| Traction Control??? | |
+10Mikel albertj LARRY70GS charlieRobinson scoopy03 SpaceBar Mr.Riviera AA 97rivman BoattailBob 14 posters |
BoattailBob Fanatic
Age : 57 Location : Bay Area, California Joined : 2007-06-05 Post Count : 268 Merit : 0
| Subject: Traction Control??? Wed Jun 27, 2007 6:29 pm | |
| So Ive started to do some work on my 97. Just the basic tuneup, oilchange, gutted airbox. I can already feel more power and the car is loving it. BUT...Yesterday I jump on it to see how these tires break loose and as soon as it breaks I get this horrible skipping (for lack of a better term) sensation from the front end. So I figure, oh I forgot to take traction control off. I do that.....and no difference. Feels like something is wrong with the steering as well. Like there's more resistance than there should be, especially at the extreme right or left but this may not be related.
I plan on getting it up on a lift this weekend and having a look. Anyone else experience this? It sounds bad but feels worse. | |
97rivman Fanatic
| Subject: Re: Traction Control??? Thu Jun 28, 2007 12:45 pm | |
| Maybe ABS is malfunctioning? That could cause the symptoms you're experiencing. Not common for ABS to fail though. Does the traction light ever come on by itself? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
97rivman Fanatic
| Subject: Re: Traction Control??? Thu Jun 28, 2007 12:52 pm | |
- Maybe ABS is malfunctioning? That could cause the symptoms you're experiencing. Not common for ABS to fail though. Does the traction light ever come on by itself?
better yet, does it ever not go off? | |
BoattailBob Fanatic
| Subject: Re: Traction Control??? Thu Jun 28, 2007 4:11 pm | |
| As far as I can tell when I turn it off, it stays off. at least that's what the light is telling me...yet it seems like it's still on. The traction light has never come on by itself. | |
| Subject: Re: Traction Control??? Thu Jun 28, 2007 5:03 pm | |
| brake fluid low or recently flushed? and by skipping do you mean wheel hop? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
97rivman Fanatic
| Subject: Re: Traction Control??? Thu Jun 28, 2007 5:56 pm | |
| thats how mine was, its meant for old people, Buick never intended for people like us to actually drive these. I havent gotten into my VCM yet, but assume the traction control is much more "stiff" than other cars. | |
| Subject: Re: Traction Control??? Thu Jun 28, 2007 6:20 pm | |
| Remember when the TC is turned off, it's still on, but to a lesser extent. The only way to disable it totally is to pull the fuse. The ABS one I think? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
BoattailBob Fanatic
| Subject: Re: Traction Control??? Thu Jun 28, 2007 7:22 pm | |
| By skipping I did mean wheel hop, at least that's what it feels like, but I let off as soon as I felt it so it was pretty quick to tell for sure. I haven't changed the brake fluid yet, only had the car a few weeks but the fluids all look clean and full. I guess I could pull the fuse and see, I didn't realize it was still on when you press the off button...really I'm not out to just smoke the tires I was just testing its capabilities and then found something I wasn't expecting. Thanks for the help guys | |
| Subject: Re: Traction Control??? Thu Jun 28, 2007 7:45 pm | |
| Careful trying to spin tires. One-wheel burn-outs = #1 killer of auto transmissions. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
BoattailBob Fanatic
| Subject: Re: Traction Control??? Fri Jun 29, 2007 11:03 am | |
| Yea I agree with that. Just want to find out what the problem is, if there is one at all. I'll see what it looks like underneath this weekend. There's definately something going on with the steering. gonna change out fluids this weekend too. | |
SpaceBar Aficionado
| Subject: Re: Traction Control??? Fri Jun 29, 2007 7:11 pm | |
- Careful trying to spin tires. One-wheel burn-outs = #1 killer of auto transmissions.
