 LIM coolant elbow!
bunchabuix
brutusk1
96_Juggernaut
bmcd9179
96rivie
Natesriv
crstump
Dave1998riv
2000ws6transam
96scriviera
BrianEsser
Nez
moldymac
Joby70739
BillBoost37
38 posters
Go to page : Previous  1, 2, 3, 4, 5, 6
LIM coolant elbow! - Page 6 Empty
PostSubject: Re: LIM coolant elbow!   LIM coolant elbow! - Page 6 EmptyFri Feb 13, 2015 11:04 pm
I definitely agree with Daymon , mine was stuck on there pretty good as well. I managed to remove it after spraying down with pb blaster and wiggling around while yanking on it. You need to pull evenly on it. Also make sure you don't leave any of the old elbow in the manifold because It usually falls apart.
Mikel
PostSubject: Re: LIM coolant elbow!   LIM coolant elbow! - Page 6 EmptyFri Aug 25, 2017 10:31 am
I just did mine. I was surprised at how easy it was.
Merit : 180
PostSubject: Re: LIM coolant elbow!   LIM coolant elbow! - Page 6 EmptyFri Aug 25, 2017 12:01 pm
...as long as it does not break. Many tensioners come with the LIM coolant elbow to replace. Replacing it that often probably reduces the problem.
Mikel
PostSubject: Re: LIM coolant elbow!   LIM coolant elbow! - Page 6 EmptyFri Aug 25, 2017 1:17 pm
Oh, mine broke bonk
Luckily I was able to extract the broken piece fairly easily.
Merit : 180
PostSubject: Re: LIM coolant elbow!   LIM coolant elbow! - Page 6 EmptyFri Aug 25, 2017 6:35 pm
Mikel wrote:
Oh, mine broke bonk
Yes, it is not difficult. for people doing the job the first time it is frustrating.
Mikel
PostSubject: Re: LIM coolant elbow!   LIM coolant elbow! - Page 6 EmptyFri Aug 25, 2017 7:16 pm
What did help tremendously is that I have another L67 in my garage and I was able to see what the bracket looked like and where all the bolts are, which are really obscured while the engine is in the car. Once you see that, it is very easy.
I can take a photo of that engine, if it will help someone.
Mikel
PostSubject: Re: LIM coolant elbow!   LIM coolant elbow! - Page 6 EmptySat Aug 26, 2017 3:33 pm
This is my junk L67.  After the alternator is removed, the bracket in yellow is the one that holds the elbow in place. There is a coolant inlet at the bottom that goes into the water pump mounting that also uses an o-ring (replace too). Bracket is held by three bolts (in red) and can be detached by moving it towards the passenger side once bolts are removed.
LIM coolant elbow! - Page 6 13jScIk
1997riv
PostSubject: Re: LIM coolant elbow!   LIM coolant elbow! - Page 6 EmptySat Aug 26, 2017 4:51 pm
Sorry if this has already been suggested, I don't think I've read the whole thread.  When I replaced mine I bought the kit that comes with both elbows (doesn't the Grand Prix have 2 elbows?).  The inlet that is built into the tensioner where the second elbow would normally go is the same size as the second elbow in the kit, so I just robbed the oring off the other elbow in the kit and put it on my tensioner. thumbsup
PostSubject: Re: LIM coolant elbow!   LIM coolant elbow! - Page 6 EmptyWed Aug 07, 2019 10:02 am
Jason wrote:
LIM coolant elbow! - Page 6 Vacuum
Is this a series 1 fitting?  Jason had a 98, so it should be series 2, but my series 2 has an "L" fitting in good, supple condition.  Here's what I've got -
LIM coolant elbow! - Page 6 Y3sw65fw
Pretty different huh? What's going on here?
PostSubject: Re: LIM coolant elbow!   LIM coolant elbow! - Page 6 EmptyFri Aug 09, 2019 6:15 am
Don't know about that, but I wouldn't worry at all about having less rubber hoses under the hood that could dry out and crack.
Who knows what he had with all the mods he did. Yours is obviously OEM because you haven't changed or modified anything.
Don't sweat the small stuff, focus on what needs to be done at the moment.
I don't have a perfect memory but I believe my 98 was just like yours.
Rick
LIM coolant elbow!
Page 6 of 6Go to page : Previous  1, 2, 3, 4, 5, 6
» Vacuum elbow
» Coolant in Oil vs. Oil in Coolant
» coolant lose
» Low Coolant light, intermittent behavior?
» Coolant over flow
