| 1997 Riviera Questions | |
+5BillBoost37 AA Buapo deekster_caddy riviera2454 9 posters |
riviera2454 Enthusiast
 | Subject: 1997 Riviera Questions Sat Jul 26, 2008 6:15 pm | |
| I know these questions may sound basic but I am curious for the answers. I am buying a 97 riv it has 132k on it. I do not know what has been to it previously. The car does run very well. I am however wondering if there is anything I should have done to it when I get to avoid future problems. | |
 | Subject: Re: 1997 Riviera Questions Sat Jul 26, 2008 6:50 pm | |
| basic tune-up, plugs, wires etc. change all fluids, don't forget about changing the supercharger fluid. (is it supercharged?)
Otherwise they are pretty good. | |
 | Subject: Re: 1997 Riviera Questions Sat Jul 26, 2008 7:05 pm | |
| yes it is supercharged the service manger at the dealer looked at it and said the the sc is in good shape. He said he sees them with bearings going out but said the one on my car sounded real smooth. | |
Buapo Addict
Name : Ben Age : 37 Location : Eastlake, OH Joined : 2007-07-17 Post Count : 691 Merit : 2
 | Subject: Re: 1997 Riviera Questions Sat Jul 26, 2008 9:14 pm | |
| Heh. You know, it's funny. Lots of mechanics and dealer service shops and the like really like to talk AGAINST our supercharged configuration. According to them:
1. Oh, those supercharged, you gotta watch out - they'll go out on ya. 2. That supercharger is expensive to fix, watch out. 3. You should buy this extended warranty... if that supercharger goes out, that'll be a LOT of money. 4. This supercharged car doesn't get that great of gas mileage.
Is it just me or is the supercharger one of the more RELIABLE elements of our car? Change the fluid? Good. Maintenance after that... uh.... enjoy added power?
Yeah, the coupler goes bad. But there's a special replacement part for that, and it's a fairly simple operation. No problems there.
All right, this was kind of rant. It was sort of relevant. Just don't worry about the supercharger unless it's broken - and of course, like Derek said, change all those fluids, the SC oil included! | |
 | Subject: Re: 1997 Riviera Questions Sat Jul 26, 2008 9:22 pm | |
| I actually got the excat opposite from the dealer on the supercharger. He told me that the LIM gaskets and such are alot better than in an N/A motor. My list so far includes these items if you can think of anything else add it
plugs wires air filter fuel filter pcv valve battery | |
 | Subject: Re: 1997 Riviera Questions Sun Jul 27, 2008 1:40 am | |
| Front struts and rear shocks. Check belts.
The blowers are near indestructible. You really have to let it go to see one fail. Even with a bad coupler, it just makes noise. Still works. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
Buapo Addict
 | Subject: Re: 1997 Riviera Questions Sun Jul 27, 2008 2:30 am | |
| For belts, make sure you get GATES belts. They're the best.
If I were you, do the transmission fluid and filter. Go with a full-synth fluid. I used Dexron 7 or something... it's GM's newest synthetic tranny fluid, and it works very nicely. | |
BillBoost37 Junkie
Location : Enfield CT Joined : 2007-11-28 Post Count : 769 Merit : 25
 | Subject: Re: 1997 Riviera Questions Mon Jul 28, 2008 10:36 am | |
| One of the first things I would consider is the lower intake gaskets. At 130K they are most likely original. While they are most likely not going to cause a problem today, a swap to the new GM (dealer only) aluminum gaskets will help bulletproof your investment. | |
Name : Dave Age : 62 Location : In The AZ Oven Joined : 2007-01-17 Post Count : 4502 Merit : 44
 | Subject: Re: 1997 Riviera Questions Mon Jul 28, 2008 11:15 am | |
| No one has mentioned pulleys. At 132k it's possible some of your oem pulleys have already been replaced. They have a tendency to start failing around 100k. I'd strongly suggest taking both belts off their tensioner pulleys and checking each pulley for smooth, quiet operation, by hand. If your belts look like they are in need of replacing, do yourself a big favor and replace all of the idler and tensioner pulleys at the same time. | |
Supercharged Addict
Name : Blake Age : 33 Location : Akron, Ohio Joined : 2008-03-12 Post Count : 611 Merit : 0
 | Subject: Re: 1997 Riviera Questions Mon Jul 28, 2008 11:24 am | |
| tie rods, the joints, ends.... | |
 | Subject: Re: 1997 Riviera Questions Thu Jul 31, 2008 7:58 pm | |
| the LIM gaskets are something I should do for sure it sounds likes? I asked the service manger and he said that the supercharger cars didnt have the problems like the N/A cars do. | |
 | Subject: Re: 1997 Riviera Questions Thu Jul 31, 2008 8:21 pm | |
| The SC are less prone to LIM gasket problems, but they do fail over time it seems. I have 165k miles so far on original LIM gaskets. I have not had a problem yet, but recently 2 of my plugs were in bad shape. I am having my oil tested to see if antifreeze could be leaking from the gaskets, but no solid conclusion yet. My engine runs great, but I'm keeping an eye on this.
I recently replaced the injectors, but this probably could have waited a bit longer. I do not know if one or all six were clogged, but swapping made a big improvement in performance. I plan to send them out for inspection sometime soon. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
manofmany Addict
Name : manofmany Age : 38 Joined : 2008-07-26 Post Count : 611 Merit : 5
 | Subject: Re: 1997 Riviera Questions Thu Jul 31, 2008 8:30 pm | |
| If it aint broke, don't fix it! | |
ibmoses Aficionado
 | Subject: Re: 1997 Riviera Questions Thu Jul 31, 2008 8:31 pm | |
| - manofmany wrote:
- If it aint broke, don't fix it!
Ditto! Bert  | |
 | Subject: Re: 1997 Riviera Questions  | |
