| 9 inch K&N intake SAWEET | |
T Riley Guru
| Subject: 9 inch K&N intake SAWEET Thu Apr 26, 2007 11:49 pm | |
SpaceBar Aficionado
Name : Patrick Age : 38 Location : Quincy, MA Joined : 2007-04-08 Post Count : 1199 Merit : 3
| Subject: Re: 9 inch K&N intake SAWEET Thu Apr 26, 2007 11:56 pm | |
| Looks good just get some kind of heat shield around that so your not sucking in all that hot air. | |
T Riley Guru
| Subject: Re: 9 inch K&N intake SAWEET Fri Apr 27, 2007 12:04 am | |
| - SpaceBar wrote:
- Looks good just get some kind of heat shield around that so your not sucking in all that hot air.
im ACTUALLY shoving that in the Fender for the FWI so i dont have to worry bout the heat shied i have the parts Working on the time still!!!!!! VERY BUSY at work haha as u can tell with the golf cart vid | |
SpaceBar Aficionado
| Subject: Re: 9 inch K&N intake SAWEET Fri Apr 27, 2007 12:06 am | |
| Well get a light, get off the computer, go outside and get it into the fender. | |
T Riley Guru
| Subject: Re: 9 inch K&N intake SAWEET Fri Apr 27, 2007 12:09 am | |
| - SpaceBar wrote:
- Well get a light, get off the computer, go outside and get it into the fender.
hahahahahhaha do u kno much bout the IAT sensor are those Finiky lil B***** cus my SES light keeps coming on after this!!!!!! GOD....... | |
SpaceBar Aficionado
| Subject: Re: 9 inch K&N intake SAWEET Fri Apr 27, 2007 12:14 am | |
| Mine is on too. I just ordered a new one from autozone going to be in tomorrow.
Try cleaning yours off. If the light doesn't go away you probably broke it like i did taking it out of the stock box and putting it into the new one.
I read that there shouldn't be a problem for a couple days with the light on. | |
T Riley Guru
| Subject: Re: 9 inch K&N intake SAWEET Fri Apr 27, 2007 12:22 am | |
| Subject: Re: 9 inch K&N intake SAWEET Fri Apr 27, 2007 6:38 pm | |
| I have a "slightly modified" stock IAT sensor that works if someone wants to buy. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
SpaceBar Aficionado
| Subject: Re: 9 inch K&N intake SAWEET Fri Apr 27, 2007 6:47 pm | |
| Wish I knew that I'm going to pick up the one at autozone I bought soon What is slightly modified about it? | |
| Subject: Re: 9 inch K&N intake SAWEET Fri Apr 27, 2007 7:03 pm | |
| I shaved the diameter down to fit in my threaded FWI mount. It could be epoxied into a stock air box, or could use in FWI tube with some help. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
T Riley Guru
| Subject: Re: 9 inch K&N intake SAWEET Sun May 06, 2007 10:21 am | |
| o.k. its in the fender u guys happy now??? no pics for u!! | |
NO 4 EVR Addict
Name : Troy Age : 39 Location : Sylvania, OH (Toledo) Joined : 2007-01-26 Post Count : 645 Merit : 1
| Subject: Re: 9 inch K&N intake SAWEET Sun May 06, 2007 11:25 pm | |
SpaceBar Aficionado
| Subject: Re: 9 inch K&N intake SAWEET Mon May 07, 2007 6:43 pm | |
| Subject: Re: 9 inch K&N intake SAWEET Mon May 07, 2007 8:50 pm | |
| everyone left the fender liners on after the FWI install right? | |
SpaceBar Aficionado
| Subject: Re: 9 inch K&N intake SAWEET Mon May 07, 2007 9:00 pm | |
| - turtleman wrote:
- everyone left the fender liners on after the FWI install right?
I hope so or your engine is going to be sucking in lots of water the first time it rains. | |
T Riley Guru
| Subject: Re: 9 inch K&N intake SAWEET Mon May 07, 2007 11:45 pm | |
| Subject: Re: 9 inch K&N intake SAWEET | |
