| My 1998 SC Rivera | |
+4269GSColorado charlieRobinson crlombardi69 nothincame2mind jimmyriv florence_x BMD VJD2 stan deekster_caddy IBx1 Jack the R jonly turtleman DEMonte1997 KillaKeninaRiv ZEP robotennis61 flyineagle96 Turbocharged400sbc 71stagegs 1995 Riv Ship curious riv Rickw ericde manofmany dscott2000 palermocorey90 oldsman105 ewolfe0050 Rivster CeeKay racinfan jax95riv NO 4 EVR T Riley Mr.Riviera 98riv Andysdorm 1998 Riv AA 46 posters |
palermocorey90 Expert
Name : Corey Age : 34 Location : Rome NY Joined : 2007-10-03 Post Count : 2968 Merit : -24
| Subject: Re: My 1998 SC Rivera Sun Jan 18, 2009 5:59 pm | |
| - Rickw wrote:
- Aaron,
In your Cardomain site you mention the color as being Slate Green Metallic. How can I find out what they call the color of mine? It is a green metallic color and I can get the paint code from the trunk, then how do I cross reference to what GM calls that color? send me ur paint code i will get the name for you | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 11:36 am | |
| So I got an early birthday present yesterday. First investment I've made in the car in quite a while. Waiting till spring to put these babies on: Once again, craigslist FTW. Enkei hyperblack 5-spokes from '06. Found them in northern KY for $500 including a half worn set of Potenza RE050A Y-rated tires ($226 ea at TireRack!), indicating these wheels were probably only run in the summer. Rims are in 90% perfect condition. The plan is to run these tires bare at my first few autocross events in the late spring, then mount some less expensive 245/45/18s for summer duty. Snow, you can go away at anytime... Here's a photochop of what I'm hoping for: _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^
flyineagle96 Junkie
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 11:57 am | |
| they will look sweet nice find[ | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 12:14 pm | |
| That looks sick! especially with your paint color and yellow F-bodys. How much do they weight? i'm still not sure i believe our stock wheels are 28lbs, but i have no way to prove otherwise. most 18's are 23-25lbs. and to whomever weighed a stock wheels which style was it? i've held the 12 spoke aluminum ones and they feel very light. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 12:36 pm | |
| Thanks! Each wheel weighs 22.2 lb, and each tire will weigh 27 lb ea (current tires are 28 lb each). Total est weight will be ~ 49.2 lb per wheel, so I can believe our stock chrome wheels + tires are well over 50 lb. I'll weigh mine when I take them off. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 12:56 pm | |
| What are the spec's on the wheels? I'm assuming they are 18" dia. | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 12:59 pm | |
| 18" x 7.5" with 5 x 114.3 bolt pattern, 45mm offset. My only real concern is the offset being too much, although TireRack sells 18" x 7.5" wheels for our cars with this offset. If I run into clearance issues with direct mounting, I will probably go this route: http://adaptitusa.com/5x115to5x450wheeladapter.aspx The 1" spacer would push the wheel out, resulting in a 19.6 mm effective offset. It would also correct the bolt pattern to a true 5 x 114.3 mm. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^
T Riley Guru
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 1:53 pm | |
| your wheel game is proper. | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 2:11 pm | |
| Thanks, brah. Good to know the wheels are cool with the young cats! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 3:23 pm | |
| nice find! my new ones are gathering dust in the garage,i just cant see myself putting them on my unfinished riv? gotta wait till the fresh paint goes on or ill look like the ricers with a $1000 set -o- wheels on a $300 car??not nice | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 3:26 pm | |
| I agree, I would wait until the new paint. My car has a few scratches, but still looks presentable when it's washed up. I'll need to fix those yellowed corners, I guess. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
ZEP Fanatic
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 6:17 pm | |
| Those rims should look beautiful on there. They should make the paint look even nicer. It sounds like you got a good deal too. | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 6:28 pm | |
| AA wrote: tire will weigh 27 lb ea . ??? what kind of tires are those that weigh more than the rim?? | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 7:43 pm | |
| What are the two different bolt patterns on these wheels. I notice that on a lot of wheels but never inquired about it. Also, for what it's worth, I think you should go with a silver or black caliper to blend in with the wheels. Just my opinion. | |
ewolfe0050 Aficionado
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 8:28 pm | |
| Nice find AA. Those would look great on your car. Let me know when the autocross event comes- I don't live too far from you... | |
T Riley Guru
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 9:00 pm | |
| - ewolfe0050 wrote:
- Nice find AA. Those would look great on your car. Let me know when the autocross event comes- I don't live too far from you...
