 FWI installed
NO 4 EVR
98riv65lark
17 posters
FWI installed - Page 2 Empty
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyWed May 02, 2007 6:56 pm
Nice to see all the different types of FWIs. They all look great!
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyWed May 02, 2007 7:40 pm
dude idk why but it looks like you guys have so much more room between your throttle body and that opening.. my engine is from an impala, but should still be the same size I suppose... when I made my fwi, there wasn't enough room between the 45 off the tb, and the other 45 to put a straight peice like you guys did, mines just 45, 45, then 90 down into the hole with a 4 inch straight peice on that
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyWed May 02, 2007 7:48 pm
I had trouble when I tried the pvc pipes too. I couldn't get it to fit in there. I'm guessing you should have the same size considering its the same engine though?
Why is your engine from an impala did yours die?
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyWed May 02, 2007 10:12 pm
well the previous owner had it swapped when the oem 3800 died
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyThu May 03, 2007 6:45 am
Mine is tight, you'll notice the 45 going into the reducer isn't exactly straight. It's slightly cocked to make the angle needed to get to the opening in the FW.
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyThu May 03, 2007 4:40 pm
same with mine, but even with it like that, there was still 0 space between the 45's
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyThu May 03, 2007 11:38 pm
jax and rhino can you tell me exactly what parts you used on your intakes. i'd like to make one like yours. another dumb question - do you have to expand the size of the fender passage from the engine compartment for yours to work or could i use 3in plumbing for example and not have to mangle my engine bay
98riv65lark
98riv65lark
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 5:13 am
turtleman I used a 3" pipe for my intake and it seemed to fit fine. HOWEVER, Im not quite sure how Im going to seal everything without enlarging the whole.
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 6:39 am
This is the link I used as an example to build my intake. I went through the top instead of through the fender well though. I didn't want to rip my fender well apart everytime I wanted to clean my filter. So, I probably took more material off enlarging the hole for my filter. IF you are going to do it the way I did, I suggest using air tools. It makes the job much easier. I used a 7" filter which is pleanty big enough. I still had to remove the horn. Three inch pipe should work fine with minimal trimming. I also used black bumper paint. It worked with the pvc well and it was more of satin or semi gloss finish.
https://rivperformance.editboard.com/Supercharged-3800-Tech-c2/Series-II-Engine-Transmission-f4/Write-Up-4-FWI-t107.htm
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 10:50 am
basically, I followed jason's guide, and used the same materials he did.
4 inch to 3 inch rubber reducer on the tb, 4 inch 45 degree bend off the tb, 45 degree from that, 90 degree bend going into the fender well . I only ended up using maybe 4-5 inches of the 2 foot pipe though, and I used that on the end of the 90 going into the fender well with a 4 inch to 3 inch reducer with the filter on the end of that. and yeah, if you want to use 4 inch piping you'll need to expand the fender well hole a couple of inches on two sides. almost everyones will come out different I think, i'm not sure if anyone used reducers on theirs.. I just found it much easier, although my filter sits alot lower then everyone elses, and I removed a small peice of plastic for optimum air flow.. just going to have to be careful driving in the rain or washing my car.
I had to cut maybe 3 inches off of the second 45 bend to land the 90 directly into the fender well, but again, mine came out different then others.
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 11:34 am
Guys, how is the transition inside your 4x3 reducers? Is there a sharp line protruding out into the air flow? We happen to sell 3x2 rubber reducers, and looking at them, I see the inside has a sharp-edged "ring" protruding at the transition point. I would think that it could be trimmed down fairly easily for smoother flow.
Now I'm not thrilled with the idea of cutting my stock fenderwell opening in order to fit a 4" pipe... wouldn't a 3" FWI pipe provide a significant improvement over the stock airbox also? 4" would be nice, I admit, just don't like the idea of cutting.
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 11:47 am
cutting the hole sounds alot worse then it really is. all I did was open it up maybe 2-3 inches on two sides, and if you ever want to sell the car stock, you can always pick up some aluminum and just weld a few strips in, no problem. and yeah a 3 inch would still provide a considerable improvement over the stock airbox
NO 4 EVR
NO 4 EVR
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 2:37 pm
Well wouldnt the stock airbox cover that hole? Or you could just sell it w/ the fwi on and explain that to them. either way I am sure it wouldnt look bad if you do it right. How did you open yours up?
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 2:54 pm
If you cut using a pattern, and you're neat about it, I bet it's hard to tell it's not stock. But like Troy said, the stock air box would cover it up.
In my experience, the hole is big enough as is to flow enough air for most of our cars. My 3.5" FWI tapers down to 3" to fit through the stock hole, and I'm getting plenty of air for my set up.
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 2:59 pm
i used a saw-z all, then filed down the rough edges
NO 4 EVR
NO 4 EVR
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 3:47 pm
I see
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 4:07 pm
Here I am complaining about cutting my FW, and what do I do 30 minutes later??? STOP AT HOME DEPOT AND BUY 4" STUFF!! smile
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 4:18 pm
I can also get a 60deg elbow at Home Depot, wonder if that would be TOO much of a bend?
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 4:43 pm
I dunno Dave, I had to do some head scratching when I was putting it together. My biggest concern was getting the hole in the right place. I didn't want some huge opening. IF I ever sell the car, the old air box will cover the hole no problem. I chain drilled the hole as much as I could and then used a 90 degree sander/grinder to clean up the rest. It's not a hard job. If I can do it, anyone can. Buy the 60 along with the other pieces and take it back if you don't need it.
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 5:16 pm
I have to go back anyway, forgot the FxF 45 elbow first stop, may as well bring home a 60 to try out.
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 5:26 pm
see lol, everyones ends up different :> I stared at mine for quite some time before it all fell into place
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 9:48 pm
When you keep reading all this stuff everyday it just sticks in your head and you have to do it. wink
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptyFri May 04, 2007 11:03 pm
Man, ain't that the truth!
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptySun May 06, 2007 8:50 pm
FWI installed - Page 2 DSC01363
FWI installed - Page 2 DSC01362
FWI installed - Page 2 DSC01365
not painted yet but I am very pleased with the results. Noticably more power after it heats up than with my cone filter on T.B. and this is just as loud!
GREAT MOD!
PostSubject: Re: FWI installed   FWI installed - Page 2 EmptySun May 06, 2007 8:53 pm
Looks good! I love the new sound of mine and of course the new power. wink
FWI installed
» Cam INSTALLED
» Write-Up: Building a Custom PVC Fenderwell Intake
» NEW CARB FOR MY 307 I INSTALLED
» 3.4 " Pulley Installed....
» Write-Up: Installing SLP Exhaust Headers
