| FAQ: Automatic Leveling Control (ALC) Concerns | |
+6799Rivman 1967 - 1997 Riviera gunmetalRED c0reyl dboydakid Lisa P charlieRobinson gmann3001 BigRay1125 Mattwa Coltrain billy1290 AKC GreenMonster J. Chris Davis Derek sqrivi Mike9874 Karma epic612 Robb soulbladexll Snowdog Abaddon BrianEsser ciro307 98inSFl Z-type DEMonte1997 Eldo Allstyle Sweepspear LARRY70GS GMFreak8 Dj Brady ewolfe0050 1995 Riv Ryan from Ohio Rickw No-Lift gliderguy albertj robotennis61 '96reese Jack the R T Riley ibmoses TonySmooth89 ¤DoughBoy¤ 96RIVMANN BillBoost37 1badriv jhodges robertwolf86 TType_Riviera AA 97rivman 1998 Riv dreww clazzicradiorepair bayarearivi 98riv deekster_caddy oldsman105 Mr.Riviera jax95riv NO 4 EVR 71 posters |
T Riley Guru
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri Feb 29, 2008 10:45 pm | |
| - deekster_caddy wrote:
- Hey, how'd you get a picture of my old air shocks?!
NO joke i think those were my old ones too!  | |
Name : Dave Age : 62 Location : In The AZ Oven Joined : 2007-01-17 Post Count : 4502 Merit : 44
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri Feb 29, 2008 11:37 pm | |
Ah, so THAT'S where they were before someone put them on my car...  | |
Name : Aaron Age : 46 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18438 Merit : 248
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon Mar 17, 2008 10:17 am | |
| Anyone know where I could find some kind of coupler or connector to patch the plastic air lines for our ALC system? I pinched one of mine under a bolt and want to cut out the section and reconnect.
Thx _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon Mar 17, 2008 10:37 am | |
| I have "hose menders" here. Polypropylene piece, slips into the 2 pieces of hose/tubing you're putting together. Should be able to find at a good hardware store. Do you know what inside diameter the tubing is? | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon Mar 17, 2008 10:44 am | |
| I have them for tubing as small as 1/8", 3/16", 1/4" inside diameter. | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon Mar 17, 2008 11:10 am | |
| Those lines are really tiny, probably 3/32"-1/8" ID. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon Mar 17, 2008 11:12 am | |
| Unless you're in a hurry, I could mail you a couple today, no charge. Let me know. | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon Mar 17, 2008 11:18 am | |
| No hurry. I have some of the line at home. I'll measure tonight and let you know.
I wonder if heat shrink tubing would work? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon Mar 17, 2008 12:22 pm | |
| maybe, but I wouldn't trust it for long | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Mar 19, 2008 2:00 pm | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Mar 19, 2008 4:29 pm | |
| Aaron, we also sell compression fittings for air tubing. I have an assortment, and they are sized per the OD of your tubing. I "should" have a coupling, and you simply push the tubing in on each side. How much tubing do you need to cut out of your line? | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Mar 19, 2008 4:34 pm | |
| Smallest I stock is for 1/4" OD tubing, probably too big? They are available in 3/16 and 5/32 OD also, but I'd have to order. | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Mar 19, 2008 4:41 pm | |
| I don't need any line extensions, have plenty of length to work with. I need something to couple two pieces together. I think the OD is around 2-3 mm. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Mar 19, 2008 4:47 pm | |
| Right, that is what the compression coupling will do. But 2-3 mm, well I don't know about something that small in a coupler. Seems to me the hose mender inserts I mentioned earlier would be your best bet, if you don't want to just replace the whole line. | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Mar 19, 2008 4:49 pm | |
| I'd be happy to mail you a couple of my smallest hose inserts to try out. They fit approx 1/8" ID tubing. Just PM your address and I can mail today still. | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Mar 19, 2008 4:50 pm | |
| I just replaced the whole line, so don't want to do it again. There's no leak, it just got squished under a big nut when I installed the hitch. I don't want to unbolt that either.  I know there are connectors out there. The ones in the previous link seem to be the right size. PM sent. I will try them out. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Mar 19, 2008 5:00 pm | |
| I'm going to take a quick look at my lines. | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Mar 19, 2008 5:03 pm | |
| Sorry Aaron, no chance of a fit. My 1/8" insert is larger than the tubing OD. That is some small hose! | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Mar 19, 2008 5:08 pm | |
| I think they made them really small so the pump can inflate the shocks very fast. I may just look for something at the local hardware store. Thanks though for checking! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Mar 19, 2008 5:12 pm | |
| Hey, found something else here. I have a plastic air fitting, that screws tight on each side to hold the tubing, and they work very well. This is made for 1/8" OD tubing, which is about 3mm OD. I'll bet this will be perfect. | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Mar 19, 2008 5:29 pm | |
| If you have two, send them! Maybe they'll work. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Mar 19, 2008 5:33 pm | |
| One already on the way, will send 2nd tomorrow, gotta run! | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri Mar 21, 2008 2:54 pm | |
| Dave, this works perfect! I saved a few scraps from the line kit, and tested your coupler. It fits just right, and once you tighten the ends, you cannot pull the hose out. I did not need the small black piece you included. When the other arrives, I will be fixing the lines on the car. Thanks so much!
P.S. may want to make a note of the part number for the white coupler, for future reference. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri Mar 21, 2008 3:12 pm | |
| 1182  We always have them in stock, but I didn't think of that option at first, was only looking at push-in compression fittings. Sorry, I didn't send a 2nd one yet, will do it today. Is one more all you need? | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri Mar 21, 2008 3:13 pm | |
| Feel free to add it to the part # FAQ if you want, as a line repair part. | |
 | Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns  | |
