BillBoost37 Junkie
Location : Enfield CT Joined : 2007-11-28 Post Count : 769 Merit : 25
 | Subject: T stat housing--- o-ring Idea Thu Dec 06, 2007 8:19 am | |
| I'm planning a couple small things this winter to improve upon current items. Not power adders.
To my knowledge the S2 L67 had the paper t stat housing gasket through the end of 99 and in 00 GM stopped using the paper gasket . Many 00+'s that I've seen have a seepage and the fix is to use a bit of RTV on the housing.
What does everyone think about taking an S2 T stat housing and having a machinist bore a slight groove into it to facilitate adding an o ring as a gasket. For those of us that run different stats in summer and winter it theoretically would make changing even easier.
Thoughts, opinions, other ideas? | |
Jason Aficionado
Name : Jason Age : 39 Location : Comox, BC, Canada Joined : 2007-01-23 Post Count : 1378 Merit : 64
 | Subject: Re: T stat housing--- o-ring Idea Thu Dec 06, 2007 10:29 am | |
| for the 63 cents it costs to buy a paper gasket, it isn't worth the hassle. | |
Name : Aaron Age : 46 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18438 Merit : 248
 | Subject: Re: T stat housing--- o-ring Idea Thu Dec 06, 2007 10:57 am | |
| Your idea makes a lot of sense. 2 years ago, I would've really supported this. But Jason makes a good point. When I used to change my T-stat often, I would just pick up a paper gasket for a buck. Oftentimes though, I would be able to reuse the old gasket because I never used RTV - and It never leaked on me. So, in effect, I used that cheap paper gasket in exactly the same way you are suggesting with the O-ring.
However, I do not change my T-stat anymore. After I got the PowrTuner, the 160º was history, so now I run the 180º all year. The idea that a cooler T-stat doesn't work in winter is way exaggerated, imo. It was 5ºF this morning, and my car warmed right up. I have graphed data that proves a 160º and the factory 195º heat up at exactly the same rate.
Still, for those using a 160º in summer, or who don't have the ability to control their fans, this O-ring idea could make some sense. It all depends on if they are having a problem with seeping gaskets, and if they mind coughing up that dollar each time they swap. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
TType_Riviera Fanatic
Name : Rob Age : 40 Location : ohio Joined : 2007-03-05 Post Count : 422 Merit : 0
 | Subject: Re: T stat housing--- o-ring Idea Thu Dec 06, 2007 1:14 pm | |
However, I do not change my T-stat anymore. After I got the PowrTuner, the 160º was history, so now I run the 180º all year. The idea that a cooler T-stat doesn't work in winter is way exaggerated, imo. It was 5ºF this morning, and my car warmed right up. I have graphed data that proves a 160º and the factory 195º heat up at exactly the same rate. It will work perfectly fine,until you start going down the road...i even tried putting card board in front of my radiator...but untill i change stats,i finally had working heat while cruising down the road. | |
BillBoost37 Junkie
 | Subject: Re: T stat housing--- o-ring Idea Thu Dec 06, 2007 1:43 pm | |
| I haven't found a need to use a 160 in the summer. Similar to the electric wp on the car. It's more of a because it is possible than a true need for me.
Seemed like something others may have though about as well. | |
 | Subject: Re: T stat housing--- o-ring Idea  | |
