| Chrome Wheel Center Caps | |
+19Jason RivieraRyan stan robotennis61 Mr.Riviera Eldo 99Rivman BMD ibmoses Karma Rickw xxsupergman25xx Straighteight deekster_caddy AA sburch23 albertj nothincame2mind Shintsu 23 posters |
| Subject: Re: Chrome Wheel Center Caps Sun Oct 03, 2010 11:39 pm | |
| I still have a 7 spoke chrome cap for sale. its missing 1 tab but otherwise in perfect condition. $35 shipped in the cont. US. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
Straighteight Member
Age : 89 Joined : 2007-01-22 Post Count : 66 Merit : 1
| Subject: Re: Chrome Wheel Center Caps Mon Oct 04, 2010 7:49 am | |
| - albertj wrote:
- Straighteight wrote:
- Anybody found a NEW way to use the center caps once the tabs break off? How about the adhesive used to hold moldings on, just a dab to hold, but strong enought to hold em on?
Anybody got used ones for sale? You can stick them on the wheels by cleaning them (and the hub area) with a little dry gas on a clean rag and then a streak of RTV on the edge of the cap - in effecct you glue them in place.
Problem is (not a huge problem just a PITA) you have to do this *every* time you pull them off.
Thank you for the tip! Any particular brand of RTV you have had good luck with? How much trouble getting them off? Wouldn't a spot here and there on the edge of the cap do the job, and make them easier to take off? | |
| Subject: Re: Chrome Wheel Center Caps Mon Oct 04, 2010 12:14 pm | |
Any particular brand of RTV you have had good luck with? How much trouble getting them off? Wouldn't a spot here and there on the edge of the cap do the job, and make them easier to take off? Permatex. Unless your tabs are somewhat holding with that wire bail thinngy then you'll need to use a bead not dabs. THey will hold on unless you pry them off, if pried they will come right off clean. Form-a-Gasket is not anything like stick-at-all-costs urethane trim cement. It is mean to hold and disassemble clean. Albertj
| Subject: Re: Chrome Wheel Center Caps Mon Oct 04, 2010 3:13 pm | |
| I'm sure some of the fault lies with the tire monkeys and the demands of faster, faster, faster, but in my experience I don't think GM has ever built a decent center cap... The Buick Rallyes, the Pontiac PolyCast Honeycombs, the original Cadillac alloys, and now these - by the time I've bought the car something has always been broken or missing. | |
| Subject: Re: Chrome Wheel Center Caps Mon Oct 04, 2010 4:25 pm | |
| - Eldo wrote:
- I'm sure some of the fault lies with the tire monkeys and the demands of faster, faster, faster, but in my experience I don't think GM has ever built a decent center cap... The Buick Rallyes, the Pontiac PolyCast Honeycombs, the original Cadillac alloys, and now these - by the time I've bought the car something has always been broken or missing.
The center caps for the chromes are weird, it's like the tabs were glued on in the first place, which I imagine might have been done to keep the faces smooth. For what they charge for the silly things they could have molded in slots in the back and put a t304 stainless 'spider' on with little feet to hold on the rim. My Chrysler LeBaron had alloys and **much** better center caps, they were spun aluminum with a steel "spider" on the back, never a problem. Albertj | |
| Subject: Re: Chrome Wheel Center Caps Mon Oct 04, 2010 4:32 pm | |
| I think the tabs were molded to the cap as one piece, but it seems like they attempted to strengthen them with an epoxy near the area that is stressed. GM knew the design was weak, so they did what they could - might be the reason they charged so much for them.
My originals all broke, but I think that's because I let others (mechanics) abuse them. Now that I have a set of "fresh" ones (NOS), I've had no problems as long as I'm careful and don't let them fall into the wrong hands. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Chrome Wheel Center Caps Mon Oct 04, 2010 4:37 pm | |
- I think the tabs were molded to the cap as one piece, but it seems like they attempted to strengthen them with an epoxy near the area that is stressed. GM knew the design was weak, so they did what they could - might be the reason they charged so much for them.
My originals all broke, but I think that's because I let others (mechanics) abuse them. Now that I have a set of "fresh" ones (NOS), I've had no problems as long as I'm careful and don't let them fall into the wrong hands. My originals all broke, now when have a shop do tire changeover I just take 'em off first. I do have a couple tabs I repaired with fillets of JBWeld. Albertj | |
| Subject: Re: Chrome Wheel Center Caps Mon Oct 04, 2010 4:47 pm | |
| I have added some epoxy to the stressed areas, as extra insurance. Maybe it has helped? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Chrome Wheel Center Caps Tue Oct 05, 2010 3:41 pm | |
| Epoxy looks like a great idea. As I read thru all these suggestions the thought that these clips were glued on from the start, (a poor manufacturing procedure that should never have been considered by anyone sober) makes one wonder if any thought was given to Buick's reputation for durabilitiy, and what kind of tests they put these parts through before approving use and production. Thank you all for your thoughts and the time it took to present this information!! | |
| Subject: Re: Chrome Wheel Center Caps Tue Oct 05, 2010 3:56 pm | |
- As I read thru all these suggestions... it makes one wonder if any thought was given to Buick's reputation for durability, and what kind of tests they put these parts through before approving use and production...
