Recently there was a thread at 3800 pro about head gaskets. Fel pro's should probably treat you right.
GM for the LIM's (aluminum frame)
Valve covers, I've yet to have a fel pro leak on me.
You can save a pile of money usually by getting the fel pro "lower conversion set" for the year you plan to make your motor into. All the gaskets are the same except the oil pan depending on year/make. But you'll do fine ordering for a 97 Riv unless you are going with the aluminum Bonne oil pan for the cool kid factor.
Lower conversion has front and rear main gaskets, front and rear cover gaskets, cam sensor o ring, water pump ghasket , oil pick up tube gasket, oil pan gasket, oil dipstick tube gasket, and drain plug gasket. Not sure what list is..but my cost is usually $45ish.
