| LIM Gaskets | |
| | Author | Message |
T Riley Guru
| Subject: LIM Gaskets Wed Apr 02, 2008 10:00 pm | |
| i need to replace my LIM gaskets..................... does anyone know if a bad LIM gasket will cause coolant to go into the cylinder bank.........>??????? i have white exhaust | |
| | | dreww Junkie
| Subject: Re: LIM Gaskets Thu Apr 03, 2008 12:42 am | |
| - 98riviera98 wrote:
- RhinoFLA wrote:
- I popped my hood yesterday and noticed some coolant on the block. I've been smelling a hint of it when I get home from my hour long+ drive, and I suppose that's why. The temperature as been normal, going over 200 slightly at a stop, but that's about it. I would take pictures but my camera isn't here at the moment, where should I check for leaks?
i need to replace my LIM gaskets..................... does anyone know if a bad LIM gasket will cause coolant to go into the cylinder bank.........>??????? i have white exhaust yes, what does your oil look like? | |
| | | T Riley Guru
| Subject: Re: LIM Gaskets Thu Apr 03, 2008 12:44 am | |
i need to replace my LIM gaskets..................... does anyone know if a bad LIM gasket will cause coolant to go into the cylinder bank.........>??????? i have white exhaust yes, what does your oil look like? a little black....... why do you ask just curious what i should look for | |
| | | dreww Junkie
| Subject: Re: LIM Gaskets Thu Apr 03, 2008 12:46 am | |
i need to replace my LIM gaskets..................... does anyone know if a bad LIM gasket will cause coolant to go into the cylinder bank.........>??????? i have white exhaust yes, what does your oil look like? a little black....... why do you ask just curious what i should look for the LIM gasket is notorious for failing, partially because the gasket (stock) sucks and partially because you got an aluminum intake mounted onto iron block and heads. different metals heat and expand at different rates which leads to problems like this. a leaking LIM gasket and cause coolant to mix with the oil, but its usually obvious because the oil will have a foamy or milky appearance. | |
| | | T Riley Guru
| Subject: Re: LIM Gaskets Thu Apr 03, 2008 12:54 am | |
a leaking LIM gasket and cause coolant to mix with the oil, but its usually obvious because the oil will have a foamy or milky appearance. thanks man! i maybe doing a Ported blower and lower intake while i do the lower intake mani gaskets | |
| | | Jason Aficionado
Name : Jason Age : 41 Location : Comox, BC, Canada Joined : 2007-01-23 Post Count : 1378 Merit : 66
| Subject: Re: LIM Gaskets Thu Apr 03, 2008 1:05 am | |
| | | BillBoost37 Junkie
| Subject: Re: LIM Gaskets Thu Apr 03, 2008 8:02 am | |
| White exhaust (when the engine is up to temp) would signify moisture or coolant in the exhaust system or cylinders. The reason i say it this way is ...condensation is common in our exhausts and unless the car is run good each day you can see some of that condensation as steam when the exhaust heats up.
LIM gaskets are also prone to failure as mentioned, although it's not uber common for them to fail from coolant port to intake or oil ports. They'll look horrible, but usually not cause a large issue. First thoughts on it pooling would be that the coolant is pushing up a bolt thread onto the manifold. | |
| | | Sponsored content
| Subject: Re: LIM Gaskets | |
| | | | LIM Gaskets | |
Similar topics | |
