| Write-Up: A-Pillar Re-Upholstery & Guage Pods | |
+31stan matt270avian LaFlare denim ghpcnm RoughNecks17 abaucom robotennis61 Derek Rickw Abaddon J. Chris Davis 98riv T Riley DEMonte1997 brmcm15 albertj vendetta SuperRiv07 deekster_caddy turtleman palermocorey90 Mr.Riviera RhinoFLA SpaceBar Jack the R 97rivman dreww jax95riv AA Buapo 35 posters |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Wed Sep 22, 2010 10:30 pm | |
| I stand corrected. Spose I was lookin at it wrong when it was on the bench. Looks good man. It'll look even better when you re-wrap that A-pillar piece  Do you have the P/N's of the pod(s) you used? | |
J. Chris Davis Aficionado
Name : Chris Davis Age : 41 Location : Dixon, IL Joined : 2010-04-14 Post Count : 1008 Merit : 19
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Wed Sep 22, 2010 10:31 pm | |
| Ya I had to put it in after yo u said something. I kept staring at it wondering if I messed it up, lol.
The pods I used are for the last generation Camaro/Firebird and I just cut them down more and more till they looked about right. The pod part number from Summit is ATM-10210.
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Wed Sep 22, 2010 10:36 pm | |
| - J. Chris Davis wrote:
- Ya I had to put it in after yo u said something. I kept staring at it wondering if I messed it up, lol.
LOL  sry bout that - J. Chris Davis wrote:
- The pods I used are for the last generation Camaro/Firebird and I just cut them down more and more till they looked about right. The pod part number from Summit is ATM-10210.
Thx  | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Wed Sep 22, 2010 10:37 pm | |
| No problem. I was due for another test fitting anyway, lol. | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Thu Oct 07, 2010 3:36 pm | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Thu Oct 07, 2010 3:45 pm | |
| Dude, that looks sweet! I'm assuming you sent them to an interior joint to have them upholstered? | |
 | Subject: temp Thu Oct 07, 2010 3:47 pm | |
| Yes I had a local upholster do them for me. Only cost $75 for both pillars. Here's some pics of my interior with the new upholstered A-pillars with gauge pod.  Uploaded with ImageShack.us   Uploaded with ImageShack.us  Uploaded with ImageShack.us | |
DEMonte1997 Aficionado
 | Subject: Stupid question about A-pillar gauge electrical and lighting Sat Nov 06, 2010 1:03 am | |
| I had a buddy help me wire the electrical for my a-pillar gauges a few years ago. The gauges weren't bad but whatever. I have a mechanical boost gauge on top, interceptor gauge in the middle and electric tranny temp gauge at the bottom. The boost and trans temp gauges are both autometer z-series gauges with identical face patterns and bezels. The bottom gauge has always been the brightest in terms of light, whereas the (boost) gauge on top is dimmer... Recently, I noticed the top gauge flickers all the damn time. So I guess the stupid (drunk) question is... I have a wiring issue from the source to the top (boost gauge) that's making the flickering? Or do you think this is something else? lol To sound even more stupid.... possibly because the lower gauge gets juice sooner, the other gauge has always been dimmer because of that? Does that make sense? I like to throw the stupid questions out there to make y'all feel better about yourselves. This is for my Regal, btw. Don't want to rub anyone the wrong way being a non Riv question... Hoping to take that sucker apart tomorrow.. gut the wiring and re-do it all. I don't think it was the greatest job to begin with. :/ | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Sat Nov 06, 2010 7:43 am | |
| Rick, It sounds like the light bulb for the upper gauge has a bad ground. That would explain why it was dimmer than the other gauge, all gauges being equal of course. And would explain the flicker or it just could be a bad bulb or bulb connection.
When you remove them verify the ground wire is good before spending time on the power wire. Just my guess. Also the way the wires are run cannot / should not have an effect on the lower one being brighter all this time, it could just be the gauge itself. You will know more when you remove the gauges and see how good or bad the wiring is. | |
Derek Fanatic
Name : Derek Age : 41 Location : New Jersey Joined : 2010-03-23 Post Count : 255 Merit : 10
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Sat Nov 06, 2010 2:10 pm | |
| I agree with Rick. Check any splices and connections carefully, a bad splice or loose connection could cause the resistence to rise significantly, making the bulb appear duller. It could also explain the flickering as the problem grows worse. | |
Name : Codith Age : 35 Location : Villa Park, IL Joined : 2007-02-08 Post Count : 3671 Merit : 140
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Sat Nov 06, 2010 3:27 pm | |
| Chris, do you have a William Ryan home? I swear your house looks exactly like my parents' house that was recently built.
