| Non-Stop Wipers | |
+2KillaKeninaRiv RivieraBoricua 6 posters |
RivieraBoricua Rookie
Name : Luis M. Davila Location : San Juan, Puerto Rico Joined : 2010-03-24 Post Count : 15 Merit : 0
 | Subject: Non-Stop Wipers Thu Mar 25, 2010 10:08 am | |
KillaKeninaRiv Addict
Name : Kenneth Age : 40 Location : Roseville, MI Joined : 2008-05-17 Post Count : 709 Merit : 6
 | Subject: Re: Non-Stop Wipers Thu Mar 25, 2010 10:42 am | |
| I would check the relay and then the wiper motor itself. You can get the motor or a relay from a junkyard. They charge pennies for them here. The motor is fairly cheap and sits at the top of the engine bay and should be fairly easy to replace. | |
 | Subject: Re: Non-Stop Wipers Thu Mar 25, 2010 11:03 am | |
| Where can I locate the relay? | |
Name : Mark Age : 58 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09 Post Count : 3107 Merit : 104
 | Subject: Re: Non-Stop Wipers Thu Mar 25, 2010 3:03 pm | |
| Luis, I think he is referring to the Park Relay inside the wiper motor assembly itself... at least that's the only one I can find in my '98 book. Do you have an FSM (factory service manual?) If not, that's the first thing that we send newbies to eBay for.  I only have '97 & '98 manuals, so I can't be sure if the wiring is the same on a '95, but the only thing that isn't solid state in these systems is the Park Relay. The delay circuit in the motor is solid state, and wiper switch is the last thing you want it to be. A new one costs $400 even if you live in Michigan, because they combined everything into one unit, whereas a decade earlier the turn signal switch, emergency blinker switch, the cruise switch and dimmer switch were all separately-replaceable units... If you have a manual, there is a whole procedure for checking different parts of the wiper circuits. It is a very involved system... However, it may be worth taking the cover off of the motor module and checking the Park switch and any associated linkages in there, because I do remember that the older systems from the '60s thru '80s would sometimes not shut off because something in side would hang up and not let the system go into Park. Good luck, Mark | |
 | Subject: Re: Non-Stop Wipers Thu Mar 25, 2010 4:38 pm | |
| Thanks Mark! I only have the owners manual, but I am expecting soon a Service Repair Manual disc that we find on e-bay. | |
 | Subject: Re: Non-Stop Wipers Thu Mar 25, 2010 5:39 pm | |
| Thats why instead of looking through relays and switches Id just rather swap out the entire unit. Its only a matter of time before something else associated with it goes wrong, then youre right back at square one-taking it apart! For instance, if youre gas gauge is bad, instead of removing the fuel pump to replace the float, why not just remove the pump and replace the entire thing? If one part is messing up, sooner or later, youll be in the trunk again. If I find a motor for $25, isnt it worth that price rather than opening a complicated electrical unit that Im QUITE sure you dont want to end up doing? | |
 | Subject: Re: Non-Stop Wipers Thu Mar 25, 2010 5:49 pm | |
| Sorry Ken, I have to disagree with your example. The fuel sender is a notoriously bad part that can often be fixed by hand (got almost 5 years out of mine) or replaced with an individual part... The whole "fuel module" is over $400, and often a total waste of both $ and parts. Not to mention, how good can you be sure that a $25 wiper motor is? Luis, did you by chance purchase a "GM eSI Techline" DVD? That is what my '98 manual is, but it doesn't cover '95...  | |
 | Subject: Re: Non-Stop Wipers Thu Mar 25, 2010 6:04 pm | |
| Mark: I bought the GMC North America & Europe Service Repair Manual 1980-2005 Disc. | |
 | Subject: Re: Non-Stop Wipers Thu Mar 25, 2010 7:18 pm | |
| - RivieraBoricua wrote:
- Mark: I bought the GMC North America & Europe Service Repair Manual 1980-2005 Disc.
