 Fel-Pro tranny pan gasket?
5 posters
96RIVMANN
96RIVMANN
Fel-Pro tranny pan gasket? Empty
PostSubject: Fel-Pro tranny pan gasket?   Fel-Pro tranny pan gasket? EmptyMon Oct 27, 2008 8:42 pm
Has anybody replaced the factory tranny pan gasket with the fel-pro one? I have changed my fluid 3 times and I think my original gasket with 168K is starting to leak finally and the GM replacment is $40 where as the fel-pro is only $13.
PostSubject: Re: Fel-Pro tranny pan gasket?   Fel-Pro tranny pan gasket? EmptyMon Oct 27, 2008 9:04 pm
I would take a good look at the fel-pro and compare it to our OEM. The OEM is a fantastic gasket, it appears to be a rubber coated metal. I don't know if I got a new one with my rebuild or not, but it's still the OEM type, and it's still holding up well. I will never use one of those cork or thin rubber/foam ones that comes with a trans filter.
If it were mine, I would replace with OEM or something just as good. have you checked that all the bolts are tight on the pan?
PostSubject: Re: Fel-Pro tranny pan gasket?   Fel-Pro tranny pan gasket? EmptyMon Oct 27, 2008 10:09 pm
Yeah I used The oem Style gasket from napa seams to be working great
http://www.Chitownracing.com
PostSubject: Re: Fel-Pro tranny pan gasket?   Fel-Pro tranny pan gasket? EmptyMon Oct 27, 2008 10:51 pm
As long as the replacement gasket has metal spacer rings around each bolt location you should be okay. The stocker is well worth the $40 as it prevents you from crush bending the tranny pan. Look for discounts from the big online GM parts dealers (GMpartsdirect, Monsterpartsonline, etc).
ramjetranch
ramjetranch
PostSubject: Another Country Heard FRom   Fel-Pro tranny pan gasket? EmptySat Jul 02, 2011 6:55 am
Based on my long experience with the OEM metal core gasket on the Riviera, and now a similar design on our Ford Taurus Duratec V-6, I would keep reusing the factory "reusable" gaskets until they leak or appear damaged when you remove them.
» Valve Cover Gasket and Oil Pan Gasket
» "Top end" gasket set
» tranny help pls!!!!
» Transmission Fluid Survey...
» Transmission Trouble, Slipping?? (Series I SC)
