 Shift Kit Questions
VJD2
BillBoost37
TType_Riviera
NO 4 EVR
urbsnspices
24 posters
Go to page : 1, 2, 3  Next
Shift Kit Questions Empty
PostSubject: Shift Kit....................Transmission Filtter   Shift Kit Questions EmptySun Apr 08, 2007 6:50 pm
?????????????????????Difficulty level????????????????????????/
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptySun Apr 08, 2007 9:56 pm
Transmission filter is easy enough if you've got the tools.
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptySun Apr 08, 2007 10:15 pm
I didn't do my shift kit install, but it looks easy.. if you can do a filter, shouldn't be much problem.
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyMon Apr 09, 2007 4:42 am
dammit - I wish I'd known that when I did my filter!
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyMon Apr 09, 2007 8:43 am
You're not missing out on much. Tuning does more for shifts than the kit. Together they form the best result.
urbsnspices
urbsnspices
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyMon Apr 09, 2007 9:41 am
I would place the difficulty at 46 question marks. study
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyMon Apr 09, 2007 4:01 pm
finger
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyMon Apr 09, 2007 9:31 pm
hey so do u have to drain all of the tranny fluid to do this??
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyMon Apr 09, 2007 9:33 pm
You can't really drain all of the fluid, just what's in the pan.
NO 4 EVR
NO 4 EVR
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyMon Apr 09, 2007 9:51 pm
I don't know if this is the same, but my roommate put in a shift kit for his ZR2 and its like the easiest thing to do. Of course his PCM is easier to acess, but it takes about 5 minutes.
And his kit makes a big difference. On the highest setting its almost scarey. What shift kits do they make that work with the Riv (96?)?
I know his isn't quite the same as what we would use but I am sure its similar.
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyTue Apr 10, 2007 1:33 am
not a damn thing I can find. crappy outdated 4T60's. Even the PT programming doesnt do much of jack for the transmission.
Im thinking a swap is necessary for any real "upgrade" for us in this area. this is all I found http://store.summitracing.com/partdetail.asp?part=BMM-70383&view=2047 and no one has it anymore rolleyes
i found "shift kits" but they only install during a rebuild.
PostSubject: ZZP Shift Kit on a Riviera - anyone tried it?   Shift Kit Questions EmptyThu Jul 19, 2007 2:43 am
I ordered a ZZP shift kit, with intentions on installing it in my '98 Riviera. It only has 58k on it, so I'm a little hesitant on putting it in. I have to change the fluid soon anyway, which is why I was going to do it (seems to be an easy install).
Any thoughts on this? Anyone done it?
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyThu Jul 19, 2007 8:54 am
I know Aaron has a shift kit but I think his is intense. I've heard good things about them but I don't personally have one myself.
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyThu Jul 19, 2007 9:44 am
It's supposed to be easy to install, but I had INTENSE do mine because they had the car up.
Imo, a shift kit works better when combined with a performance PCM program, it will enhance the firm, quick shifts. On it's own, it makes a slight difference, but I felt like it made a "jolt" when shifting rather than actually speeding it up. When you decrease shift time and increase fluid pressure, a shift kit seems to be more effective.
Be aware there are different levels of spring tension available, which determine whether your shifts are better suited for street or track. Not sure how ZZP's compares to the INTENSE, but mine is one of the milder ones I think.
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyThu Jul 19, 2007 8:33 pm
so Aaron, you would say it's a good thing to have with the appropriate tuning for sure?
My next major purchase will be my own powertuner but I'm doing the trans very soon. I figured I'd definatelly use one of the milder tensions in the kit and work with that. If after I do more modding and tuning, see room for improvement, I can always change it in an afternoon.
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyThu Jul 19, 2007 9:30 pm
If you're going to tune, and you like firm shifts, I'd install the shift kit.
TType_Riviera
TType_Riviera
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyFri Jul 20, 2007 11:52 pm
IMO anyshift kit is good..since it increases clutch life,with firmer quicker shifts...which means less slippage an less heat...
PostSubject: Shift kit for 4t60e-hd   Shift Kit Questions EmptyTue Dec 04, 2007 12:30 pm
Anyone know of one?
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyTue Dec 04, 2007 12:41 pm
zzp has one but it's out of stock i guess
BillBoost37
Merit : 26
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyTue Dec 04, 2007 12:50 pm
I've heard of the trans go shift kit and the trans go jr.
Think it was said that on the 4T60 the trans has to come out for the shift kit to be installed.
Merit : 66
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyTue Dec 04, 2007 1:57 pm
Transgo only makes a JR shift kit for the 4T60. Their shift kits are really more of a "fix it kit" because they address problems. It's their "reprogramming kits" that are probably what you are thinking about when you say shift kit (actual increase in performance), but they don't make one for your transmission.
The SK 4T60E-Jr kit
Corrects: Light throttle converter shudder. Contains
hardened pins and “Tuff” accumulator piston seals to
reduce clutch failure due to pin and seal wear, 3rd
clutch seal is self expanding. Includes PWM valve,
lock-up regulator valve & bushings.
It will prolong your trans' life, but will probably yield very little performance-wise.
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyTue Dec 04, 2007 3:26 pm
Yeah thats actually more what im looking for... i kinda like smooth shifts better. And as for dropping the tranny to install it... is that true?
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyMon Dec 17, 2007 9:26 am
yea its true u have to drop the trans, the ZZP kit is available now and the W-body store has a kit as well
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyMon Dec 17, 2007 10:45 am
The shift kit on ZZP and Wbodystore is for the 4T65E. It own't work for the 4T60E.
PostSubject: Re: Shift Kit Questions   Shift Kit Questions EmptyMon Dec 17, 2007 11:43 am
look under grand prix GT they have a 4t60-e
Shift Kit Questions
» Transmission will not shift at all.
» turbo'd 3800 thoughts.
» will not shift into gear
» Shift Points
» Slow Shift