Does anyone here have any experience using this disc and is it comprehensive or lacking in detail due to the amount of years it covers.???? I'm curious, as I have seen these for sale on Ebay, but am under the assumption that the specific FSM (Factory Service Manual) for any particular year vehicle is more detailed and advantageous. Anyone have any input.?????? | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8530 Merit : 181
 | Subject: Re: Non-Stop Wipers Thu Mar 25, 2010 8:29 pm | |
Does anyone here have any experience using this disc and is it comprehensive or lacking in detail due to the amount of years it covers.???? I'm curious, as I have seen these for sale on Ebay, but am under the assumption that the specific FSM (Factory Service Manual) for any particular year vehicle is more detailed and advantageous. Anyone have any input.?????? Supposedly it's the GM SPO DVD. A guy in latvia is selling old ones and the EPC (a dual-layer DVD with pretty much all available parts listed). THey were intended to be used as backups if the GM dealer did nto have net access due to weather or high usage, in order to help ensure customer's cars were repaired timely. One way to find out - Boricua will please report. In the meantime you may find this informative - a page on the GM SPO web site explaining the DVD. http://service.gm.com/faq/dvdfaq.html#sidvdgenquestAlbertj | |
 | Subject: Re: Non-Stop Wipers Thu Mar 25, 2010 9:34 pm | |
| Albert, Is there a way to log on to this site for detailed info without being a Dealer.? | |
 | Subject: Re: Non-Stop Wipers Thu Mar 25, 2010 9:57 pm | |
In the meantime you may find this informative - a page on the GM SPO web site explaining the DVD. http://service.gm.com/faq/dvdfaq.html#sidvdgenquest Albertj Now that is the DVD that I was talking about. I bought it before I found my '97 paper manuals. GM Techline Service & Parts Operations (SPO) Electronic Service Information (eSI)... Mine is labelled version 2004.19, with the 2005.2.21 update. It has TSB's back to 1980, but the Riviera Service Manuals only extend from 1998 to 2005. Most of the 1998 stuff applies to 1997, but occasionally something is different, like the EVAP pressure switch next to the purge solenoid on '97s, but on top of the fuel module on '98s... | |
 | Subject: Re: Non-Stop Wipers Thu Mar 25, 2010 10:30 pm | |
| - Rickw wrote:
- Albert,
Is there a way to log on to this site for detailed info without being a Dealer.? not that I am aware of... if you surf around you will find you *can* see more than you'd expect, but not the manuals actually. Funny thing - the Hyundai people let you have their info as long as you own a Hyundai and register: http://www.hmaservice.com/I was once told that the site drives OE parts sales and improves customer satisfaction - something about better understanding of the cars' systems and functions, customers ask better questions, stuff like that. I have no data to back up that assertion though. It probably also helps both customers and the company avoid costs. Albertj | |
 | Subject: Re: Non-Stop Wipers Fri Mar 26, 2010 4:18 am | |
| Because the vast majority of the cars are running when they go in. You just pull off what you need. But thats why I buy a warranty when I go, so I dont get stuck holding a piece of scrap metal lol | |
 | Subject: Re: Non-Stop Wipers Fri Mar 26, 2010 10:51 am | |
| Nobody asked this......
Are they on constant low or high? Maybe your multi-function switch is toast.......the wiper control on the left stick of the steering column. | |
 | Subject: Re: Non-Stop Wipers Fri Mar 26, 2010 12:35 pm | |
| I will be able to give you a report about the disc as soon as it arrives by mail. One thing that worries me is that the original ad on E-Bay was for a 1995 Buick Riviera Service Manual, but when I received the payment confirmation the title was GMC North America & Europe Service Repair Manual 1980-2005. We'll see. | |
 | Subject: Re: Non-Stop Wipers Fri Mar 26, 2010 6:53 pm | |
| Well, based upon the information received from you guys regarding my "non-stop wipers" trouble, I decided to spend part of my spring brake doing the following: PLAN A: Replace the wiper motor. PLAN B: Replace the turn signal level switch( tenneseeautosales@e-bay $159.95). ALL TEN FINGERS CROSS.  | |
 | Subject: Re: Non-Stop Wipers Fri Mar 26, 2010 9:06 pm | |
| Dude, wait until you get the disc, and go through the steps in the manual to test the motor, wiring, and multi-function switch... Plan A: Pull the cover and see if you can check the Park relay & linkage - It might just need cleaning/lubricating. Plan B: Go thru the diagnostic procedure in the manual.  Plan C: Replace whatever part or fix whatever wire is indicated... | |
 | Subject: Re: Non-Stop Wipers Thu May 06, 2010 1:10 am | |
| Luis, I just found out that my PM Inbox was 100% full...
How did the installation go with the disc? And did you fix your problem? | |
 | Subject: Re: Non-Stop Wipers  | |
| Non-Stop Wipers | |
