dreww Junkie
 | Subject: autometer gauge failure Sun Jun 08, 2008 11:29 pm | |
| anyone ever had an autometer gauge fail or know someone who has? ff so, what kind and what model (pro-comp, sport-comp, etc.) it was?
I think my boost gauge just crapped .out. Actually, I think its BEEN going out. I always blamed the hose pinching/breaking (and it did a few times) but now its completely failed. | |
TonySmooth89 Aficionado
Name : Anthony Age : 34 Location : Florida Joined : 2007-11-14 Post Count : 2410 Merit : 16
 | Subject: Re: autometer gauge failure Mon Jun 09, 2008 12:04 am | |
| No i've never heard of that. So you think this is the cause of your low boost readings? | |
97rivman Fanatic
Name : alex Age : 37 Location : Crete,IL Joined : 2007-06-09 Post Count : 484 Merit : 2
 | Subject: Re: autometer gauge failure Mon Jun 09, 2008 12:05 am | |
| if it reeds vacuum and not boost, u have a pinched line somewhere. i have a pro-comp and when i thought it was going out, the engine blew, but it works fine now. i have the procomp model | |
dreww Junkie
 | Subject: Re: autometer gauge failure Mon Jun 09, 2008 6:18 pm | |
| - TonySmooth89 wrote:
- No i've never heard of that. So you think this is the cause of your low boost readings?
no, fixed the boost problem. Hitting in the low 10's PSI. - 97rivman wrote:
- if it reeds vacuum and not boost, u have a pinched line somewhere. i have a pro-comp and when i thought it was going out, the engine blew, but it works fine now. i have the procomp model
i found my compressor in my garage and hooked it up... it does work. It not a vac/boost gauge, just boost. (didn't know any better at the time). I think it simply cannot work in the a-pillar because the hose will kink no matter what I do. The fitting on the back of the gauge touches the a-pillar, kinking the line. might have to switch out with one in my center console. hmmm, probably the scangauge now that I think about it. | |
 | Subject: Re: autometer gauge failure  | |
