| FAQ: Rust Areas & Concerns | |
+32Rivit DaveE_95Riv Rivnut Sir Psycho Sexy Yardley sniperdude rivparadise holson03 Straighteight stan RidzRiv deekster_caddy denim Abaddon SupersportSteve flyineagle96 robotennis61 ghpcnm otto95 AA Snowdog BlownRiv BKRIV LARRY70GS ibmoses Z-type Karma 1998 Riv albertj Rickw Jack the R rivboy 36 posters |
Yardley Enthusiast
| Subject: Re: FAQ: Rust Areas & Concerns Sat Sep 14, 2013 9:15 pm | |
| OK. Not knowing an engine cradle from a baby cradle, can someone explain to me where to look? And what tilt wheel issue? This car has sat on this lot since spring, based on the lack of foliage on the trees in the pics. it is a small lot in a small town, so it might just be lack of buyers, but it may be something others see that I don't. So I want to be sure. Any help is appreciated. | |
Sir Psycho Sexy Junkie
| Subject: Re: FAQ: Rust Areas & Concerns Sat Sep 14, 2013 9:22 pm | |
| Lay down on your back, crawl under the front of the car and look for a metal frame. Tap it with a wrench or something to check to make sure its solid. As for the tilt wheel thing, Grab the wheel, try to shake it from top right to bottom left. If it feels tight, youre good. If there is excessive movement, its really not that hard of a fix. | |
Rivnut Member
Name : Ed Raner Age : 77 Location : NE Kansas Joined : 2011-11-30 Post Count : 67 Merit : 6
| Subject: Re: FAQ: Rust Areas & Concerns Sat Sep 14, 2013 9:26 pm | |
| With the car on a lift it will be obvious. The engine in bolted into something like a sub-frame and that sub-frame is bolted to the chassis. On a lift it's easy to see. Look for rust around anyplace that can trap dirt, sand, salt, or other crud that will allow rust to form if not kept clean especially where pieces are bolted together. You'll see the rust, flaked paint, corroded metal, etc.
This link is to an ebay listing showing an engine cradle. It's not for a Riviera, but it is for a Buick; you'll get the idea.
http://www.ebay.com/itm/00-BUICK-LESABRE-Engine-Crossmember-Front-cradle-/390414925830?pt=Motors_Car_Truck_Parts_Accessories&hash=item5ae68b0006&vxp=mtr | |
| Subject: Re: FAQ: Rust Areas & Concerns Sun Sep 15, 2013 8:06 am | |
| - Yardley wrote:
- So, the whole cradle goes bad? The metal frame area? Or just the mounts? And is it a rust issue?
It is a rust issue Yards, and if it is that bad, it will be very obvious if you take a good look at the car. Make sure you inspect the rear brake lines. My cradle was fine, but the rear 4 mounts were a bit corroded. I replaced them up at Readers Digest when we installed the sway bars. My back brake lines were scary, replaced them at the same time. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
DaveE_95Riv Amateur
Name : David Egan Location : Minnesota USA Joined : 2013-06-08 Post Count : 20 Merit : 0
| Subject: temp Fri Sep 20, 2013 7:53 am | |
| Anyone who will buying a Riv from the states who use salt, please check your fuel tank lock ring area for the fuel pump. I live in the midwest-Minnesota (Salt). Pull back the trunk carpet on the passenger side, remove a small access panel to see the top of the fuel pump. you will see a lock-ring holding the fuel pump down sealing it on the fuel tank. It sits on top, but in a depression which can hold water and salt. Not good. If your fuel pump never goes out - no worry then, but if it does.... The car stalled and quit an hour away one morning the wife was going to work. The mechanic scanned, checked, and said the fuel pump went out, and surprise, in looking the lock ring was very, very rusty. The huge problem was the lock tabs on the plastic/nylon fuel