| 97 brake/suspension upgrade. update pics pg3 may 22b | |
+8deekster_caddy T Riley albertj AA TonySmooth89 Jack the R Mr.Riviera oldsman105 12 posters |
What color to paint the calipers? | BLACK | | 73% | [ 11 ] | DARK GRAY | | 0% | [ 0 ] | GRAY | | 0% | [ 0 ] | SILVER | | 27% | [ 4 ] |
| Total Votes : 15 | | |
oldsman105 Junkie
Name : Enrique Patino Age : 37 Location : Queens, New York City Joined : 2007-01-24 Post Count : 756 Merit : 10
 | Subject: 97 brake/suspension upgrade. update pics pg3 may 22b Fri Apr 04, 2008 10:19 am | |
| Well the time has come to take care of the suspension on the Riviera. Here is what I have planned
97 Spindle/Knuckle upgrade New strut mounts 97 Front struts Wbodystore GP GXP brakes Front Control arm bushings. Eibach STS springs ________________________________________ Rear shocks and sway bar links are already new. ________________________________________ Now my question is... Is there any accessories I need also. I.e. strutmounts, strut bearings, diffrent size bolts, etc...
I just ant a check list so that when I take it apart I am not scrambling to get a part I need.
Any and all help is " GREATLY " apprecaited.
Thanks guys
Last edited by oldsman105 on Thu May 22, 2008 10:13 pm; edited 3 times in total | |
oldsman105 Junkie
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Sat Apr 05, 2008 10:32 pm | |
| Guess I must be good then.  | |
Name : Matthew Age : 36 Location : Florida Joined : 2007-01-17 Post Count : 4394 Merit : 101
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Sat Apr 05, 2008 11:09 pm | |
| gota give some time to answer...jeez especially if our help is only "greatly" appreciated. is there some fine print involved in our responses?? :razz: are the GXP brakes the 13" package they offer? do you have a 97 right now? strut top mounts wouldnt be a bad idea since you are going to take it all apart anyways. i didnt have the money when i did my struts and now i think i need new mounts/bearings. if it were me i would get the entire setup from a 98 riv. strut top mounts 98/99 (the complete assemble with bearings) KBY GR-2 98 struts STS springs STB if you dont already have it big brake kit and wheels large enough to fit those rotors and calipers. LCA bushing (what make you think you need them?) sounds like a good setup to me (i want all those mods too, but $$ is tight  ) keep in mind you may need to get longer brake lines with that kit. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Sun Apr 06, 2008 12:17 am | |
| 2nd going with the 98-99 stuff so you can use the GR-2's
I wish we could get custom springs made.
I think the W Body Store 13" brake kit comes with longer lines.
I don't know if it's worthwhile to upgrade to 13" though, extra rotating mass and all. I was flipping through some old Motor Trends the other day and FWIW 12" is bigger than what most cars, even performance cars, had back in the day. The 911 was the only car I could find with nearly 12" brakes. Camaro and Mustang were 11" | |
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Sun Apr 06, 2008 12:35 am | |
| i have to agree with Jack on the rotor size. 12" is plenty of stopping power. 12" f-body calipers mated with quality pads/rotors and the tires are the next limiting factor, not surface area of rotor IMO. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
oldsman105 Junkie
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Sun Apr 06, 2008 3:02 pm | |
| I bought the W-body store kit in christmas so Im stuck LOL. Are you guys sure the 98 spindles will work with the 96 control arms? I thought the control arms changed in 98 to a diffrent design. the 17" rims in my sig Should fit the brake kit. STB check (I also have one more to make a rear STB like Jack the R pointed out) LCA bushings looked bad when I had the car on the lift ( car has 176.000 rough miles on it ) Thanks for the help guys  | |
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Sun Apr 06, 2008 5:10 pm | |
| what year is your car? <---- would help to have that in your sig btw  _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
oldsman105 Junkie
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Sun Apr 06, 2008 5:32 pm | |
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Sun Apr 06, 2008 6:03 pm | |
| then you will need the 97+ knuckles  sorry, i thought you had a 97. you can get KYB's for 96's so scratch my comment about swapping things over to the 98 stuff. so to revise my previous post: strut top mounts for a 96 KBY GR-2 for 96 STS springs big brake kit from WBS LCA bushing 5 pt harness to keep you from breaking your rib cage when you hit the brakes for the first time ;lol: _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Sun Apr 06, 2008 6:55 pm | |
| - Mr.Riviera wrote:
- i have to agree with Jack on the rotor size. 12" is plenty of stopping power. 12" f-body calipers mated with quality pads/rotors and the tires are the next limiting factor, not surface area of rotor IMO.
