Why take the belt off at this point? It's out of the way.
OK, did you get the balancer bolt loose?
My neighbor's got that impact wrench (or an earlier model). We're going to work on it tomorrow.
I've got a new harmonic balancer bolt too. I should be able to get up to the case learn part. Hopefully I can do it without a Tech 2, but if not, I know a guy who has one.
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23Post Count : 2184 Merit : 149
I never did a case learn when I replaced my crank sensor. Never had a problem. Maybe you'll be OK.
The DeWalt wasn't strong enough to break the bolt loose, but I scored a free air compressor and now I'm playing with an air impact wrench. How do you torque to 200 ft/lbs? I haven't found a 200 ft/lb torque stick yet.
The above wrench will zip a 3800 balancer bolt off in seconds.
When I did my timing cover R&R, I marked the bolt with a straight line and two hash marks on the ID of the balancer so I had a reference to where the bolt was tightened to. My engine builder torqued that bolt so I knew it was correct. There are 3 power levels on the Dewalt. I turned it up to 3 and hit it for about 5 seconds. It tightened the bolt beyond where it was. I've used my Dewalt on flexplate to crank bolts installed with red locktite. On alternator pulley bolts, and most frequently on lug nuts. It makes short work on all of it, with ease.
How do you torque a bolt to 200 ft. lbs? You max out your torque wrench, then put a pipe over it and lean on it as hard as you can. For the Buick 455, the spec is 200 ft. lbs. MINIMUM.
Mine got zipped on with an impact wrench many years ago, same bolt. Not going to worry about it now.
I think it is relatively easy to lock the flexplate, use a torque wrench to 111 ft. lbs, then mark a reference line on the bolt and figure out what 76* is and tighten it that much more.
90* would be 1/4 of a full turn. A little bit short of that.
I finally managed to get the bolt out. My neighbor looked at the air compressor and gun and confirmed everything was set up right. I hit the bolt for a solid minute and didn't budge it. I had to fall back on the starter motor trick and that did it, after four tries. My neighbor was watching and was alarmed at how much the engine was pushed up by the starter motor trying to break that bolt loose. I hope I'm not in for new motor mounts now, I'm sure that's not good for them. He thought the pry bar (the end with the socket) might have smacked the inside of the sub frame too. I haven't inspected that area for damage yet, but I noticed the brake lines are helpfully located in that area when I installed the pulley puller.
Once I had the bolt out, I noticed a slight discrepancy between the old bolt (bottom) and the new bolt (top) -
Found a video about changing the crankshaft sensor. I think at one point he said the rpms were off by 300 without a case learn, but it ran. A couple of the commentors were not so lucky though.
Has anyone had this problem mentioned in the comments -
When you install the sensor, there is usually an adjustment screw which holds the sensor in place. This is so to cure any impact of the balancer upon the sensor when the harmonic balancer spins. If you do not check for spacing, you will ruin the sensor in short order.
Further down I found this -
btw, the 2 previous GM 3.8s I replaced crank position sensors on never had a case learn on them and they went years with no problem so I been told the case learn is really for older cars with the older style ECM.
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Tue Sep 15, 2020 12:52 am
What about the thread locking compound on the sensor bolts (white) and on the harmonic balancer bolt (orange)? The YouTubers aren't replacing it.
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Tue Sep 15, 2020 9:24 am
RTFM he he.
Even if the manual did not call for threadlocker I'd at least use Loctite Blue. That thing popping off for that reason (loosening in service) would be, well, catastrophic.
NAPA says they no longer stock the harmonic balancer bolt. The hunt for what should be a very common part continues . . .
Regarding the FSM, it leaves a lot to be desired. Usually the forum or YouTube are more useful.
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Wed Sep 16, 2020 11:20 am
Looking at the FSM regarding the crankshaft balancer bolt, it says to see "fastener notice" in "General Information." There are sections about fasteners in General Information, but not a "fastener notice" section. In the "Metric Fasteners" section, it says not to use thread lockers or sealant unless the FSM specifically calls for it. The FSM does not call for thread locker or sealant on the CPS sensor studs or on the crankshaft balancer bolt. Even though they had/have something on them when I pulled them
I have never used thread locker on a crank bolt. Just torqued it to spec.
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Thu Sep 17, 2020 8:39 am
The GM ones I've seen came with a red dry threadlocker actually under the washer at bolthead. The NAPAones I've seen are naked. Given the direction the crank spins I doubt you'd 'need' threadlocker, but the presence on the OE bolt would have me using a little loctite blue on say a NAPA bolt. Blue does not require a torch to loosen/disassemble.
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Thu Sep 17, 2020 8:46 am
I know some guys will put some RTV under the washer. Had the director of my club tell me he does that.
