The only thing I would be skeptical about is the difference in weight between the Grand Prix and the Riviera. But, with the 300+ pound difference, I almost wonder if that would lend these springs to be perfect for lowering.
matt270avian Expert
Name : Matt Age : 28 Location : Frederick, MD Joined : 2012-01-15Post Count : 2681 Merit : 54
If you look at the GXP it weighs close to the Riv, plus it's really front heavy so it SHOULD balance out.........
matt270avian Expert
So the front springs fit in the strut. So what. What are you gonna do about rear springs? GP's have struts. Rivs do not. What good is a set of GP springs if you cannot use them all?
matt270avian Expert
I know. However, for the sake of EVERYONE looking for different spring combos and lowering options, front GP springs are useless. No need for people to get the wrong idea and just start buying stuff that won't work.
That is all
EDIT: Modifications specific to your own car, and not for everyone else, should be posted in your own thread, NOT in the FAQ section. People imply things when they read this stuff.
matt270avian Expert
Sorry... Just figured it should go in the lowering springs thread since some people might like a slight rake to their car, raise/lower the rear with the air shocks, find something that works on the Lucerne and adapt it or go completely custom....
matt270avian Expert
Beautifully. It handles amazingly, you can just feel the whole car rotate where you want it to. Ride is a bit firmer but less bouncy. More comfortable because of that IMO.
matt270avian Expert
Figured I would post an update after a few months of use. The ride definitely got firmer as the springs settled it. It's not horrible, comparable to maybe a G35 or Camaro or something. There is a little bit of vibration whenever you accelerate at a medium pace due to the axle geometry not being perfect, but if you take it slow or really hard there are no vibrations. Car handles really well, can keep up with my friends MR2 through the larger and faster turns but through the slow tight turns it just can't compete. No rubbing issues or any other issues so far.
ADDvanced likes this post
ADDvanced Member
Name : ADDvanced Joined : 2024-03-18Post Count : 56 Merit : 4