Why is that? | |
| Subject: Re: Traction Control??? Fri Jun 29, 2007 8:54 pm | |
| too much strain on the differential for FWD cars _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
SpaceBar Aficionado
| Subject: Re: Traction Control??? Fri Jun 29, 2007 10:38 pm | |
| - Mr.Riviera wrote:
- too much strain on the differential for FWD cars
Is there a "safe" point for smoking them? I read to "spin" the tires for a couple seconds at the track when you get lined up to clear off the dirt... | |
| Subject: Re: Traction Control??? Fri Jun 29, 2007 11:02 pm | |
| smoking tires is never "safe", something could always go wrong and snap! (but you could just as easily frag a piston half way down the track) but as long as both tires spin up freely you will be fine 95% of the time. when you floor it going thru a turn or burn out only 1 wheel it puts strain on the diff. also if you try to burn out with drag slicks on stock diffs they can and will sometimes shatter due to the extra torque required to initaly start moving the sticky, wrinkled rubber.(maybe not the right set of adjatives to describe tires ) even vettes blow chunks of their rear diff at the track sometimes. the best and safest way to do a bunout IMO, is to hit peak torque as fast as possible (either by torque braking or just jabbing the gas 3/4 way) so that the tires easily start spinning with little resistance. it problably puts undue stress on parts when/if you hold the parking brake, so i dont do that. there is enough power you should need to either _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Traction Control??? Sat Jun 30, 2007 1:23 am | |
| Good advice.^^^ I use the E-brake to keep from throwing the car forward. As long as you punch it real good from a stop, both wheels should brake loose. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
scoopy03 Amateur
| Subject: Re: Traction Control??? Tue Jul 17, 2007 1:26 pm | |
| yea but at the track you cant be launching 100ft during the burnout, so it's more like this...
http://www.3800pro.com/movies/Tires_On_LSD.wmv _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
97rivman Fanatic
| Subject: Re: Traction Control??? Tue Jul 17, 2007 1:37 pm | |
| - Mr.Riviera wrote:
- yea but at the track you cant be launching 100ft during the burnout, so it's more like this...
http://www.3800pro.com/movies/Tires_On_LSD.wmv Todd (the owner of the car) had it chained to a dumpster in the backround. I know this because of the way it pulls, and someone told me. 2 of my friends had to hold back my 06 monte 3.9, with the e-brake on, and bricks infront of the back tires just to get it to stay put. It can be done, I did a nasty burnout at the track once, and there was so much smoke that by the time i made down half track, my whole car instanly fogged up. You gotta juice that torque, or brake torque it real fast in the water. | |
charlieRobinson Expert
| Subject: Re: Traction Control??? Tue Feb 14, 2012 8:37 am | |
| Hope this is the place to ask but.. I have noticed this lately whenever I lost traction and especially today with the snow. Whenever I lose traction I hear a motor/mechanical noise from the drivers side of the car. It sounds like a robotic cat growling. Does anyone know what this is and if it is functioning properly by growling every time I lose traction? Is it the ABS or something to do with traction control? Anyone know what I am talking about? | |
| Subject: Re: Traction Control??? Tue Feb 14, 2012 9:53 am | |
| Sounds like traction control/ABS doing their thing. All cars with these systems make these sounds, especially the older ones. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Traction Control??? Tue Feb 14, 2012 10:05 am | |
| What exactly is it? It sounds like a motor of some sort. Where can I read/learn more about it?
So that robot cat growl is a normal sound it makes? nothing to worry about? | |
| Subject: Re: Traction Control??? Tue Feb 14, 2012 10:06 am | |
| It's the ABS pump. It is a kind of hydraulic pimp motor, engaging and disengaging the brakes faster than you can. You notice it more in snow because the wheels are loosing traction. Nothing to worry about. Only worry if you don't hear the noise. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Traction Control??? Tue Feb 14, 2012 11:08 am | |
| I believe the PCM runs a diagnostic on the ABS/TC every time you start the car. I feel it in the morning sometimes where the ABS buzzes the brake pedal for a split second. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Traction Control??? Tue Feb 14, 2012 11:51 am | |
| The noise just startles me. It definitely sounds like something is not right but I guess that is just the noise the ABS pump makes? If I turn off Traction Control would that affect the ABS at all?
If that noise is the ABS pumping the breaks then what does Traction Control do that is different? You guys should know that I am total noob by now, so please forgive my elementary questions. I just really want to get familiar with my car. | |
| Subject: Re: Traction Control??? | |
