| In need of some advice for 95 rivi | |
+3jax95riv Brad95Riv heyzelchi 7 posters |
heyzelchi Amateur
![In need of some advice for 95 rivi Empty](https://2img.net/i/empty.gif) | Subject: In need of some advice for 95 rivi Mon Dec 10, 2007 1:24 pm | |
| Ok I have an 95 riv sc I'm not getting any heat or a/c does nor does the front windshield defroster work I'm thinkin that it might be something wrong with the vents,or blower control module, the climate controls works I hear when the heat and a/c active but nothing comes out the vents? | |
![Go down](https://2img.net/i/empty.gif) | |
Brad95Riv Member
![Brad95Riv](https://2img.net/u/3215/30/10/37/avatars/11-73.jpg)
Name : Brad Age : 44 Location : Wisconsin Joined : 2007-01-18 Post Count : 97 Merit : 0
![In need of some advice for 95 rivi Empty](https://2img.net/i/empty.gif) | Subject: Re: In need of some advice for 95 rivi Mon Dec 10, 2007 1:56 pm | |
| Does the blower motor (fan) change speeds when you change the fan speed on the climate control unit? If not, it's probably either a bad blower motor or a bad blower motor resistor. Both of them are located behind the passenger side kick panel. | |
jax95riv Aficionado
![jax95riv](https://2img.net/u/3215/30/10/37/avatars/3-33.jpg)
![In need of some advice for 95 rivi Empty](https://2img.net/i/empty.gif) | Subject: Re: In need of some advice for 95 rivi Mon Dec 10, 2007 7:36 pm | |
| It could be the climate control unit too... | |
heyzelchi Amateur
![In need of some advice for 95 rivi Empty](https://2img.net/i/empty.gif) | Subject: Re: In need of some advice for 95 rivi Mon Dec 10, 2007 10:07 pm | |
| - Brad95Riv wrote:
- Does the blower motor (fan) change speeds when you change the fan speed on the climate control unit? If not, it's probably either a bad blower motor or a bad blower motor resistor. Both of them are located behind the passenger side kick panel.
the blower fans does not come on and the climate control works properly the problem is that it no heat or a/c coming out of the vents at all | |
imaspaceguy90 Special
![In need of some advice for 95 rivi Empty](https://2img.net/i/empty.gif) | Subject: Re: In need of some advice for 95 rivi Mon Dec 10, 2007 10:11 pm | |
| Its your blower motor then, the reason you hear it kicking on is because it is working however the blower motor is not pushing the air threw the vents. | |
![AA](https://2img.net/u/3215/30/10/37/avatars/1-6.jpg)
Name : Aaron Age : 47 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18448 Merit : 252
![In need of some advice for 95 rivi Empty](https://2img.net/i/empty.gif) | Subject: Re: In need of some advice for 95 rivi Tue Dec 11, 2007 12:22 am | |
| A bad blower control module can cause no air to flow, even if the blower is working. In my case, everything worked, but the blower wasn't turning on. I replaced the module with a used one from Ed Morad ($30 I think) and problem was fixed. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ ![frown](/users/3215/30/10/37/smiles/icon_sad.gif) | |
![turtleman](https://2img.net/u/3215/30/10/37/avatars/48-65.jpg)
![In need of some advice for 95 rivi Empty](https://2img.net/i/empty.gif) | Subject: Re: In need of some advice for 95 rivi Tue Dec 11, 2007 12:40 am | |
| I hate to just jump in and take the thread but it seems better than making another one about the same thing.
I've only recently noticed on my 97 that My air blows and its warm and everything but when I switch it to blow in the upper vents instead of the floor, nothing comes out of the upper vents... I don't think on either side of the car. blower is definitely running
So the bottom works and the defrosters seems to work up on top but not a trace of air out of the upper (middle) vents | |
ewolfe0050 Aficionado
![ewolfe0050](https://2img.net/u/3215/30/10/37/avatars/211-6.jpg)
![In need of some advice for 95 rivi Empty](https://2img.net/i/empty.gif) | Subject: Re: In need of some advice for 95 rivi Tue Dec 11, 2007 1:05 am | |
| I thought I read a thread in here that addressed sticking flaps in the vent system. If I find it, I'll send it along. | |
Brad95Riv Member
![In need of some advice for 95 rivi Empty](https://2img.net/i/empty.gif) | Subject: Re: In need of some advice for 95 rivi Tue Dec 11, 2007 9:20 am | |
| - heyzelchi wrote:
the blower fans does not come on and the climate control works properly the problem is that it no heat or a/c coming out of the vents at all I tested mine this way. I located the blower motor, turned the key to the 'On' position and set the fan to high speed on the climate control unit. Then I played with the wires connected to the blower motor. The motor did not do anything. Then I grabbed onto the motor itself and pushed it in various directions (it doesn't move much, but there is some play). I found that when I pushed it toward the front of the car, it worked full speed. When I let go, it either didn't work at all or it worked only at partial speed. I then assumed that the blower motor was the problem, and it was. Of course, had things turned out differently I would have probably had to do more tests (I had a step-by-step list in the service manual but wanted to try my own brand of troubleshooting first). So IMO, if I were you, I'd wiggle the wires around and wiggle the motor around a bit and go from there. | |
![In need of some advice for 95 rivi Empty](https://2img.net/i/empty.gif) | Subject: Re: In need of some advice for 95 rivi ![In need of some advice for 95 rivi Empty](https://2img.net/i/empty.gif) | |
