 engine harness
5 posters
engine harness Empty
PostSubject: engine harness   engine harness EmptyTue Apr 15, 2008 10:27 pm
im getting a engine harness for free from a 96 riviera, will it for on a 99 GTP motor or do i need to mod it some what? please help asap
PostSubject: Re: engine harness   engine harness EmptyTue Apr 15, 2008 10:51 pm
You will need diagraqms to rewire the tranmisson harness to accept the 4T65E.
PostSubject: Re: engine harness   engine harness EmptyTue Apr 15, 2008 10:55 pm
why cant i build my 4t60e, or would a 4t65e be that much better
PostSubject: Re: engine harness   engine harness EmptyTue Apr 15, 2008 11:19 pm
just do a 4t65e hd........... you'll be a BAMF......... and more relibal twisted
PostSubject: Re: engine harness   engine harness EmptyWed Apr 16, 2008 8:16 am
VVV Replacing 4T60E 11 months after rebuild VVV
A 4T60E does not like the RPMs a series 2 puts out.
Buickman104
PostSubject: Re: engine harness   engine harness EmptyWed Apr 16, 2008 11:41 am
Yup you will never be able to keep the engine (series 2) in its power delivery sweet spot with the 4t60. Pretty much anything slightly above 5700=5800 rpm the trans will be starved of trans fluid.
BillBoost37
Merit : 26
PostSubject: Re: engine harness   engine harness EmptyFri Apr 18, 2008 10:01 am
what year pcm do you plan on using?
I have found that Gm pinouts on the 96/97 pcm's are very different than 98+ pcms.
engine harness
» Engine Wiring Harness Diagrams - Series II SC
» Knocking Sound?
» whats the TAC harness?
» Wire Harness Help
» Help Me Identify a Wire Harness
