 Fuel filter replacement
rivcop
96RIVMANN
8 posters
96RIVMANN
96RIVMANN
Fuel filter replacement Empty
PostSubject: Fuel filter replacement   Fuel filter replacement EmptySun Nov 11, 2007 8:40 am
Just wanted to throw this out there and make sure that everyone replaces there's before another fuel pump goes out. I usually replace mine every 50K. I just did mine last night. It takes no more than 15 minutes to do and it will save you $$$ in the long run. Jack up the drivers side rear, throw a jack stand under the car and proceed to pull the old filter out. Easy as pie! cheers
PostSubject: Re: Fuel filter replacement   Fuel filter replacement EmptySun Nov 11, 2007 12:40 pm
Good advice. Reminds me, I need to do mine!
PostSubject: Re: Fuel filter replacement   Fuel filter replacement EmptyMon Nov 12, 2007 12:19 am
one of the easiest things to replace on this car.
in my nissan, the fuel filter is in the engine bay. cut my hands up every time.
rivcop
rivcop
PostSubject: Fuel filter replacement   Fuel filter replacement EmptyMon Nov 12, 2007 12:53 am
This post is so weird!! My car would not start all of a sudden yesterday. My motor is in tip-top shape, even has a re-maned block, but would not start. Pulled and checked all fuses, they checked ok.....Pulled, cleaned, and inspected the coils, all ok. I could even hear the fuel pump "Whine" as I started it (attempted to start it), but nothing!!! I pulled the fitting out of the fuel filter, and gold colored gas and gunk came out. Replaced line, car started up without hesitation. Nice post, I agree replacing before other problems occur, such as leaving you stranded/blind-sided, scratching your head. Bought a new one. Great post guys. bonk
Kevin
PostSubject: Re: Fuel filter replacement   Fuel filter replacement EmptyMon Nov 12, 2007 3:23 am
Jacking up the car is 3/4 of the work.
PostSubject: Re: Fuel filter replacement   Fuel filter replacement EmptyMon Nov 12, 2007 9:05 am
I did mine easily without jacking up.
PostSubject: Re: Fuel filter replacement   Fuel filter replacement EmptyMon Nov 12, 2007 9:18 am
We 6'3" 250lb guys need to jack it up to fit under there. smile This is on my annual to-do list, for sure.
PostSubject: Re: Fuel filter replacement   Fuel filter replacement EmptyMon Nov 12, 2007 9:27 am
I'm just going to pump up my rear shocks to 120 PSI!
PostSubject: Re: Fuel filter replacement   Fuel filter replacement EmptyTue Nov 13, 2007 12:52 am
i thought about that, unless they lost pressure for some reason.... shocked
PostSubject: Re: Fuel filter replacement   Fuel filter replacement EmptyTue Nov 13, 2007 12:56 am
hah......... i still couldnt get under there
PostSubject: Re: Fuel filter replacement   Fuel filter replacement EmptyTue Nov 13, 2007 4:24 pm
Kevin
if it was that bad, you may want to replace it again after a tank or 2 of gas and sea foam wink
Fuel filter replacement Dsc_0110
» Fuel filter location ?
» FAQ: Fuel Filters
» Write-Up: Fuel Filter Replacement
» Write-up: Fuel Filter removal / installation
» Where the heck was that fuel filter, again?