you know i'd prolly track my way down too if we got a few riv's to go | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 9:07 pm | |
| I'm still confused bout the weight of your tires?? a tire weighing 27 lbs?/ am i missing something? | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 10:19 pm | |
| For our stock wheel size, a 225/60R16 tire weighs between 22-28 lb, while a 245/45R18 weighs between 27-30 lb. I think with a lower profile tire you have less variance, because the different sidewall thicknesses don't effect the overall weight as much. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 10:30 pm | |
| no way! when i pick up my crap cumho it dont weigh as much as my rim! no way! | |
| Subject: Re: My 1998 SC Rivera Sun Jan 10, 2010 10:33 pm | |
| I think we need a video "Weigh Off" | |
| my bfg traction t/a's weight in a hair over 25lbs. 225/60/16 tirerack.com shows weights of tires btw. here is what Aaron has...i think _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: My 1998 SC Rivera Mon Jan 11, 2010 4:36 am | |
| The issue is not that tires are heavy, it's that the OEM chrome rims are. My tires aren't outweighing the rims, the new rims are light, making the tires seem heavy. Although economy tires do weigh less because the side walls and tread patterns are leaner than on a performance tire. - Quote :
- What are the two different bolt patterns on these wheels. I notice that on a lot of wheels but never inquired about it.
Rick, the other pattern is 5x100mm, which makes these wheels kind of a universal fit with many popular vehicles. I don't like the look of the extra holes, but it helps if/when I should want to sell them. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: My 1998 SC Rivera Wed Apr 07, 2010 10:30 pm | |
| Well, got two of the new rims on the car tonight - mounted fronts for testing. They fit perfectly using the hub centric rings, which I finally got from a vendor other than 1010Tires. I got the incorrect size from the first vendor, so I found another set of aluminum rings on eBay. Lugs lined right up with the holes. I used a torque wrench to cross-tighten them at 10,15, 25, 35, 45, 55, 65, and 75 lb-ft. I know, mucho overkill, but I wanted to give these rims every chance to be exactly centered. Even with just the two on the front, I noticed a nice change in the handling. Vibration was minimal to nonexistent, although more than a few people told me you can't mount 5x114.3 wheels to a 5x115 hub. Can't wait to put the rears on! One thing I did notice about the wider 8.5" wheels and tires, it makes the steering shudder more pronounced. I may finally need to upgrade to the larger trans power steering hoses to correct the problem. The tires that came with the wheels, Bridgestone Potenza RE050-A are an expensive tire, and have a lot of positive reviews in regards to handling performance. I might agree, but I will also say they are noticeably louder than my OEM size Firehawk Wide Ovals, which I felt were a fairly loud tire. To read about the unexpected result of mounting only the two front wheels, see my post in the TC thread: https://rivperformance.editboard.com/brakes-suspension-f6/anti-lock-brakes-and-traction-control-ses-light-t161-150.htm#106518_________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^
| Subject: Re: My 1998 SC Rivera Wed Apr 07, 2010 10:50 pm | |
| So, to clarify you used just the hub centric aluminum rings and not the complete adapters with flanges and studs, is this correct.?
And, just so you know you mentioned replacing the Trans lines instead of Steering hoses. Just an FYI | |
| Subject: Re: My 1998 SC Rivera Wed Apr 07, 2010 11:22 pm | |
| did you notice any difference in the weight of the new rims/tires? that was one of the first things i noticed was my power after 60mph was less due to more weight, and further from the center. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: My 1998 SC Rivera | |
