| Subject: Re: ZZP 1.9:1 Ratio Modified Rockers Fri Jul 31, 2009 4:42 pm | |
| Considering it's hot summer, brief 2º blips of KR is not bad, imo. Are your headers on yet? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: ZZP 1.9:1 Ratio Modified Rockers Fri Jul 31, 2009 4:48 pm | |
| Yes, the headers have been on for quite a while now. I had lost some low end torque due to running just the headers and the Intense PCM. Those were the only real engine mod's done until installing rockers and 3.4 mps. Today was not the best day for me to do a real good HOT test as we have had rain all day. So that cooled things down a bit. Will have to re-test when temps climb again. I still need a PCM tune though, just to tweak everything and adjust trans pressure's and shift points, etc. Everything in my sig is up to date.
| Subject: Re: ZZP 1.9:1 Ratio Modified Rockers Fri Jul 31, 2009 7:31 pm | |
| 2* doesn't alarm me, especially if it's during shifts. There are all kinds of other noises going on during shifts too. Just watch for KR under heavy throttle at higher RPMs.
One of these days we'll have to get together and see what I can do with your tune! | |
| Subject: Re: ZZP 1.9:1 Ratio Modified Rockers Fri Jul 31, 2009 7:45 pm | |
| - deekster_caddy wrote:
- One of these days we'll have to get together and see what I can do with your tune!
Well, you'll have to let me know when your available. I know your very busy right now. I can make myself available to your schedule, just about any time. Thanks. | |
| Subject: Re: ZZP 1.9:1 Ratio Modified Rockers Fri Jul 31, 2009 8:17 pm | |
| I'm on vacation next week and around later in the week... | |
| Subject: Re: ZZP 1.9:1 Ratio Modified Rockers Fri Jul 31, 2009 8:27 pm | |
| Well Derek just let me know if you have some time later next week, that would be excellent. | |
| Subject: Re: ZZP 1.9:1 Ratio Modified Rockers | |