tank were very bad. If I remember right, there were 5, and 3 were rusted out. The gas tank was worthless without good tabs. Besides a fuel pump, the big issue then was finding a fuel tank w/o the lock tabs rusted out. Guess what, the tank is discontinued from GM, and no one makes a replacement. Have fun finding a good one! Finally found one in Utah. We found water in my gas tank, rust, the fuel filter was shot. its really amazing the car even ran. It was the fuel pump that finally died. Also dropping the tank is not an easy job as some say. Wow, If I had only checked that area, I would have walked away from this car, and have an extra thousand in my pocket today, and a few less gray hairs. Just beware my friends, it hides quietly under the carpet. | |
Rivit Enthusiast
Name : Jim Location : Walla Walla, Washington Joined : 2013-09-22 Post Count : 208 Merit : 22
| Subject: Subframe rust issue ? Thu Dec 05, 2013 11:36 pm | |
| Volume 47, Number 7 "BUICK Bugle" November 2012, page 13, LETTERS to the editor, reads:
"Pete, I read with great interest the warning about rusted subframes on Riviera, laSabre and Park Avenue models. I'm surprised the Buick Regal was not included. Two years ago our 1998 Regal with 98,000 miles began making strange sounds when backing out the driveway and turning the wheels. It also felt strange when driving. When the car was put on a lift to check things out it was discovered the subframe behind the engine had totally rusted through as was a wreck waiting to happen. We were told it would cost thousands of dollars to fix, so within a week we had a new car. We were told it was the air conditioner drain water that caused the problem, probably aided by the sald on Wisconsin roads. Please alert "Bugle" readers that Regals also face this serious and dangerous problem. Thanks Eric M. Bloc, BCA #1373" ********************************************************************* Does anyone here (RP) have access to the referenced "Bugle" editors warning article about subframe rust? Original notice warning may have been in the September or October 2012 edition?? (I'm not a BCA subscriber and the Nov 2012 copy was just a chance find on a used mag rack) I'd be most interested in what it says and I might add I've noticed considerable water condensation puddles following air conditioning use. Is there a preventative measure or mod that can eliminate or minimize this apparent issue? | |
| Subject: Re: FAQ: Rust Areas & Concerns Fri Dec 06, 2013 3:46 pm | |
| Imo, water itself isn't really dangerous to the undersides of a car. Salt and saltwater is the issue. I spray underneath my Riviera with a high pressure hose after driving over salted roads and there is very little rust after 10 winters. I won't say zero rust, but when I pulled the subframe a couple years ago it was solid. I don't buy into the air conditioning drip water causing the subframe to rust out. All cars drip water from AC. It can't be any more dangerous than driving in the rain.
One thing that can cause rust is dragging the underside of the car over terrain, such as curbs, parking stops or other debris. Also gravel, salt and rocks on the roads. When these types of objects hit and scrape off the undercoating, the exposed metal can be attacked by salt, water, and dirt. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Rivit Enthusiast
| Subject: Re: FAQ: Rust Areas & Concerns Sat Dec 07, 2013 10:39 pm | |
- Imo, water itself isn't really dangerous to the undersides of a car. Salt and saltwater is the issue". ..... "All cars drip water from AC. It can't be any more dangerous than driving in the rain".
