 series 1 s/c and na
4 posters
Merit : 17
series 1 s/c and na Empty
PostSubject: series 1 s/c and na   series 1 s/c and na EmptyWed Feb 09, 2011 2:12 pm
What are the differences between the series 1 l27 and the series 1 l67 besides the fact that the l27 has a supercharger?
Merit : 17
PostSubject: Re: series 1 s/c and na   series 1 s/c and na EmptyWed Feb 09, 2011 2:13 pm
l67* has super charger
PostSubject: Re: series 1 s/c and na   series 1 s/c and na EmptyWed Feb 09, 2011 2:32 pm
Really the only thing that differs between the 2 is the compression ratios (higher on the N/A engine), and the upper/lower Intake manifolds. Everything else is pretty much the same except for a couple of wiring harnesses and the PCM.
Merit : 17
so how difficult would it be to supercharge?
Merit : 123
PostSubject: Re: series 1 s/c and na   series 1 s/c and na EmptyWed Feb 09, 2011 3:48 pm
Rods and bearings in the l27 don't like boost. People have done if, but never successful for long.
http://www.pontiacbonnevilleclub.com/forum/viewtopic.php?f=44&t=194
If you are set on the l27 then turbo it. But for the money and effort, just swap in a series 2 SC. Its cheaper than even throwing in a series 1 SC. Series 2 SC should be able to go in whatever you've got if you take the wiring harness and PCM.
PostSubject: Re: series 1 s/c and na   series 1 s/c and na EmptyWed Feb 09, 2011 7:25 pm
L27 + supercharge = eventual fail.
L67 is what it is because of an over-engineered bottom end. I was told but can not verify that the L67 bottom end can take well over 900 (brake) horsepower.
If you look around a bit odds are you'll find an L67 in a junked oldsmobile 88LSS or 98, or a forgotten high end Buick Century, or a plushed-out Bonnevile just waiting for you for short money. Try phoning these guys:
http://www.horseheadspickapart.com
and ask if they have any GM cars with the supercharged 3800 sitting in the yard. They usually have 2 or 3 at a time that are rebuildable. Check price. Then try a junkyard near you and use the price you got to work 'em down -- IF you are prepared to buy. Cash talks.
series 1 s/c and na
» FAQ: Series I to Series II / Series III Engine Swap
» 95 Series I with Series II parts from factory, any external indicators?
» 1995 prototype riv swap series 1- series II
» Starter problem?
» series 2 parts on series 3 engine
Riv Performance ::   N/A 3800 Tech :: Pre-Series I Engine & Transmission-