Is there any way of knowing how much tire it takes to make use of a given brake size? | |
oldsman105 Junkie
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Sun Apr 06, 2008 7:01 pm | |
oldsman105 Junkie
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Wed Apr 16, 2008 11:54 am | |
| Update
ordered
97 shocks 97 shock mounts Eibach sts lowerig springs | |
oldsman105 Junkie
TonySmooth89 Aficionado
Name : Anthony Age : 34 Location : Florida Joined : 2007-11-14 Post Count : 2410 Merit : 16
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Tue Apr 22, 2008 9:05 am | |
| are those 13" rotors? Lookin good! | |
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Tue Apr 22, 2008 10:13 am | |
| Look like 12" to me. What brand are they? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
oldsman105 Junkie
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Tue Apr 22, 2008 12:11 pm | |
| Raybestos 12.7 Inch rotor.
I rounded up to 13 | |
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Tue Apr 22, 2008 12:19 pm | |
| - oldsman105 wrote:
- Raybestos 12.7 Inch rotor.
I rounded up to 13  AA ! In your face! | |
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Tue Apr 22, 2008 12:45 pm | |
|  Wow, now there's some stopping power! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8520 Merit : 181
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Tue Apr 22, 2008 3:15 pm | |
| you can now get KYBs for the '98 via RockAuto.com. I did - quite pleased.
12.7" rotors look nice. F-body calipers?
oldsman105 Junkie
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Tue Apr 22, 2008 3:39 pm | |
| The calipers are from a Grandprix GXP. | |
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Tue Apr 22, 2008 3:43 pm | |
| Any plans to upgrade the rear brakes? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
oldsman105 Junkie
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Tue Apr 22, 2008 5:25 pm | |
| Yes. I am currently researching rear calipers from the following cars
PARK AVENUE 2003 - 2005 CADILLAC 2000 - 2005 DEVILLE 1998 - 2004 SEVILLE PONTIAC BONNEVILLE GXP 2004 - 2005
From what I have found so far they have larger rear rotors to our cars
The cars above are G-body or Nearly identical in every way. I am assuming based on looking at the rear calipers on the rivera and how they are secured. That the only way these car have bigger rotors is from a diffrent caliper (the rear spindles are probably the same on all the cars) I am hoping to go to the junkyard in several weeks to measure the rear calipers on at least the cadillacs ( easiest to find) hopefully if they measure right and look like they will bolt up. I'll take them right off the car at the junkyard. | |
oldsman105 Junkie
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Mon Apr 28, 2008 8:56 am | |
| Ok guys Like Aaron asked earlier. What color would you paint the calipers.  I would not like bright colors. Any and all suggestions appreicated. | |
T Riley Guru
Name : Travis Age : 32 Location : Minnesconsin Joined : 2007-02-08 Post Count : 5127 Merit : 10
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Mon Apr 28, 2008 9:23 am | |
| - oldsman105 wrote:
- Ok guys Like Aaron asked earlier.
have them dipped in chrome or just paint them red and be done!  | |
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b Mon Apr 28, 2008 10:06 am | |
| Gloss black. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: 97 brake/suspension upgrade. update pics pg3 may 22b  | |