As "The Engineer", I think I figured out the mathematical answer to your musings: 36,000-mile warranty + 40,000-mile tires = "Ok, go ahead and approve the center caps!!" | |
| Subject: Re: Chrome Wheel Center Caps Tue Oct 05, 2010 4:07 pm | |
| Now lets talk about paint delamination. | |
| Subject: Re: Chrome Wheel Center Caps Tue Oct 05, 2010 4:22 pm | |
| best way to repair plastic tabs is with thin strips of fiberglass. works forever.... | |
| Subject: Re: Chrome Wheel Center Caps Tue Oct 05, 2010 4:25 pm | |
| - robotennis61 wrote:
- best way to repair plastic tabs is with thin strips of fiberglass. works forever....
I would assume that you need to sand off the 'PlastiChrome' first? | |
| Subject: Re: Chrome Wheel Center Caps Tue Oct 05, 2010 4:45 pm | |
| Subject: Re: Chrome Wheel Center Caps Tue Oct 05, 2010 4:59 pm | |
I would assume that you need to sand off the 'PlastiChrome' first? a good scuffing is all that you need. fiberglass resin,once applied wont come off a prepped surface. | |
| Subject: Re: Chrome Wheel Center Caps Tue Oct 05, 2010 6:21 pm | |
I would assume that you need to sand off the 'PlastiChrome' first? a good scuffing is all that you need. fiberglass resin,once applied wont come off a prepped surface. For those of us with little or no imagination, how about a ruff outline how it is done? | |
BMD Aficionado
| Subject: Re: Chrome Wheel Center Caps Tue Nov 09, 2010 2:36 pm | |
| thats the way its done... another way would be to place fiberglass strips along the length of the repair. repeat until satisfied with the strength of the repair. | |
| Subject: Re: Chrome Wheel Center Caps Tue Nov 09, 2010 4:03 pm | |
| Nice repair. Will have to look at doing the same or something very similar. Cheap, strong and easy, doesn't get any better than that. | |
| Subject: Re: Chrome Wheel Center Caps Tue Nov 09, 2010 7:48 pm | |
| almost wonder if that's how they ought have done it in the first place.
| Subject: Re: Chrome Wheel Center Caps Tue Nov 09, 2010 8:35 pm | |
| PLUS! One question, BMD... What did you use for the metal? Is it aluminum that's thin enough to still 'spring'? | |
BMD Aficionado
| Subject: Re: Chrome Wheel Center Caps Tue Nov 09, 2010 8:46 pm | |
| Exactly, anything stiffer would not have allowed the necessary play for the tab to bend in and out, so a thin grade aluminum is a must. Thanks for the + . | |
| Subject: Re: Chrome Wheel Center Caps Tue Nov 09, 2010 9:17 pm | |
| this is exaclty what i did to my 7 spoke caps ,had only on 1 of the caps a missing tab the rest were OK....then used some GORILLA GLUE just to strenghten them .So far after 2 year no problem at all . | |
| Subject: Re: Chrome Wheel Center Caps Tue Nov 09, 2010 11:16 pm | |
| - stan wrote:
- this is exaclty what i did to my 7 spoke caps ,had only on 1 of the caps a missing tab the rest were OK....then used some GORILLA GLUE just to strenghten them .So far after 2 year no problem at all .
Stan, I'm not sure that I'm following you. Did you just Gorrila Glue the remaining tabs that were good or did you cut them all off and made aluminum brackets then fastened with a screw and then gorilla glued them back on to the center cover. That's the impression I got for BMD unless I'm way off base. In other words, is this a preemptive fix as well as a fix after the fact if you can find the plastic piece to attach to the aluminum angle bracket. | |
| Subject: Re: Chrome Wheel Center Caps Wed Nov 10, 2010 2:13 am | |
| ohh yes Rick,my tabs were good as new i just glued them incase they crack and break over time. Just remember-it takes about 10 hours for the glue to cure,BUT you must be careful to put only a bit `cause it expands while curing. | |
| Subject: Re: Chrome Wheel Center Caps | |
