| Engine cooling | |
maggot Member
Name : Chris Age : 37 Location : Beaumont, TX Joined : 2007-05-01 Post Count : 75 Merit : 0
| Subject: Engine cooling Wed Oct 24, 2007 4:57 pm | |
| my 95 riv with 50k on it has a 180 thermostat, i noticed after i put it in that it will stay around 180 when im driving no matter how hard or easy i am on the engine, but when i stop and idle for a while whether im at a stop light or a food place, the temps sometimes jumps up to like 210 or 215, but one i start driving it again it lowers back. anybody have any ideas? | |
| Subject: Re: Engine cooling Wed Oct 24, 2007 5:11 pm | |
| Lack of air flow while sitting is the reason it heats up. The solution is changing the fan turn-on settings to take advantage of the 180 t-stat. A 180 t-stat does not mean your engine will run at that temp. That's just the temp the t-stat will start to open. I don't know what options you have for making that change on a 95. | |
| Subject: Re: Engine cooling Wed Oct 24, 2007 6:06 pm | |
| Your description is normal. 210F is high, but not dangerous. You could wire a manual fan turn on switch to cure the problem. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Northeast Member
Name : Joined : 2010-09-14 Post Count : 84 Merit : 1
| Subject: Re: Engine cooling Tue Jun 07, 2011 10:52 am | |
- Your description is normal. 210F is high, but not dangerous. You could wire a manual fan turn on switch to cure the problem.
Any schematic or write up on this? I'm assuming you are just tapping into the existing fan wire harness, but need to know which wires to piggy back off of. | |
| Subject: Re: Engine cooling Tue Jun 07, 2011 12:08 pm | |
| Yes, I don't think it's that big of a deal to be concerned with until you are at 220º, at which point the fans should turn on. If you were racing the car, or had some other reason to keep it extra cool, the switch could be wired directly at the fan's connectors. Sorry, I don't know which wires these are. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Northeast Member
| Subject: Re: Engine cooling Tue Jun 07, 2011 12:16 pm | |
- Yes, I don't think it's that big of a deal to be concerned with until you are at 220º, at which point the fans should turn on. If you were racing the car, or had some other reason to keep it extra cool, the switch could be wired directly at the fan's connectors. Sorry, I don't know which wires these are.
Engine temp doesn't get above 205ish, but the trans definitely does ( shares the same radiator, which could hinder the cooling to the engine) My trans can get up to 220+ in the summer from with few WOT pulls real fast. Not that big of a deal, but would love to be able to kick the fans on manually if in traffic to keep the temps down. | |
| Subject: Re: Engine cooling Tue Jun 07, 2011 1:14 pm | |
| On long drives, and hot days, nothing can keep trans temps below 220ºF except for a separate trans cooler. I installed a 180º t-stat + tuned both fans to come on at 185ºF, and still the trans will get hot. I finally went with a rather large trans cooler (not too expensive) and now trans temps will usually not go above 190º, and hardly ever over 200º, even pulling a trailer. Here's the write-up: https://rivperformance.editboard.com/t1748-write-up-transmission-cooler-install_________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Northeast Member
| Subject: Re: Engine cooling Tue Jun 07, 2011 1:59 pm | |
| So the change to the fans didn't indirectly keep the trans temps down? Ok, thats good info.
I was thinking of a trans cooler, but I'm not towing...and 220/230 is about operating temp, so Ill just keep an eye on it for now. Thanks AA. | |
| Subject: Re: Engine cooling Tue Jun 07, 2011 2:07 pm | |
| Mine was topping out around 220ºF before, I think that's within acceptable operating temp. If you're concerned, change the fluid every year or 25k miles - cheap insurance. A cooler will delay the temp climbing, and ultimately cap the peak to around 200ºF. I would also add I'm not using TCC lock-up anymore, so that says a lot for the trans cooler. Tours might run well below 200º. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Northeast Member
| Subject: Re: Engine cooling Tue Jun 07, 2011 2:13 pm | |
- Mine was topping out around 220ºF before, I think that's within acceptable operating temp.
Yes, thats within the normal operating temp. Although your trans is much better than mine (I have a 96, so non-HD) | |
RidzRiv Addict
| Subject: Re: Engine cooling Tue Jun 07, 2011 2:21 pm | |
| you could also get a tune from sinister like robotennis did, and have your fans settings changed, probably a more expensive idea, but if you wanted the tune, it would be a good thing to add on. | |
Northeast Member
| Subject: Re: Engine cooling Tue Jun 07, 2011 2:32 pm | |
| - RidzRiv wrote:
- you could also get a tune from sinister like robotennis did, and have your fans settings changed, probably a more expensive idea, but if you wanted the tune, it would be a good thing to add on.
True, but I'd rather wire in a manual switch for $1.00, than tune the PCM just for that, but AA is saying the lower fan setting didn't affect the trans temp too much. Im going to remove the weather stripping to see if this reduces engine bay temps at all. | |
| Subject: Re: Engine cooling | |
| Engine cooling | |
