| Roof Rack? | |
jrocha Enthusiast
Name : John Age : 55 Location : Lisbon, Portugal Joined : 2007-07-12 Post Count : 104 Merit : 0
| Subject: Roof Rack? Mon Mar 03, 2008 9:51 pm | |
| I know I'm gonna get bashed for this question or for even suggesting doing such a thing to a Riviera, but here it goes anyways. Where can I get a roof rack? What model fits our Rivs? I TEMPORARILY need to install a roof rack on my Riv. I'm doing some renovations at my place and need to carry some lumber on top. I have no other vehicle right now and can't have the lumber delivered to my house, so my only solution is to install a roof rack just for that purpose, and then I promise I'll take it off the car as soon as I get home with my building supplies. Thanks, | |
| Subject: Re: Roof Rack? Mon Mar 03, 2008 9:53 pm | |
| If you go to a rental store, they usually have temp roof racks that attach into the door openings. I haven't used one, but they look like they'd work ok. | |
| Subject: Re: Roof Rack? Mon Mar 03, 2008 9:56 pm | |
jrocha Enthusiast
| Subject: Re: Roof Rack? Thu Mar 06, 2008 12:32 am | |
| Thanks guys, I'll look into it. | |
| Subject: Re: Roof Rack? Thu Mar 06, 2008 7:27 am | |
| - 1998 Riv wrote:
- If you go to a rental store, they usually have temp roof racks that attach into the door openings. I haven't used one, but they look like they'd work ok.
Wait, I did too use one once, on our first car, a 92 Corsica... | |
| Subject: Re: Roof Rack? Thu Mar 06, 2008 11:46 am | |
| I used a hybrid roof rack setup I made from old stuff I had laying around. It actually turned out pretty good. I had a Thule roof rack on my '94 Regal, which didn't have any rails. It had a complicated bend to the bracket so it fit inside the top of the door and the door closed over it. I also bought the Thule brackets for the Riv - a very thin piece that slips between the door weatherstripping and the roof. For our cars they recommend some weird extension piece for the rear brackets. I found that the Regal brackets fit quite nicely in the weird roof seam we have, so I use the 'correct' front brackets and the '94 Regal brackets on the back. I had a roof-box and ski racks on this setup with the Thule cross bars and it all worked really well. The best part is, since I only used two of the Thule brackets, I still have two of each bracket left over if somebody else wants to duplicate the setup. I'll try to assemble it this weekend and take some pictures, since I want to do some spring skiing runs. If the Riv only had a trunk pass-through, I would never need a roof rack | |
jrocha Enthusiast
| Subject: Re: Roof Rack? Thu Mar 06, 2008 12:12 pm | |
| I know what you mean about the rear seat pass through. It would be a lot more convevient to just lay a blanket down to not get the interior dirty and then run 'whatever' through to the front. I'm also llokin into a hitch like 'AA' suggested and then al I have to buy is a small utility trailer and taht way I can pull my boat too. Either way works. | |
| Subject: Re: Roof Rack? Thu Mar 06, 2008 5:06 pm | |
| Ask at a dealer. I do not remember which lie of roof racks it is, but there is a line available that has brackets that fit into those channels in the roof. Not sure it's Thule but it is a popular line. Might be THule with different feet.
| Subject: Re: Roof Rack? Thu Mar 06, 2008 10:30 pm | |
| With some modification, a small pass-through is possible. I made one for my subwoofer system. If the sub wasn't there, I could slide my skis into the back seat area from the trunk, through the armrest pocket. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
jrocha Enthusiast
| Subject: Re: Roof Rack? Fri Mar 14, 2008 1:12 am | |
- Another option:
https://rivperformance.editboard.com/exterior-f12/my-latest-mod-riv-is-haulin-now-t2441.htm I took a look at the link. I liked it so I ordered mine too. I think I still might go with the roof rack too though, because I have a Thule box (one of the bigger ones) and it's going to come in handy when I take the boat out for a weekend with the kids and camping. I'm turning my Riv into MPV (only when needed) Thanks for the idea, it's actually pretty good the way it hides under there in a way you can barely see it. Not like some other cars where you can see it a mile away. | |
| Subject: Re: Roof Rack? Fri Mar 14, 2008 3:00 am | |
| It's a really great product. I think you'll like how well it hides under there. I had no idea how stealthy it was, or I'd have done it a long time ago! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Roof Rack? | |
| Roof Rack? | |
