 Trying to remove lower half of dash...
3 posters
Trying to remove lower half of dash... Empty
PostSubject: Trying to remove lower half of dash...   Trying to remove lower half of dash... EmptyThu Aug 20, 2009 5:17 pm
... Does the upper half need to come out or can I just pull it down? I removed the 3 7mm screws underneath but it won't budge at all.
PostSubject: Re: Trying to remove lower half of dash...   Trying to remove lower half of dash... EmptyThu Aug 20, 2009 7:48 pm
Just what are you trying to remove. It's not clear. You said you removed 3 screws, are you talking about the insulating panel below the steering column or the one on the passenger side below the glove box?????
PostSubject: Re: Trying to remove lower half of dash...   Trying to remove lower half of dash... EmptyThu Aug 20, 2009 8:25 pm
To remove the knee bolster, the padded piece under the steering wheel, the dash panel does have to be removed, there are bolts under the panel that hold the bolster on.
PostSubject: Re: Trying to remove lower half of dash...   Trying to remove lower half of dash... EmptyThu Aug 20, 2009 11:29 pm
Sorry I wasn't more clear. I meant the lower half of the dash just beneath the steering wheel. You do have to pull the upper half of the dash which was an added PITA step but it turns out that I had to pull it anyway.
Thanks for the info.
» DO YOU HAVE TO REMOVE THE DASH TO INSTALL A PCM?
» Write-Up: Riv Dash and Door Removal
» to remove or not to remove, that is the question
» Remove Headrest
» How to remove the seat memory module?