That gauge pillar is just awesome! | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Sat Nov 06, 2010 3:31 pm | |
| whats up with the vintage gas pump in the background of the photo? | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Sat Nov 06, 2010 5:07 pm | |
| The garage is where the car is parked. There's no house there. The gas pump is fiberglass. | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Sat Nov 06, 2010 7:44 pm | |
| Thanks for the insight guys. Rick was dead on but I also discovered a funny screw up on my end. I have the 5-point LED bulbs in these gauges to match factory lighting as close as possible. The bulb in the trans gauge was slightly different (no doubt a replacement on my end) and I never noticed that it was considerably brighter than the existing one in the boost gauge.  So after re-wiring all the grounds and then replacing the bulb all the gauges match perfectly now with no flickering. | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Sat Nov 06, 2010 7:54 pm | |
| So you had a successful day working on the car. Now you can come to my place and do some gauge install after making a custom pod for me. How does that sound for fun times.  | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Sat Nov 06, 2010 9:08 pm | |
| I certainly owe you Rick but that whole custom a-pillar upholstry thing isn't my strong suit. lol  | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Sat Nov 06, 2010 10:33 pm | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Mon Jul 18, 2011 1:28 pm | |
| Hey Chris, did you basically get a solid 2 gauge holder, trim down the bottom and glue it to the pillar? I kinda want to do a 3 gauge deal myself. | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Mon Jul 18, 2011 2:00 pm | |
| Yes, I used one from a 98-02 FBody. I cut it down alot and then used jb weld to hold it down. then trimmed some plastice pieces to fit in the gaps and usd jb well there to. then sanded to be as smooth as i could. Then had the upholstery guy do his magic. If you do a 3 gauge one it will probably stick out alot. Unless that doesn't bother you. How mine is now the front gauge is about even with my dash pad front. | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Mon Jul 18, 2011 4:48 pm | |
| That sounds like a pain. Out of curiosity, did you try any other vehicle-specific or universal piller inserts out for easier fitment? | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Mon Jul 18, 2011 6:52 pm | |
| I couldnt find any others close enough myself. It did take a little while to get it the way i wanted it. the hardest and longest part was getting it in the right spot, but after i got it glued down the rest was easy. | |
abaucom Enthusiast
Name : Al Baucom Location : Ottawa Ontario Joined : 2010-03-28 Post Count : 225 Merit : 22
 | Subject: 1998 A pillar fabric Thu Aug 04, 2011 5:07 pm | |
| I have read this thread on how-to reupholster the 'A' pillar which is very helpful.
I have same issue, and same color fabric (medium gray ?). Need to reupholster the 'A' pillars. Has anyone found a source for this fabric? Prefer stock fabric. Trying to keep my 1998 Riviera as close to factory stock as possible.
Please understand I am more or less new to this board and just spent a few hours on this helpful site trying to find this information. As I understand it (could be wrong) the 'A' pillar fabric is also foam backed same as the headliner? Is there any source to buy replacement fabric that appears to match the interior headliner?
Reason for my question beside the obvious that my 1998 Rivera needs new fabric on the 'A' pillars. I have a 1998 Riviera, Bright White Diamond (looks pearl), with gray leather upholstery. Inherited the Riviera from my aunt, 2005, it was her 4th white Riviera and I helped her pick out each of four (4) white Riviera's over the decades. Currently my 1998 has 67,500 miles, and I am happy to say I have overly maintained this car, expense is not an issue, still has her red umbrella in the drivers door pocket, and perhaps it is now a garage queen, not a trailer queen. Love my Riviera but currenly driven less than 800 miles per year, since new always garage kept, never been driven in snow (seldom driven in rain), change oil yearly before it goes into winter storage late November. Hopefuly this Riviera will be passed on to future family generations, therefore trying to keep it stock and well maintained.
If anyone on this board can help me find NOS or replacement fabric for the 'A' pillars (gray) your help would be much appriciated. | |
Name : Aaron Age : 46 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18438 Merit : 248
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods Thu Aug 04, 2011 5:25 pm | |
| _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Write-Up: A-Pillar Re-Upholstery & Guage Pods  | |
