| Parking heaters, Webasto/Eberspächer etc. | |
+9Jason robotennis61 duckstu Hometown Hero T Riley Rickw 1998 Riv deekster_caddy JT Newman 13 posters |
Snowdog Addict
Name : Timo Age : 37 Location : Finland Joined : 2008-10-04 Post Count : 732 Merit : 24
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Wed Jan 06, 2010 7:13 am | |
| yeh...it was a weard strong wining...never heard it before..toght something is braking down..like power steering pump or something...maybe i make a video clip next time i cold start it. not sure if it's normal or not. | |
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Wed Jan 06, 2010 7:22 am | |
| Does it quiet down after a few minutes.? And, can you can hear it on the drivers side near the intake, not on the passenger side so much.? | |
JT Newman Amateur
Name : Jari Age : 41 Location : Tampere, Finland Joined : 2009-10-05 Post Count : 38 Merit : 0
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Thu Jan 07, 2010 7:18 am | |
| Derek: well.... 5W40 was the first can to grab. Engine rarely gets so hot that it would benefit better oil pressures 40-grad oil gives, so it may be too "good". And of course multigrade oils have much more additives. I'll buy 5W30 next time. Jason: you got the point! Our electric grid gets lots of beating during long winter and it of course causes pollution, but what you gonna do. But: if a little masochist lives inside you, you can check our energy production charts here: http://www.stat.fi/til/salatuo/2008/salatuo_2008_2009-10-21_kuv_001_en.html You've been warned  But really, car owners cannot be punished about these things. I simply think that it's better to get car pre-heated so I can get better mileage per gallon and help my engine to last longer. Pre-oiler system is totally new for me except using them on military vehicles. Some of my friends are running panzer/tank museum nearby and they drive old russian tanks which use system like that. -5°F. It tooks 4-5 secs to start Riv. I possibly need to change battery. | |
Snowdog Addict
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Thu Jan 07, 2010 10:17 am | |
| hmmm cos i changed the fuel pump...every time i start it i have to wait that the fuel pump makes pressure then start. whit old one the pressure stayed and it started right after turning the key. now if i straight turn the key it will take longer to start. sometimes i let the fuel pump work 2 times (turne the key till the pump starts....turn back...and turn again ignition position so the pump starts again and makes pressure...after that it allways starts...even whit -23C it took 1-2 sec to crank and started!...but yeh...the wining sound is somethign new and odd...i think it comes from left side of the car...SC or transmission.
today one worker told me that he started hes car today on morning (Mercedes Benz 315 or something...turbo disel whit automatic tiptronic transmission) and he noticed a strange wining tho..not the alternator...told it came from the transmission...
On cold times it's allways better to keep new filters in (fuel, engine oil, transmission oil and others) liqueds don't go so good through the old filters.. | |
Name : Mark Age : 58 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09 Post Count : 3118 Merit : 104
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Thu Jan 07, 2010 2:49 pm | |
| Timo: I've occasionally heard transmissions whine, but usually in a particular gear position, and usually all the time regardless of temperature. If your whine is on the left and goes for at least several minutes and no more than 10, I'd say it is the supercharger. I've heard mine doing it ever since I gutted the airbox lid. JT: If the engine was cranking at normal speed for those 4-5 seconds that it took to start, the battery is fine. Jason: Do you know how many watts or amps the block heater uses? I know that cold starts are harder on the engine, but as far as fuel consumption and pollution vs a gasoline parking heater or the electric power plants, remember that these cars have heated O2 sensors that only take about 90 seconds to put the PCM into closed loop mode... I've watched the A/F mixture on the scanner start out at 7:1 upon startup, and slowly climb until it locks into 14.7:1 when the O2 sensors go into closed loop. This also makes the converter light off sooner. In the old days, it took about 5 minutes for the system to go into closed loop. PS - Since there was some talk about oil on here, I thought I'd mention something else incredibly stupid I discovered about those brilliant GM engineers: After all these years, they are still setting the oil light to only come on at two PSI! We shouldn't call them "idiot lights", but rather "idiotic lights"... They come on to tell you that you've already burned up your engine. I lost the engine in my Eldorado because the top of the motor stopped oiling on a long trip, but the damned oil light never came on!  | |
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Thu Jan 07, 2010 9:12 pm | |
