| Cleaning throttle body question | |
+19robotennis61 ejeraser Derek themanwithsauce Abaddon Eldo RidzRiv Rickw Karma maggot oldsman105 deekster_caddy alkemist pwmin Mr.Riviera urbsnspices NO 4 EVR AA T Riley 23 posters |
maggot Member
Name : Chris Age : 36 Location : Beaumont, TX Joined : 2007-05-01 Post Count : 75 Merit : 0
 | Subject: Throttle body cleaning Tue Dec 22, 2009 3:34 pm | |
| Hey guys, what is the best way to clean the throttle body on my s/c series 1. I know u cant use the cleaner because the stuff will hurt the s/c. I just took the TB off the car and it its horrible gunked in the tb and in the inlett of the s/c. The butterfly valve is covered in it and it is sticking real bad, and takes quite a bit of force to break it loose. Whats the best way to get this stuff off. The hard part looks to be inside the s/c inlet. thanks guys! | |
Karma Aficionado
Name : Andrew Age : 38 Location : Ontario, Canada Joined : 2008-01-14 Post Count : 1949 Merit : 123
 | Subject: Re: Cleaning throttle body question Tue Dec 22, 2009 3:42 pm | |
| If the TB is off the car, I find an old toothbrush and some of the canned TB cleaner does wonders. _________________  | |
 | Subject: Re: Cleaning throttle body question Tue Dec 22, 2009 3:59 pm | |
| If you have the TB out of the car, I'd REMOVE ALL SENSORS, then spray it with BP blaster and let it soak for a few minutes. Then use a plastic brush (or hard toothbrush) and some brake cleaner to make it sparkle like new. Make sure none of that stuff gets near the MAF sensor though. | |
maggot Member
 | Subject: Re: Cleaning throttle body question Tue Dec 22, 2009 4:40 pm | |
| Wow thanks for the help!!!! Ok ive cleaned the MAF with is specific cleaner and ive cleaned the TB. Damn now i have to wait for a gasket, nobody has one! Anybody clean inside the S/C inlet or is it best to just leave it alone? | |
 | Subject: Re: Cleaning throttle body question Tue Dec 22, 2009 4:43 pm | |
| I would clean as much area of the intake that you can reach with a lint free cloth or some of those red or blue disposable shop towels. | |
 | Subject: Re: Cleaning throttle body question Tue Dec 22, 2009 4:45 pm | |
| You should be able to wipe the inlet out with some kind of solvent - brake cleaner or PB blaster on a rag, but don't spray directly in there. If you shoot chunks deeper in you can scratch up the rotor seals. | |
RidzRiv Addict
Name : Greg Age : 30 Location : Wisconsin Joined : 2011-02-07 Post Count : 590 Merit : 17
 | Subject: Can't remove throttle body Wed Mar 02, 2011 5:47 pm | |
| I just bought some throttle body cleaner and a new gasket, but i cant figure how to take the throttle body off ha. I could get the front two bolts, but the last one i couldn't get at because of the black shield that hangs over the throttle body. I would take it off, but it is also connected using that last bolt that i cant get to. How have any of you guys done this? | |
Name : Mark Age : 58 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09 Post Count : 3108 Merit : 104
 | Subject: Re: Cleaning throttle body question Wed Mar 02, 2011 11:03 pm | |
| I'm not a TB expert, but I can tell you that you'll probably get good information if you go into your Profile and fill out your Signature with your year & model, so folks know the specific application... | |
RidzRiv Addict
 | Subject: Re: Cleaning throttle body question Thu Mar 03, 2011 3:33 pm | |
| anybody know what i'm talking about? | |
 | Subject: Re: Cleaning throttle body question Thu Mar 03, 2011 3:49 pm | |
| - RidzRiv wrote:
- I just bought some throttle body cleaner and a new gasket, but i cant figure how to take the throttle body off ha. I could get the front two bolts, but the last one i couldn't get at because of the black shield that hangs over the throttle body. I would take it off, but it is also connected using that last bolt that i cant get to. How have any of you guys done this?
