| Write-Up: Transmission Cooler Install | |
+16robotennis61 Karma TheAviator 96RIVMANN deekster_caddy EatDirtFartDust Rickw albertj T Riley Jack the R oldsman105 Jason TType_Riviera racinfan AA dreww 20 posters |
Name : Mark Age : 58 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09 Post Count : 3108 Merit : 104
 | Subject: Re: Write-Up: Transmission Cooler Install Tue Sep 07, 2010 3:19 pm | |
| Update: I borrowed a scanner to see what this (inline) stacked-plate cooler would do on an unusual 95-degree day. The location right behind the bumper seems to block all the ram-air effect, actually leaving the tranny fluid a couple degrees higher on the freeway... However, during 40 minutes of stop & go, hills, and highway with the A/C on and the coolant going as high as 205, the fluid stayed at 180*, +/- 2 degrees. That puts it in squarely in the safe zone for fluid and transmission life - now I just hope I didn't wait too long to install it... | |
Name : Matthew Age : 36 Location : Florida Joined : 2007-01-17 Post Count : 4394 Merit : 101
 | Subject: Re: Write-Up: Transmission Cooler Install Mon May 02, 2011 11:54 pm | |
| With the added torque from my I/C install i am starting to question how much longer my stock trans will last. (180k miles now and i beat the shit out of it daily) I would like to get some kind of trans cooler installed to help with not only keeping this one as cool as possible in the FL summer, but in preparation for the trans i will eventually need to buy/rebuild. I am thinking about getting a cooler with an attached fan so i can mount it facing down at the rear of the car. (not sure quite where yet)  I would also like to clean up as much of the lines as possible and completely bypass the radiator. What lines can i use that will hold up to the heat and pressure of a trans? Opinions? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
 | Subject: Re: Write-Up: Transmission Cooler Install Tue May 03, 2011 12:59 am | |
| For a worry-free installation, I'd pay the extra $$$ for something like Earl's ProLite 350 braided Nylon hose: http://www.jegs.com/i/Earl%26%23039%3Bs/361/350606/10002/-1 detail:  Russell and Aeroquip also make high pressure hoses to withstand up to 1000 PSI and 350ºF. JEGS and Summit both sell a house brand version that costs less, but does the job. I went with JEG' Pro-Flo 350, which I think is the same as Earl's: http://www.jegs.com/p/JEGS-Performance-Products/JEGS-Pro-Flo-350-Series-Braided-Hose/761335/10002/-1 You might also consider a braided stainless hose to protect against road debris, or can enclose the Nylon hose in split loom. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
T Riley Guru
 | Subject: Re: Write-Up: Transmission Cooler Install Tue Nov 13, 2012 1:40 pm | |
| I am in need of a trans cooler. I am getting a Chris harmon built transmission with a 15/16" chain sooner than later here.. looking for a 1" chain for cheap but everyone wnats like 1500 bucks | |
 | Subject: Re: Write-Up: Transmission Cooler Install Tue Nov 13, 2012 1:42 pm | |
T Riley Guru
 | Subject: temp Thu Nov 15, 2012 2:31 am | |
| - robotennis61 wrote:
- make sure it has a fan.
oh yea. I am looking for one, a motorcycle fan might just do the trick. | |
 | Subject: Re: Write-Up: Transmission Cooler Install Thu Nov 15, 2012 7:11 am | |
| If you get the Tru-Cool MAX from page 3, it doesn't require a fan. Even when stopped idling hot, it cools right down to the 170ºF range in less than a minute. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Write-Up: Transmission Cooler Install Sat Mar 16, 2013 1:59 pm | |
| I installed this one awhile back
http://www.jegs.com/i/JEGS-Performance-Products/555/60346/10002/-1?parentProductId=1032940
along with one of these
http://www.jegs.com/i/Derale/259/16759/10002/-1
works great! easy install | |
Z-type Aficionado
 | Subject: Re: Write-Up: Transmission Cooler Install Thu Jun 06, 2013 12:53 pm | |
| Hey everyone, I thought I'd throw my installation pics up here for fun. I didn't much different than Jason or Mark did, except for one little thing, which I'll get to.  Alyssa helping me  Mounted it a familiar way. Oh, by the way, this is a B&M cooler. Smaller one, but still effective I'm sure.  Here's what I ended up doing different, just because I felt it would work nicely. I actually cut out a smaller section of the original trans line. I flared both ends with the flaring tool I didn't even know I had (found it while cleaning one day) and attached the trans fluid hoses with fuel injection clamps. Both hoses routed between the radiator and support structure rather easily, and I haven't had any issues with leaks or anything rubbing or touching.  I would not have done it this way if I didn't flare the ends of the lines. It's working great so far! I only had one little leak, and thats because I forgot to tighten a clamp at all. | |
 | Subject: Re: Write-Up: Transmission Cooler Install Thu Jun 06, 2013 4:30 pm | |
| Nice instal but one thing,I had mine mounted similar to yours the first time round and my trans got no airflow at all tucked behind the impact bar.I mounted it as close to the bottom of the condensor rad and mounted a fan too.now it's ok. | |
 | Subject: Re: Write-Up: Transmission Cooler Install  | |
