matt270avian Expert
Name : Matt Age : 27 Location : Frederick, MD Joined : 2012-01-15 Post Count : 2681 Merit : 54
 | Subject: E-Brake Pedal Not Coming All Of The Way Up Wed Oct 09, 2013 12:25 am | |
| Like the topic says, when I release the pedal it doesn't always come all of the way up. It goes far enough to disengage it, but not far enough for the PCM to recognize that it's off. If I kick/pull it up the rest of the way the PCM sees that it is in fact off. There is a couple of inches of play in the pedal when disengaged. It is not difficult to get it the rest of the way up as it moves rather freely. | |
Name : Codith Age : 35 Location : Villa Park, IL Joined : 2007-02-08 Post Count : 3671 Merit : 140
 | Subject: Re: E-Brake Pedal Not Coming All Of The Way Up Wed Oct 09, 2013 2:25 am | |
| Cable system might be stretching/starting to fail. IIRC mine did that for a while before it pretty much completely stopped working. If the brake engages & disengages ok still, just pull it back up that little bit with the toe  | |
llamalor2112 Junkie
Name : Evan Age : 30 Location : Granite Falls, WA Joined : 2012-07-13 Post Count : 852 Merit : 13
 | Subject: Re: E-Brake Pedal Not Coming All Of The Way Up Wed Oct 09, 2013 2:36 am | |
| Mines done this once after the car sat with it engaged for about a week. No problems since thankfully... worried a bit though | |
llamalor2112 Junkie
 | Subject: Re: E-Brake Pedal Not Coming All Of The Way Up Wed Oct 09, 2013 3:30 am | |
| 30mins after I post that, take the girlfriend home in the 91 reatta annnnnd it didn't disengage the e brake the first time around...of course, but reset and disengage again with success haha uncanny | |
 | Subject: Re: E-Brake Pedal Not Coming All Of The Way Up  | |
