 totally random intercooling idea
BillBoost37
TType_Riviera
7 posters
totally random intercooling idea Empty
PostSubject: totally random intercooling idea   totally random intercooling idea EmptyThu May 15, 2008 5:44 pm
Has anyone heard or seen anyone using a refrigerated intercooling (pumping refrigerant through liquid heat exchangers instead of coolant?
This is just a thought and I've never really seen it done at all so I was wondering if anyone else has. Certainly the a/c compressor takes a sizable amount of mechanical power from the motor but imagine how cool you could get a charge to be. The air coming out of the blower would be like beading up into droplets as its going into the LIM! jk but you know what i mean
TType_Riviera
TType_Riviera
PostSubject: Re: totally random intercooling idea   totally random intercooling idea EmptyThu May 15, 2008 10:19 pm
the newer porsche 911's run the fuel through a little canister cooled by the AC to cool the fuel...
BillBoost37
Merit : 26
PostSubject: Re: totally random intercooling idea   totally random intercooling idea EmptyFri May 16, 2008 7:27 am
I've heard it discussed before...but don't remember much.
Buickman104
PostSubject: Re: totally random intercooling idea   totally random intercooling idea EmptyFri May 16, 2008 8:22 am
The Ford Lightnings use their AC refrigerant lines to intercool the truck.
PostSubject: Re: totally random intercooling idea   totally random intercooling idea EmptySat May 29, 2010 5:15 pm
Another idea...
Anyone ever run something like this: Link as the coolant in an I/C, instead of normal coolant? Redline sells little bottles of the additive but if anything, I'd be looking to run a full on premix like that. I'm thinking about my coming I/C system and how to maximize the effectiveness of the SSIC setup I'll be building for Manny soon. We upgraded the FMHE to zzp's stage 2 and honestly I'm not even sure what kind of pump it is we got with the package but it closely resembles a bosch.
totally random intercooling idea GetAttachment
That's the only pic I have of it right now.
PostSubject: Re: totally random intercooling idea   totally random intercooling idea EmptySat May 29, 2010 10:40 pm
Devin and i used it in the regal when we changed out the I/C fluid.
I use the stuff in my car (WW+ 70/30 water/glycol mix) and i will say that i see cruse temps around 177* with a 180 t-stat. i like the stuff, but i wouldnt go so far as to call it amazing or even a noticeable change in the I/C efficiency. But then again i'm not able to monitor that coolant temp or blower output temp.
I'd use a bottle of WW ($10) + H20 + some coolant (helps with reducing friction on pumps, and prevents I/C freezing if you live somewhere besides FL)
Every little bit helps i guess...
totally random intercooling idea Dsc_0110
PostSubject: Re: totally random intercooling idea   totally random intercooling idea EmptySun May 30, 2010 12:21 am
Using a larger IC radiator should increase the cooling effectiveness. You can also spray water on the radiator for even more cooling.
PostSubject: Re: totally random intercooling idea   totally random intercooling idea EmptySun May 30, 2010 2:51 am
Nissan Skyline R34 GTR Z-Tune has fuel coolers on the rear?
totally random intercooling idea Ztune05081600
Uploaded with ImageShack.us
totally random intercooling idea Ztune05muffler1600
http://chrisnz.com/nissan-nismo-skyline-gt-r-r34-z-tune/
» GOOD IDEA:fwi/air intake,BAD IDEA:fender delete/H20 intake
» intercooling?
» Looking for a extrememly random part
» Transmission Shudders... Easy Fix?
» Possible to rebuild/restore one totally?