Thanks Aaron and I share your opinion and practice of spraying the undercarriage frequently. I am not experiencing any subframe rust or for that matter, rust of any nature on my 95. I remain curious as to what Pete Phillips, the editor of "The Buick Bugle" put to writing and his basis for it. Was hoping someone here @ RP, belonging to the BCA could review their retained 2012 copies and quote the original content, context, and basis or bias of said "warning". Maybe I'll route a PM to Brian (Centurion) asking him if he could find it himself or know just the person to ask. Thanks again AA for the response and admining this site. | |
rivparadise Fanatic
Name : Samuel Age : 51 Location : Niagara Co. Joined : 2007-06-10 Post Count : 381 Merit : 11
| Subject: Holy Shishkabob! Sun Jul 05, 2015 1:07 pm | |
| Been looking for a mysterious clunk and after major surgery on the strut towers, the frame where the cradle bolts to was completely rotted away! Wow. After almost two years of mechanics looking at this car no one saw this until now. In any case, part of a 1981 Gravely mower deck is now part of my new frame! My neighbor, mechanic is an artist! Welded and rebuilt the entire section. I know anyone who buys this car is getting a TANK! We're going to weld a few more pieces in the back as well. In the meantime this car drives amazing now. Forgot how awesome this thing drives. Subframe Bolt floppin around! Tower work! Gravely Orange! Right in front of RSSA All Better now! | |
h20man Enthusiast
Name : Aaron W. Age : 29 Location : CT Joined : 2013-10-04 Post Count : 242 Merit : -2
| Subject: Re: FAQ: Rust Areas & Concerns Tue Oct 18, 2016 6:26 pm | |
| OK guys I just found some rust on the passenger side rear jack point, right in front of the rear wheel. I pulled up on the plastic panel and all this sand and rust poured out..now I'm scared big chunks too. What can I do to stop this process?? Where else should I look for rust I know engine cradle also | |
| Subject: Re: FAQ: Rust Areas & Concerns Tue Oct 18, 2016 6:38 pm | |
h20man Enthusiast
| Subject: Re: FAQ: Rust Areas & Concerns Tue Oct 18, 2016 8:30 pm | |
h20man Enthusiast
| Subject: Re: FAQ: Rust Areas & Concerns Tue Oct 18, 2016 8:31 pm | |
| 2nd pic is my jack point it's a little dark I just took it, I think I'll have to por-15 all these areas | |
1997riv Enthusiast
Name : Joined : 2014-11-23 Post Count : 131 Merit : 0
| Subject: Re: FAQ: Rust Areas & Concerns Fri Dec 29, 2017 1:07 am | |
Last edited by stydel311 on Sat Feb 15, 2020 10:47 am; edited 2 times in total | |
| Subject: Re: FAQ: Rust Areas & Concerns Fri Dec 29, 2017 12:12 pm | |
| Yup, mine is a lot worse than that. Northeast road salt winters. I wire brushed it and hit it with rust converter. Just trying to limit the future damage. It is why the top of the fuel tank rots (locking tabs for the fuel pump) _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
chitown_riv98 Fanatic
Name : Ruben Age : 42 Location : Illinois Joined : 2008-03-10 Post Count : 399 Merit : 4
| Subject: Re: FAQ: Rust Areas & Concerns Sun Jan 14, 2018 11:46 am | |
| I'd say keep an eye on your subframe and rear shock area where the shocks mount to the car | |
| Subject: Re: FAQ: Rust Areas & Concerns Mon Jan 15, 2018 9:17 am | |
| - chitown_riv98 wrote:
- I'd say keep an eye on your subframe and rear shock area where the shocks mount to the car
I just replaced my rear subframe and rebuilt the spring perches. | |
| Subject: Re: FAQ: Rust Areas & Concerns Thu Jan 17, 2019 11:24 am | |
| WHile looking for other things on the net this morning I came across this link
http://www.saltawayproducts.com/How%20Salt-Away%20Works.htm
It has what seems to be a good report on how salt works in causing corrosion and how a water-borne cleaner/inhibitor works to solve that problem.
I'd like to know what those of you who are knowledgeable think of this -- looks like analytical chemistry to me -- and would you mind posting comments? I mean, it sounds sensible to me. Might give it a try.
nickwon Member
Name : Nick Joined : 2018-06-25 Post Count : 52 Merit : 0
| Subject: Re: FAQ: Rust Areas & Concerns Thu Mar 21, 2019 1:20 am | |
| Interesting. Hope someone here has personal experience with Salt-Away. I did a quick research and I found out that this product is quite popular among boat owners. | |
| Subject: Re: FAQ: Rust Areas & Concerns | |
