just purchased a GV M90 today (including manifold)... early Christmas present for me. It has higher miles than I would like but I could not pass up on price. I won't install until I get the intercooler (hopefully right after the Holidays) and cam so I can do the install at one time. In the meantime, what can I do to the GV to make it more durable/effecient? Coatings? Blueprinting? HP parts? etc... I will be running 2.8 pully, IC, GV, XP cam, plus all the other mods I have done already.
Does anyone have a photo(s) of their intercooler setup? I need ideas on how to mount the IC "radiator".
PostSubject: Re: GV M90 Coming in!!   GV M90 Coming in!! EmptyTue Dec 04, 2007 3:36 pm
I'd have it sent out for port & polish if not already. Look into getting fuel logs rather than rail extenders. W-Body store sells a modified stock rail for around $100. It's always out of stock, though.
PostSubject: Re: GV M90 Coming in!!   GV M90 Coming in!! EmptyTue Dec 04, 2007 3:50 pm
The local guy here has designed fuel logs that work well and I will probably go with his. I did just learn that the only company selling an IC for the GV (ZZP) is in the process of redesigning their setup. Looks like they can not get the original cores anymore (they used to use a modified Ford Probe heater core). They will not have a new design until spring...don't know if I can wait that long but I don't want an IC that I can't get a new core for.
PostSubject: Re: GV M90 Coming in!!   GV M90 Coming in!! EmptyTue Dec 04, 2007 3:51 pm
I am planning on test fitting a intercooler radiator tomarrow.
I'll let you know if it works. It is a radiator out of a 1985 volkswagon Diesel.
I saw it mentioned on ClubGp that it is similar to radiator 4 at zzpperformance which sells it for $99.99 plus shipping .
I don't think it is going to fit but I am going to try anyway.
PostSubject: Re: GV M90 Coming in!!   GV M90 Coming in!! EmptyWed Dec 05, 2007 2:31 am
alittle cutting and anything fits. smile
BillBoost37
Merit : 26
PostSubject: Re: GV M90 Coming in!!   GV M90 Coming in!! EmptyWed Dec 05, 2007 6:20 am
Gv Intercooler $400 santa
http://www.3800pro.com/forum/showthread.php?t=17563
INTENSE is also designing new intercoolers. Both GV and G3. I'm waiting a bit for the new designs and looking at a custom design with a friend. Overall though with a Gen V, the intercooler isn't holding you back much.
I've run a couple temperature tests with a buddy and his Gen 3 running a 3.4" pulley vs a Gen V with 3.2" pulley. The Gen V running a smaller pulley was 80-100F difference in temp externally.
97rivman
97rivman
PostSubject: Re: GV M90 Coming in!!   GV M90 Coming in!! EmptyWed Dec 05, 2007 7:52 am
I must defiantly agree that there is a huge difference in the way the gen 3 and gen v move air. You could easily install the gen v right now during the winter and it will easily amaze you bone stock without hurting the motor (depending upon driver). And then I would opt for one of he new intercoolers come spring time.
urbsnspices
urbsnspices
PostSubject: Re: GV M90 Coming in!!   GV M90 Coming in!! EmptyWed Dec 05, 2007 9:37 am
Hey Ewolfe, dont forget to get a TB adaptoroo.
I used this one:
http://www.wbodystore.com/grandprix/gen-v-throttle-body-adapter-p-167.html
PostSubject: Re: GV M90 Coming in!!   GV M90 Coming in!! EmptyWed Dec 05, 2007 10:44 am
ZZP was showing a sale on TB adaptor kit that included the wiring harness, TB, adaptor, throttle bracket, etc... Of course when I called the sale was over. I think I will go with wbodystore now...
GV M90 Coming in!!
» Fuel smell coming in cabin?
» E-Brake Pedal Not Coming All Of The Way Up
» Noise coming from tranny area
» Rumble noise coming from under hood
» Passenger side heat not coming on
