Natesriv Addict
Name : Nate Age : 53 Location : KCMO Joined : 2007-01-18 Post Count : 509 Merit : 16
 | Subject: new low note horn ? Tue Dec 04, 2012 1:58 pm | |
| Is it possible to mis-wire a new horn? I bought a replacement low note horn and had to cut the factory plug. So I just put connectors on the wires, plugged into horn and put it all back together.
HOWEVER, from outside, it sounds decent...but inside it's an odd reverb sound...very un-horn like.
Possible that I need to switch the + and -?? Or does that even matter?
Thanks!
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8529 Merit : 181
 | Subject: Re: new low note horn ? Wed Dec 05, 2012 3:20 am | |
| the new horn might be a different low note than the old. | |
Natesriv Addict
 | Subject: Re: new low note horn ? Wed Dec 05, 2012 9:10 am | |
| it is.. I think i'll unhook the high note to hear the low by itself. but can the + and - be wrong? ...I can switch them too.. just curious. inside, it sounds like they're under water!  | |
 | Subject: Re: new low note horn ? Wed Dec 05, 2012 12:58 pm | |
| - Natesriv wrote:
- it is.. I think i'll unhook the high note to hear the low by itself.
just curious.
inside, it sounds like they're under water!  Used to be horns had metal cases and the (-) was the case. So if you wired backwards you'd have a short and blow a fuse. If polarity is important it will be marked on your new horn. Typically the (-) is not an insulated terminal and the (+) is - again, if it matters. Now if you are concerned about phasing the waveforms, that is a little trickier. The first thing I would do is figure out what not the horns are each playing and then figure out what the interval is. Play it on a piano to get an idea what it could sound like. It may be that you just don't have a euphonic interval. My D Eb A F horn sounds kind of snarly, actually. Thing that amuses me is the mecahnics at the local GM dealer like to blow it (more than they need to) when the car is in for service. Don't need to guess at which horn it is... sounds like an Alto with an attitude... | |
Natesriv Addict
 | Subject: Re: new low note horn ? Thu Dec 06, 2012 12:07 pm | |
| I'm going to unhook the OEM high note and hear the low by itself. I think it's a combo of non metal resonance and the waves from both interacting.
I did buy a big double air horn, LOUD...but there's no room under the hood for it.
 | Subject: Re: new low note horn ? Thu Dec 06, 2012 2:52 pm | |
| You might mount that air horn behind the radiator. Be sure to use stainless hardware so you can remove and reinstall for service. Also it maybe might fit n place of one or the other OE horn if you take OE horn out. | |
 | Subject: Re: new low note horn ?  | |
