mrod7510 Member
| Subject: Re: Ported Blower Photos and Stuff 1996 Riv PIC WORK now Thu Sep 09, 2010 1:41 am | |
| those were pieces of aluminum i cut out to fit and weld in. Just so i would not have to fill the slits with weld. | |
mrod7510 Member
| Subject: Re: Ported Blower Photos and Stuff 1996 Riv PIC WORK now Wed Sep 22, 2010 12:14 pm | |
| AFR are 14.6 at idle and soft throttle, 12.5 at full throttle. I'm gonna have some changes made then I'll report results and maybe a video | |
| Subject: Re: Ported Blower Photos and Stuff 1996 Riv PIC WORK now Wed Sep 22, 2010 3:43 pm | |
| - mrod7510 wrote:
- those were pieces of aluminum i cut out to fit and weld in. Just so i would not have to fill the slits with weld.
But they look like they're going to fall out man. You don't want one of those having a jolly old time in the engine......are they glued? JB Welded? I see no evidence of anything. | |
97 park ave Addict
| Subject: Re: Ported Blower Photos and Stuff 1996 Riv PIC WORK now Wed Sep 22, 2010 7:44 pm | |
| even if there is anything holding those from the other side, they still dont look safe. i would secure them from both sides if it were me. | |
Karma Aficionado
| Subject: Re: Ported Blower Photos and Stuff 1996 Riv PIC WORK now Wed Sep 22, 2010 8:42 pm | |
| .. I'll bet you guy anything that that pic is "pre-welding";
since he said "those were pieces of aluminum i cut out to fit and weld in. Just so i would not have to fill the slits with weld."
Trying to fill the gap would need way too much contact time and heat, resulting in distorting the blower, but with the pictured inserts, you can slowly work your way welding around the edges with MUCH less chance of warping the bore. This is the way our blowers are usually successfully welded. I say usually, since the welder needs to have knowledge of welding cast aluminum (which tends to be slightly porous and absorb oils which contaminates the metal reaction in welding) to have success. _________________ | |
mrod7510 Member
| Subject: Re: Ported Blower Photos and Stuff 1996 Riv PIC WORK now Thu Sep 23, 2010 3:17 am | |
| I could not have said it better sir | |
mrod7510 Member
| Subject: Re: Ported Blower Photos and Stuff 1996 Riv PIC WORK now Thu Sep 23, 2010 3:19 am | |
| Air fuels are good. 11.7 WOT and the car feels considerably faster. Street race video coming soon | |
| Subject: Re: Ported Blower Photos and Stuff 1996 Riv PIC WORK now | |