| 2PSI, that is idiotic and also good to know. Now I'll have to add an Oil Pressure gauge in the spring along with a voltmeter. What do think about the oil pressure accumulator in the winter. Wouldn't this unit have a hard time pre-oiling with thick cold oil.? I would think it would or should be mandatory to use a synthetic oil with one of the pre-oilers in the winter. I still like the idea of pre-oiling though. I can't see any downside to it. | |
Jason Aficionado
Name : Jason Age : 39 Location : Comox, BC, Canada Joined : 2007-01-23 Post Count : 1378 Merit : 64
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Thu Jan 07, 2010 9:40 pm | |
| - JT Newman wrote:
But really, car owners cannot be punished about these things. I simply think that it's better to get car pre-heated so I can get better mileage per gallon and help my engine to last longer. -5°F. It tooks 4-5 secs to start Riv. I possibly need to change battery. right. Do you have a block heater ? Less than 10% or 98 rivieras got them from the factory, I don't know about 1996. They are pretty cheap to buy aftermarket. Probably a lot cheaper than the heaters you mention. It should be more to get you through the winter. Have your battery tested. It's probably on its way out. | |
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Thu Jan 07, 2010 9:46 pm | |
| He mentioned in his first post that he had no way to power an electric block heater. That's why he is exploring the purchase and install of a self contained gasoline powered unit. | |
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Thu Jan 07, 2010 10:39 pm | |
| - Rickw wrote:
- 2PSI, that is idiotic and also good to know.
Now I'll have to add an Oil Pressure gauge in the spring along with a voltmeter. What do think about the oil pressure accumulator in the winter. Wouldn't this unit have a hard time pre-oiling with thick cold oil.? I would think it would or should be mandatory to use a synthetic oil with one of the pre-oilers in the winter. I still like the idea of pre-oiling though. I can't see any downside to it. Tell me about it. But where to put the gage? Any multi-weight oil is supposed to thin out at cold temps, but then again I was surprised how thick my new Castrol Edge synthetic was at room temperature... | |
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Thu Jan 07, 2010 10:56 pm | |
| - Eldo wrote:
- Tell me about it. But where to put the gage?
I'm going to eliminate the ashtray, I think, and put a flat piece of ABS plastic in there and mount the gauges and still be able to close the door/cover for it. | |
Jason Aficionado
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Sat Jan 09, 2010 3:23 pm | |
| - Rickw wrote:
- He mentioned in his first post that he had no way to power an electric block heater.
That's why he is exploring the purchase and install of a self contained gasoline powered unit. his post can mean a several things does he not have the K05 block heater option ? a block heater probably costs 50$ to buy. is he banned from using electric block heaters ? they sell car heaters that run on electricity. You plug it in and leave it in your car. Is that what he can't use ? Does he just not have access to an outlet ? | |
Snowdog Addict
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Sat Jan 09, 2010 4:59 pm | |
| the problem is that where he lives/works or so on he dos not have the plug from where to take the electricity for the block heater. thats why he desided not to install it.
Thats what i understood of hes story..
The webasto heater is independent and can be used anytime anywhere. | |
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Sun Jan 10, 2010 9:25 am | |
| I watched a couple of the video's on the Webasto unit. Well, I have emailed the US manufacturer of the Webasto units for more information. Their website cater's to the Diesel Truck market and they also make aftermarket sunroofs for autos and they are big in the Marine industry with A/C units and heaters. Very little info on car heaters and the re-seller and installer list for my state doesn't list anyone selling or installing the car heaters. Will wait for there response and see what they have to say. It seems they are very common in Europe but not here yet. | |
JT Newman Amateur
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Sun Jan 10, 2010 3:21 pm | |
| I don't have a parking lot of my own yet, thus I don't have an electric post where to take juice for engine block heater. I live in city centre and we have shortage for parking lots. My car is an ex-Florida car without block heater. Because of lack of lot and post (I've now been on queue for 8 months) I haven't installed it (yet), that's why I'm thinking of buying fuel powered unit, because it runs independently It was very cold weekend here, temperature dropped to -20°F. | |
Snowdog Addict
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Sun Jan 10, 2010 4:43 pm | |
| Jari how does your's start whit -20C or even colder?...the coldest i truyed was -25C...just turnign the key 1 time to ignitoin but not cranking. letign the pump make the pressure up...then turnign back in O...and again into ignition so the pump makes agan more pressure and then turn the key to end so it cranks. sometimes 2-6sec and starts.
