 Noise from brake pedal
3 posters
96_Juggernaut
96_Juggernaut
Name : Todd Balestrini
Noise from brake pedal Empty
PostSubject: Noise from brake pedal   Noise from brake pedal EmptyThu Jul 11, 2013 2:29 pm
So as off today the Juggernaut starting making some noise from the brake pedal when it is pressed. She makes the sound like if you to walk on a old creaky wooden floor. can I assume this might be the brake booster? or does she need a little lube somewhere.
PostSubject: Re: Noise from brake pedal   Noise from brake pedal EmptyThu Jul 11, 2013 2:56 pm
Try lubing the linkage with some 3-1 oil, see if it goes away. Worked in my case for a very slight squeak under the dash.
96_Juggernaut
96_Juggernaut
PostSubject: Re: Noise from brake pedal   Noise from brake pedal EmptyThu Jul 11, 2013 3:11 pm
Thanks Aaron, I'll try that.
PostSubject: Re: Noise from brake pedal   Noise from brake pedal EmptyFri Jul 12, 2013 9:53 am
Lithium garage door type lube will work and won't drip. Just on the linkage.
96_Juggernaut
96_Juggernaut
PostSubject: Re: Noise from brake pedal   Noise from brake pedal EmptySat Jul 13, 2013 12:24 am
Yea I unhooked the rod from the brake pedal and put some grease on the shaft than reinstalled the actuator rod. no more noise.
» Signal Relay making click noise after releasing brake pedal
» Brake Light and Chime (ding-ding-ding)
» E-Brake Pedal Not Coming All Of The Way Up
» Vibrations in brake pedal
» Brake pedal clicks
