 Diary of a Dying Transmission
urbsnspices
BillBoost37
dennycrane
blackbart95
TType_Riviera
22 posters
Diary of a Dying Transmission - Page 4 Empty
PostSubject: Re: Diary of a Dying Transmission   Diary of a Dying Transmission - Page 4 EmptyFri Aug 21, 2009 12:55 pm
Also the bores in the valve body itself that each cylinder from the solenoids
fits into get scored and require rework or replace the whole valve body.
This happened to mine.
BillBoost37
Merit : 26
PostSubject: Re: Diary of a Dying Transmission   Diary of a Dying Transmission - Page 4 EmptyFri Aug 21, 2009 1:31 pm
The valve body contains a few valves and solenoids that control nearly everything in the transmission. A solenoid opens and the fluid flows through another passage then pushes a clutch piston to engage the clutches of the next gear. If the valve bores are worn and sloppy the fluid won't fill the area and engage the piston as quickly or fully as it should.
A valve body can typically be rebuilt/upgraded to all the latest stuff. However there are special tools required for some of the updates.
Sorry to ramble...
PostSubject: Re: Diary of a Dying Transmission   Diary of a Dying Transmission - Page 4 EmptyMon Nov 16, 2009 10:05 am
I wonder how many miles AA has got on his stock rebuild now? It must be considerable.
PostSubject: Re: Diary of a Dying Transmission   Diary of a Dying Transmission - Page 4 EmptyMon Nov 16, 2009 11:49 am
42,000 miles so far on the rebuild (5¢/mile or $3/day).
PostSubject: Re: Diary of a Dying Transmission   Diary of a Dying Transmission - Page 4 EmptyMon Nov 16, 2009 2:36 pm
Have you reprogrammed the shift yet?
PostSubject: Re: Diary of a Dying Transmission   Diary of a Dying Transmission - Page 4 EmptyMon Nov 16, 2009 3:17 pm
Yes, about 30,000 miles ago. I did not re-install the shift kit.
PostSubject: Re: Diary of a Dying Transmission   Diary of a Dying Transmission - Page 4 EmptyMon Nov 16, 2009 5:46 pm
Aaron, just what do you mean by "I did not re-install the shift kit" ???
A shift kit involves new springs internally in the trans. Or are talking about programming the PCM.?
PostSubject: Re: Diary of a Dying Transmission   Diary of a Dying Transmission - Page 4 EmptyMon Nov 16, 2009 5:47 pm
I meant the shift kit (springs and spacers) that were in my original transmission did not go back in with the rebuilt. I instead used PCM programming to achieve firmer shifts.
PostSubject: Re: Diary of a Dying Transmission   Diary of a Dying Transmission - Page 4 EmptyMon Nov 16, 2009 6:09 pm
Oh, now I understand.
When I had mine rebuilt I never requested anything "Special" be done other than boring and sleeving the valve body for the high pressure solenoid.
I did not know of the performance parts available for the Riv at the time (pre Rivperformance member) otherwise I would have purchased a lot more stuff for this trans.
Anyway, the rebuilder is a friend who has rebuilt countless 4T65E transmission's and is in the habit of using a certain clutch pack and shift kit on stock transmissions as it is supposed to extend the life of the HD trans.
He did not know I was going to purchase an Intense PCM, and neither did i at the time, but once I did install that PCM the shifts were horribly harsh presumably because of the combination of the shift kit and Intense's trans setting's. Eventually I removed the Intense PCM, put the stock one back in and after doing the current mod's to the engine Derek has programmed the PCM and Trans shift pressures, speed and points very nicely for my style of driving.
I can't thank the deekster enough for what he has done with the DHP tuning on my car.
» Dying Issue...
» The Buick Youve all been dying to see!
» Hd transmission?
» Ugh! Need Transmission Help
» 96 Riv Transmission