Wonder how much it needs fot not startign anymore. guess the main reeson is the battery who gives up. Need to change the aftermarket car alar and the new interjor antenna. need to change the antennas wiering a bit so it goes only on when radio is turned on. | |
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Sun Jan 10, 2010 6:26 pm | |
| i didn't know an interior antenna required power to "come on". How does yours work. | |
Name : Dave Age : 62 Location : In The AZ Oven Joined : 2007-01-17 Post Count : 4502 Merit : 44
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Mon Jan 11, 2010 12:46 am | |
| I have absolutely no problem starting at -30 C, with no preheating of any kind. Fires right up. | |
Snowdog Addict
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Mon Jan 11, 2010 2:05 am | |
| mine problem is only the battery...i buyed a new one but cos the car had been in garage for 3 motnhs in works and so on it cone empty many times and now isent so good as it used to be.
not sure how to say but the antenna has a signal strenghtener in it? when it's on a red led light comes on it to show its turned on. | |
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Mon Jan 11, 2010 2:20 am | |
| Ah, an amplified antenna... | |
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Mon Jan 11, 2010 4:38 pm | |
| - Snowdog wrote:
- mine problem is only the battery...i buyed a new one but cos the car had been in garage for 3 motnhs in works and so on it cone empty many times and now isent so good as it used to be
On my van which I use only once in a while, I leave a device connected to the battery called a "Battery Tender". There are other versions of this too, but basically it's a smart trickle charger that keeps the battery at full charge. There are some more advanced ones that will occasionally 'zap' the battery to keep the plates from building up a coating of something. | |
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Tue Jan 12, 2010 12:56 pm | |
| This the response from Websto Corporate Headquarters in the US Rick,
We no longer sell kits for specific passenger cars. Most of our heaters are installed on trucks, buses, and work vehicles. Depending on the type of vehicle you have, your nearest dealer may be able to purchase our base heater kit (generic or non-vehicle specific) and do a custom install for you.
Your nearest dealer is:
NEW ENGLAND DETROIT DIESEL-ALLISON
90 Bay State Road Wakefield, MA 01880 Phone: +1 781 246 1810 wpellegrine@nedda.com http://www.nedda.com/
Best regards,
Josh Lupu Webasto Product North America, Inc. Main: (800) 860-7866 Direct: (810) 593-6060 Fax: (810) 593-6001 Email: josh.lupu@webasto-us.com
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Tue Jan 12, 2010 1:46 pm | |
| Sounds like big $$$$ for a custom install. | |
Snowdog Addict
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Tue Jan 12, 2010 4:45 pm | |
| for cars ower 3000CC Engine cooltantheater petrol/diesel 1300€ Comes whit a 24h timer. whit 3 time setings (can heat the car 3 times a day) + for extra € can buy remotes, thermostat (can help heating the engine on running)  one C model for sell in finlands netselling page for 775€ [url]http://www.nettivaraosa.com/viewPart.php?id_part=899385&PN[0]=adv_search&PL[0]=advSearch.php?id=5859474@tb=tmp_find_agent&PN[1]=search_results&PL[1]=listAdvSearchFindAgent.php?id=5859474@tb=tmp_find_agent[/url] | |
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Tue Jan 12, 2010 5:16 pm | |
| Wow. This is great, but I would have to be living in Greenland to need something like this. I'm thinking a heated garage might be as effective? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc. Tue Jan 12, 2010 5:31 pm | |
| what about a oil pan heater? they have been around for years and they are cheap! | |
 | Subject: Re: Parking heaters, Webasto/Eberspächer etc.  | |