you need to remove that bracket to get to the bolt that's behind it. | |
RidzRiv Addict
 | Subject: Re: Cleaning throttle body question Thu Mar 03, 2011 4:34 pm | |
| Thanks, but how do i take that bracket off? like where is it connected? I must be missing something because this seems like it should be fairly simple. | |
 | Subject: Re: Cleaning throttle body question Thu Mar 03, 2011 4:40 pm | |
| Run your finger along that bracket and follow it. It comes to an end somewhere.......you don't have to totally remove it, you just have to loosen the lower bolt in order to "swing" it out of the way. I think it's connected to the LIM...... | |
RidzRiv Addict
 | Subject: Re: Cleaning throttle body question Thu Mar 03, 2011 5:04 pm | |
| okay thanks a bunch, just trying to clean the throttle body and i want to change the fuel filter soon. | |
themanwithsauce Enthusiast
Name : Chris Joined : 2011-05-24 Post Count : 133 Merit : 8
 | Subject: THrottle body removal issues Fri Jul 29, 2011 9:19 pm | |
| Okay, so I have successfully removed 2/3 of the throttle body nuts that attach it to the rest of the engine. However, the last nut has given me nothing but a massive headache. I finally get a deep 13mm socket to actually access it and now it won;t turn. I'm giving it so much force I'm afraid of either my ratchet or engine mounts breaking first.....I've hit it with osme penetrating oil but it hasn't worked so far....Is there something I'm missing here? It is the nut that also holds the black metal bracket on. | |
Derek Fanatic
 | Subject: Re: Cleaning throttle body question Sat Jul 30, 2011 7:32 am | |
| Its been a few weeks since I pulled the tb off the car but if I remember correctly that stud came out with the nut attached. The hardest part was getting the black bracket out of the way to get to the nut. Might want to try getting the stud out like I did. In my case I didn't use any wd-40 (actually I didn't need one drop of the stuff for some weird reason) but the stud was pretty tight. Maybe try a little bigger socket wrench for added leverage. Good luck! | |
ejeraser Rookie
Name : Eric Joined : 2011-05-26 Post Count : 13 Merit : 0
 | Subject: Re: Cleaning throttle body question Fri Dec 02, 2011 9:38 pm | |
| Did you ever get that throttle body fixed. Was your car idling funy . My car is idling funny and some have told me to try cleaning the throttle body. Where did you get the gasket? I will be in need of one. I also will need a coupler and pully or bearings for my super charge. do yo uknow where I can get those as well. IN need of a repair shop book to . any spot I maybe able to find for a cheap price | |
 | Subject: Re: Cleaning throttle body question Fri Dec 02, 2011 10:22 pm | |
| you can find all the gaskets u need at autozone and others. you have to buy a Riv service manual for your car. you cant maintain your riv without one.Having one doesnt preclude knowing how to use it.I'm a prime example of that.but it will point u in the right direction. pulling the throttle body is easy. 1} remove the air intake. 2)remove bolts throttle body to manifold 3) scrape old gasket.
on the 95,there is a long bracket that goes from the throttle cable plate to the throttle body.its underneath the TB. remove that. and done. 13 mm socket will bail u out of all kinds of trouble on these cars.a long one.
ejeraser Rookie
 | Subject: Re: Cleaning throttle body question Sat Dec 03, 2011 11:16 am | |
| I saw this manual for sale do you think its a good shop manual? Factory print HELM Service MANUAL SET | |
 | Subject: Re: Cleaning throttle body question Sat Dec 03, 2011 12:15 pm | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8542 Merit : 181
 | Subject: Re: Cleaning throttle body question Sat Dec 03, 2011 12:25 pm | |
| - ejeraser wrote:
- Did you ever get that throttle body fixed. Was your car idling funy . My car is idling funny and some have told me to try cleaning the throttle body. Where did you get the gasket? I will be in need of one. I also will need a coupler and pully or bearings for my super charge. do yo uknow where I can get those as well. IN need of a repair shop book to . any spot I maybe able to find for a cheap price
coupler and bearings for sc: darossillc.com that's where I got mine. Albertj | |
ejeraser Rookie
 | Subject: Re: Cleaning throttle body question Mon Dec 05, 2011 10:02 pm | |
| cool thanks I orderd the other day. anyone know good place to order intake gasket, valve covers steel, and valve cover gasket, and a supercharge outlet gasket. Im getting a service engine code P0171 and dealer states is known for the outlet gasket having a vacum leak. | |
 | Subject: Re: Cleaning throttle body question Mon Dec 05, 2011 10:21 pm | |
| - ejeraser wrote:
- cool thanks I orderd the other day. anyone know good place to order intake gasket, valve covers steel, and valve cover gasket, and a supercharge outlet gasket. Im getting a service engine code P0171 and dealer states is known for the outlet gasket having a vacum leak.
monsterpartsonline.com if you want OE gaskets, which I would recommend for this job. | |
 | Subject: Re: Cleaning throttle body question Sat Jun 16, 2012 10:26 pm | |
| Question: when reinstalling the TB, should any RTV be used on the new gasket? It looks like none is required. Anyone have thoughts? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Cleaning throttle body question Sat Jun 16, 2012 10:32 pm | |
| The 95 doesnt specify any.dont know about the S2 ? | |
 | Subject: Re: Cleaning throttle body question Sat Jun 16, 2012 11:08 pm | |
| Thx. I assembled it without using any. Just want to get a 2nd opinion before I drop the engine in the car.
PS - I didn't use any on the supercharger, either. THAT ONE ISN'T COMING BACK OUT! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Cleaning throttle body question  | |
