 traction control problem or abs not sure
4 posters
Rivieraz
Rivieraz
traction control problem or abs not sure Empty
PostSubject: traction control problem or abs not sure   traction control problem or abs not sure EmptyMon Sep 23, 2019 11:20 pm
95 buick Riviera just turning 100,000 miles new tranny fuel lines brake lines water pump shock struts wires plugs coils, driving in the rain 2day and notice when my front tires start slipping it caused a low humming sound in the engine bay like a transformer going bad on a telephone pole(that's the best way I can describe the sound) it only does it when the front tires are slipping. any suggestions would help...they always do here!!also no codes are lit up
PostSubject: Re: traction control problem or abs not sure   traction control problem or abs not sure EmptyMon Sep 23, 2019 11:39 pm
When the road had snow or ice and caused my front wheels to slip during take off I got a loud noise from what I thought was the Traction Control Unit.
It never triggered a light or code and it drove fine otherwise, so I didn't concern myself with it.
I never had an issue in rain, maybe because I always had new or near new tires on it so they didn't slip in the rain. If your trying to go full throttle from a stop in the rain while your trying to turn into traffic maybe you'll get the Traction Control System to bark at you. I don't know. Are your tires bad.?
Rivieraz
Rivieraz
PostSubject: Re: traction control problem or abs not sure   traction control problem or abs not sure EmptyTue Sep 24, 2019 1:49 am
my tires are fine and as soon as the tires stop slipping the noise stops immediately I imagine it will do it in the snow for sure, also I can drive from 0 to 60 with no problems,noise only occurs when tires slip
Merit : 149
PostSubject: Re: traction control problem or abs not sure   traction control problem or abs not sure EmptyTue Sep 24, 2019 11:37 am
The traction control pulses the ABS the same way is if you were in a skid. The noise is the ABS motor, it's normal.
Merit : 180
PostSubject: Re: traction control problem or abs not sure   traction control problem or abs not sure EmptyTue Sep 24, 2019 4:51 pm
That buzz is the ABS *working* as Larry pointed out, it is not silent or even quiet on these cars.
Be sure to replace your brake fluid every couple years to avoid having rust form in the ABS unit.
Rivieraz
Rivieraz
PostSubject: Re: traction control problem or abs not sure   traction control problem or abs not sure EmptyTue Sep 24, 2019 7:28 pm
ty everyone!best site ever!
» FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On
» Traction Control???
» Traction Control Keeps going off
» something with traction control
» Traction Control module
